Home » Modeling » Epsilon » run haetae
run haetae [message #1740285] Thu, 11 August 2016 04:27 Go to next message
How can I use haetae for static analysis of ETL ?
Can it fully detect errors for both declarative and imperative part of ETL?
Re: run haetae [message #1740304 is a reply to message #1740285] Thu, 11 August 2016 07:34 Go to previous messageGo to next message
Hi, Yes, Haetae is compatible with ETL, it is able to detect errors for both declarative and imperative parts of ETL. However, I would recommend to be cautious about the use of Any type - for best results, it is recommended to assign a variable (of any type) with the values that conform to the same type throughout the entire program.
If any problems please let me know.
Will
Re: run haetae [message #1740456 is a reply to message #1740304] Sat, 13 August 2016 04:58 Go to previous messageGo to next message
Thank you for your reply. In eclipse I went to install new software and enter the update site url. I went to Epsilon Haetae Preference and then Import all of Haetae files (that are in github) to eclipse. I create my project when I right click on my etl file, I have 3 sub menu in Epsilon Haetae. On which one of these should I click for detecting errors?
when I want to use source metamodel named Tree.ecore. How can I declare it in etl file?
Re: run haetae [message #1744216 is a reply to message #1740456] Fri, 23 September 2016 08:13 Go to previous messageGo to next message
To use Haetae, you need to go to the Preference settings in Eclipse, under Epsilon, tick "enable static analysis (experimental)". At the same time, under Epsilon Haetae, tick "Enable Epsilon Haetae (experimental)".
Haetae will take effect when these settings are applied.
You should register your metamodel before you declare it in your program. To do so, right click on Tree.ecore and select "register EPackages" from the menu.
You should declare your metamodel using the NSURI of Tree.ecore, if you are not sure what it is, In Eclipse, click Window -> Show View -> Other and search for "EPackage Registry", the registered Tree.ecore should be in the registry. What you need to enter is the nsuri. For example:
model Tree driver EMF {nsuri="http://www.eclipse.org/emf/2002/Tree"};
I hope this helps.
Re: run haetae [message #1746035 is a reply to message #1744216] Thu, 20 October 2016 12:50 Go to previous messageGo to next message
I did this settings and declared meta models but It couldn't take effect. Is there any plugins that must installed to Haetae take effect? (I only installed eclipse mars2 containing epsilon 1.3)
[Updated on: Thu, 20 October 2016 12:55] by Moderator
Re: run haetae [message #1746085 is a reply to message #1746035] Fri, 21 October 2016 08:36 Go to previous messageGo to next message
Hi, I have recently picked up with migrating Haetae to the new repository. And I noticed that the previous build had som problems for ETL and EVL supports. This problem has now been fixed, so please checkout the latest version and try again.
Will
[Updated on: Fri, 21 October 2016 08:40] by Moderator
Re: run haetae [message #1746100 is a reply to message #1746085] Fri, 21 October 2016 13:28 Go to previous messageGo to next message
It works! Thank you very much indeed.
Re: run haetae [message #1755740 is a reply to message #1746100] Tue, 07 March 2017 06:34 Go to previous messageGo to next message
Can I see .model file generated with Haetae in the form of class diagram?
Re: run haetae [message #1755791 is a reply to message #1755740] Wed, 08 March 2017 03:54 Go to previous messageGo to next message
Hi, to see .model in the form of a diagram you would probably need to generate an editor for ETL, which can be achieved in EMF. Alternatively you can use EuGENia [1].
Will
[1]. https://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.eugenia.examples.flowchart
Re: run haetae [message #1755965 is a reply to message #1755791] Thu, 09 March 2017 10:33 Go to previous messageGo to next message
Thank you very much
Re: run haetae [message #1797663 is a reply to message #1755965] Sun, 04 November 2018 08:47 Go to previous messageGo to next message
Hi there,
How can I send a part of ETL or EOL program as string to Haetae and get its equivalent model programmatically?
Best Regards,
Banafsheh
+ I have also asked this question in github
Re: run haetae [message #1798020 is a reply to message #1797663] Sat, 10 November 2018 08:19 Go to previous messageGo to next message
No one can help me?
Re: run haetae [message #1798087 is a reply to message #1797663] Mon, 12 November 2018 04:35 Go to previous messageGo to next message
In Haetae, there are a number of creators which are responsible for generating models based on the AST. Please refer to [1].
So for a given segment of code what you need to do is to:
1) get the ast of it
2) feed the ast to one of the creators, not that wrong type of AST will yeild an error for you
3) get the in memory EOLelement and do things with it.
Hope this helps.
Cheers!
Ran
Re: run haetae [message #1798277 is a reply to message #1798087] Wed, 14 November 2018 14:54 Go to previous message
Thanks. I think the reference [1] has been missed.
[Updated on: Wed, 14 November 2018 14:54] by Moderator
Previous Topic:Module ordering in project explorer
Next Topic:Creating a Simulink Model From Epsylon
Current Time: Sun Jul 27 13:57:05 EDT 2025
Powered by FUDForum. Page generated in 0.05812 seconds
