Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Rendering of font Roboto Medium seems to be broken with antialiasing != SWT.DEFAULT(Rendering of font Roboto Medium seems to be broken with antialiasing antialiasing != SWT.DEFAULT)
Rendering of font Roboto Medium seems to be broken with antialiasing != SWT.DEFAULT [message #1746041] Thu, 20 October 2016 14:26 Go to next message
we are using font Roboto Medium in our project.
When we change the antialiasing to either SWT.ON or SWT.OFF on the gc the rendering of the font seems to be broken. The font gets kind a blown up. We are not sure if the problem is only limited to Roboto Medium albeit we failed to reproduce the problem with Arial for example.
We could only reproduce the problem on windows.
Any idea what the reason for this could be? Has somebody experienced a similar problem.
We are using the fonts contained in roboto-hinted.zip which you can find at https://github.com/google/roboto/releases.
We attached a screen shot with a sample rendering as well a as small project containing test code.
Should we open a bug for this?
Cheers
[Updated on: Thu, 20 October 2016 15:52] by Moderator
Re: Rendering of font Roboto Medium seems to be broken with antialiasing != SWT.DEFAULT [message #1746172 is a reply to message #1746041] Mon, 24 October 2016 09:12 Go to previous messageGo to next message
I went ahead and created a bug for this
Re: Rendering of font Roboto Medium seems to be broken with antialiasing != SWT.DEFAULT [message #1746173 is a reply to message #1746041] Mon, 24 October 2016 09:12 Go to previous message
I went ahead and created a bug report this https://bugs.eclipse.org/bugs/show_bug.cgi?id=506437
Previous Topic:Putting Buttons into Table Headline
Next Topic:[GTK] MessageBox created behind creating dialog
Current Time: Sun Jul 27 03:49:19 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
