Home » Modeling » GMF (Graphical Modeling Framework) » Sequence diagram with GMF?
Sequence diagram with GMF? [message #636332] Sat, 30 October 2010 20:36 Go to next message
How I can do a sequence diagram with GMF?
I have defined a metamodel in EMF, which has two elements: roles and interactions. The roles can be connected to other roles through interaction. As shown in the figure below:
http://img149.imageshack.us/img149/4021/metamodelo.png
My problem is that I can not define the "lifeline" for a role. I did something similar with composite figures, but I did not allow me to connect two lifelines to each other.
http://img708.imageshack.us/img708/7963/intaractions.png
Of course, thanks for your help.
Re: Sequence diagram with GMF? [message #1721422 is a reply to message #636332] Wed, 27 January 2016 06:30 Go to previous messageGo to next message
Have you managed to implement Sequence Diagram Editor with GMF?
Thanks!
Re: Sequence diagram with GMF? [message #1721777 is a reply to message #636332] Sat, 30 January 2016 02:49 Go to previous messageGo to next message
Klementina do you have the metamodel for your Sequence Diagram? Could you post what idea do you have?
Greatings,
[Updated on: Sat, 30 January 2016 12:30] by Moderator
Re: Sequence diagram with GMF? [message #1745840 is a reply to message #1721777] Tue, 18 October 2016 05:31 Go to previous messageGo to next message
Hello. Has there been any development on this topic since the latest post?
Regards Vetle VF
[Updated on: Tue, 18 October 2016 05:32] by Moderator
Re: Sequence diagram with GMF? [message #1745929 is a reply to message #1745840] Wed, 19 October 2016 08:45 Go to previous message
Hi.
I don't know how relevant it is for your use case, but note that Sirius (which is based on GMF internally) has support for the definition of sequence diagrams [1]. There are some constraints on the metamodel to make it work, but it has been used successfuly in Capella [2] and UML Designer [3] for example. Papyrus [4] also has sequence diagrams implemented on top of GMF.
Pierre-Charles David (Sirius co-lead)
[1] https://www.eclipse.org/sirius/doc/user/sequences/Sequence%20Diagrams.html and https://www.eclipse.org/sirius/doc/specifier/sequences/Sequence%20Diagrams.html
[2] https://www.polarsys.org/capella/
[3] http://www.umldesigner.org/ref-doc/implement-the-application.html#Sequence_Diagram
[4] https://eclipse.org/papyrus/
Previous Topic:Simple constraint using OCL
Next Topic:Getting matcher from elementType instance?
Current Time: Sun Aug 31 01:13:58 EDT 2025
Powered by FUDForum. Page generated in 0.04362 seconds
