Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Putting Buttons into Table Headline
Putting Buttons into Table Headline [message #1745854] Tue, 18 October 2016 08:31 Go to next message
I have a table where the bottom right headline is nearly empty and would allow me to build a more intuitive and concise UI if I could put there in addition to the headline text (left aligned) two buttons (right aligned).
I already googled a bit and looked at the code of table and didn't find an easy solution.
Does anybody know if such a thing would be possible?
And maybe even more important do you think it would be a good idea or am I violating good UI design on many levels?
Maybe at last a short overview on the use-case the table in question is in a property sheet and holds a list of items. The buttons would be add and remove and sofar placing the buttons on all sides of the table looked other awkward, required quite some mouse movement or used a lot of space. Therefore I'm looking for alternatives.
Re: Putting Buttons into Table Headline [message #1745855 is a reply to message #1745854] Tue, 18 October 2016 08:37 Go to previous message
Sorry for the many posts. I'm at a place with bad internet connection and didn't notice it.
Previous Topic:Putting Buttons into Table Headline
Next Topic:Putting Buttons into Table Headline
Current Time: Mon Jul 28 17:44:12 EDT 2025
Powered by FUDForum. Page generated in 1.04350 seconds
