Home » Modeling » Compare » [EMF Compare] Merge action not properly done(The user interface's top panel shows the differences correctly, but when I try to merge the result is not what I expect)
[EMF Compare] Merge action not properly done [message #1745129] |
Wed, 05 October 2016 09:52  |
I have models that comply to a custom meta-model, and I've coded some customization rules to manage the comparison (custom identifiers, feature filter, diff post processor, etc.). When I launch a comparison I can see the differences and the consequences of the merge (green highlights) correctly displayed on the top panel. I see only the differences I expect to see, the filter seems to work well etc.
But when I try to merge a diff from one model the other the diffs I expect to be "dependent" (which I see highlighted in green in the top panel) do not merge.
Let me use an image to explain it further.
In my model, when a Port is added to a SubSystem, 2 items are actually added: the Port (here an Inport) and a PortBlock (here a InPortBlock). These elements have children (visible here because the "Cascading differences" filter is disabled). I wanted to display this set of (two) unit differences into a macroscopic change, so I applied a refinement. Here's the pseudo-code:
if (<is_port_diff(diff)>)
Diff c_diff = <select_corresponding_portblock_diff(diff, all_diffs)>;
if (c_diff != null)
c_diff.eSet(ComparePackage.eINSTANCE.getDiff_RefinedBy(), new ArrayList<Diff>() {{add(diff);}});
The green highlights seem to indicate that if I merge the macro change (InPortBlock) all the dependent diffs will be merged. But this is what I get when I apply, e.g., a "Copy Current Change From Left To Right":
As you can see the InPortBlock and the InPort (which refines the InPortBlock) are merged, but the children are not.
So, here's the question: how can I get merged all the model items I expect to be merged when I look the comparison result, and why are they highlighted in green but not merged?
Thanks in advance,
Matteo
Attachment: comparison.png
(Size: 139.01KB, Downloaded 711 times)
Attachment: merge.png
(Size: 8.38KB, Downloaded 667 times)
[Updated on: Wed, 05 October 2016 10:15] by Moderator
Re: [EMF Compare] Merge action not properly done [message #1765332 is a reply to message #1763897] |
Thu, 08 June 2017 09:53  |
Hi Matteo,
I've scheduled a pass on the documentation to try and update what exists for the new code base, and add the sections that are missing, but you are right, this is one of the parts that's currently not available.
I'm still not entirely sure about what's happening in there, especially in that last screenshot. Would you have any way to provide us with a sample test case to reproduce on our side? There seems to be a bug in there, since the cascading differences merging should take place in the described scenario... and even more than that the "Apply all left changes on the right-hand side" really shouldn't behave like it seems it does for you.
Nevertheless, there's been some work accomplished to try and squash the bugs we knew of on the merge process. Could you give a try to the latest version (3.3.1RC3, scheduled to be included in Oxygen)?
Laurent Goubet
Obeo
Current Time: Fri Jul 25 11:09:04 EDT 2025
Powered by FUDForum. Page generated in 0.09609 seconds
