Home » Modeling » TMF (Xtext) » Limit scope provider to few files
Limit scope provider to few files [message #1745208] Thu, 06 October 2016 10:28 Go to next message
A file in the DSL I am working on gets variables and function declarations from
  1. Current file
  2. One file implicitly included by all
  3. Files explicitly included with #include
I use this fragment
    		fragment = scoping.ImportURIScopingFragment auto-inject {
    			ignoreCase = true
and provide a descendant of ImportUriGlobalScopeProvider and ImportUriResolver to handle the implicit import and #include statements respectively.
Variables are resolved properly but performance is quite bad. If I go to Project -> Clean, Eclipse runs in the background a long, CPU intensive process (see attached screenshot) and Eclipse becomes sluggish. My understanding is that this process constructs an index of some sort and scope provider is involved.
If I remove the scoping fragment, variables defined in included file fail to resolve, the process of building the index still goes on but for seconds instead of minutes.
I suspect that the index is useful only for namespace based variable resolution. How can I disable the index building processes and keep the scope provider for the file the user is editing?
  • Attachment: screen.png
    (Size: 14.94KB, Downloaded 118 times)
Re: Limit scope provider to few files [message #1745228 is a reply to message #1745208] Thu, 06 October 2016 12:36 Go to previous messageGo to next message
i doubt your assumtions on building the index is wrong. its not building the index (that would be writing resource descriptions) but it is updating resource descriptions which is resolving cross references and validation.
i assume you use xtext >= 2.9.0. Since the Xtext team decided some years ago import uri based scoping no longer beeing a encouraged way there is no support in the workflows to get this done.
in old <=2.8.4 workflows you usually use
fragment = scoping.ImportURIScopingFragment auto-inject {}
fragment = exporting.SimpleNamesFragment auto-inject {}
which provides the following bindings.
public Class<? extends org.eclipse.xtext.scoping.IGlobalScopeProvider> bindIGlobalScopeProvider() {
return org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.class;
// contributed by org.eclipse.xtext.generator.scoping.AbstractScopingFragment
public void configureIgnoreCaseLinking(com.google.inject.Binder binder) {
binder.bindConstant().annotatedWith(org.eclipse.xtext.scoping.IgnoreCaseLinking.class).to(false);
public Class<? extends org.eclipse.xtext.naming.IQualifiedNameProvider> bindIQualifiedNameProvider() {
return org.eclipse.xtext.naming.SimpleNameProvider.class;
public void configureIScopeProviderDelegate(com.google.inject.Binder binder) {
binder.bind(org.eclipse.xtext.scoping.IScopeProvider.class).annotatedWith(com.google.inject.name.Names.named(org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider.class);
so adding these bindings and a grammar like
Model:
imports+=Import*
Import:
"#include" importURI=STRING
should basically do the behaviour in pre 2.9
https://www.eclipse.org/forums/index.php/m/1736385/?srch=SimpleLocalScopeProvider#msg_1736385
you said that you customized some of the impls and use ignore case linking
if you leave off both (by adding explicit imports for default, use case sensitive linking)
how is the performance then?
besides this: you should always measure what the actual performance bottleneck is and not work on assumptions.
you could even use the default namespace based behaviuor by
(1) give the elements a name like "file.extension.elementname"
(2) turn a include into a import "file.extension.*"
(you gave to few infos how your includes work - eg regarding relative imports/paths etc)
Re: Limit scope provider to few files [message #1745242 is a reply to message #1745228] Thu, 06 October 2016 15:43 Go to previous messageGo to next message
Thank you for the detailed answer.
I am using the latest XText. You guessed the syntax for imports correctly.
I removed from mwe the fragment about ImportURIScopingFragment and SimpleNames. However, I have in *RuntimeModule.java the following
		return P4ImportUriGlobalScopeProvider.class;
		binder.bindConstant().annotatedWith(org.eclipse.xtext.scoping.IgnoreCaseLinking.class).to(true);
	public Class<? extends ImportUriResolver> bindImportUriResolver() {
		return P4ImportUriResolver.class;
	public Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
		return P4ResourceDescriptionStrategy.class;
My resource description strategy ignores some resources to minimize the work of index building process.
I did not expect any difference in performance since I am still using my own global scope provider but strangely updating the index went from 95 seconds to 7. As far as I can tell variables are resolved correctly.
I don't know why these modifications improved performance. What tools do you use for monitoring XText plugins? JVM Monitor reports memory usage but nothing about CPU.
Re: Limit scope provider to few files [message #1745243 is a reply to message #1745242] Thu, 06 October 2016 15:48 Go to previous message
I am puzzled as well
Previous Topic:get a model from a grammar expression
Next Topic:Unit Testing the Language
Current Time: Sun Jul 20 18:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.04327 seconds
