Home » Modeling » Papyrus » JAVA error before the installation of PAPYRUS(before the instalation when we try to run papyrus an error java apear)
icon9.gif  JAVA error before the installation of PAPYRUS [message #1744604] Wed, 28 September 2016 15:42 Go to next message
Hi everyone !!
I've problem with the run of papyrus. I've download papyrus in my PC, but when i try to run papyrus, an error message apear (i've put screenshot of this message with this post) he say:
"java was started but returned exit code=13"
I didn't found anything about that in internet
Can you help me ???? Confused
Thank !
Corentin
ps: i'm french, i tryed to explain but if you don't understand, don't hesitate to ask me what you not understand Very Happy
Re: JAVA error before the installation of PAPYRUS [message #1744718 is a reply to message #1744604] Thu, 29 September 2016 11:53 Go to previous messageGo to next message
The exit code 13 is thrown in the case of a 64 / 32 bit mismatch. So please check if both JVM and the Ellipse installation is either 32 or 64 Bit. Mixed setups are not possible.
/Carsten
Re: JAVA error before the installation of PAPYRUS [message #1744727 is a reply to message #1744718] Thu, 29 September 2016 13:16 Go to previous messageGo to next message
hi cartsen,
The papyrus version is well in 64bit, I've the same problem if i try to run polarsys ...
Have you got any other idea ?
thank you very muche !
Re: JAVA error before the installation of PAPYRUS [message #1744728 is a reply to message #1744718] Thu, 29 September 2016 13:16 Go to previous messageGo to next message
hi cartsen,
Re: JAVA error before the installation of PAPYRUS [message #1744771 is a reply to message #1744728] Fri, 30 September 2016 03:26 Go to previous message
It's your java installation that you should check.
Eclipse require a 64 bit version
More explanation there:
http://stackoverflow.com/questions/11461607/cant-start-eclipse-java-was-started-but-returned-exit-code-13
Previous Topic:Any way to control default size of SVG shapes?
Next Topic:Installing SysML 1.1 in Neon
Current Time: Wed Sep 17 04:28:51 EDT 2025
Powered by FUDForum. Page generated in 0.08764 seconds
