Home » Eclipse Projects » NatTable » CalculatedValueCache Deadlock
CalculatedValueCache Deadlock [message #1744573] Wed, 28 September 2016 09:15 Go to next message
I appear to be getting a deadlock from the calculated value cache which I'm using for thumbnails (with custom painter) in my table (if there is a better way please shout).
The calulcated value cache worker thread fires a layer event which propagates throug the layers ending with a Display.syncExec (because it started in a worker thread). So far so good.
Unfortunately the main thread is busy trying to aquire a lock from eventHelperLock so this never happens. The lock can't be aquired because the calculated value cache worker thread has it (it is named as the "first reader" in the ReentrantReadWriteLock's sync object.
Most of the time this code works fine but it will inevitably go wrong occasionally. Especially when scrolling or repainting from a sort or filter.
It looks to me like a bug in the calculated value cache but I could well have things configured non optimally. Any thoughts?
Thanks!
Edit: I should also mention this is nattable 1.5.0 and an eclipse neon rcp application.
Calculated value cache worker thread.
Thread [pool-8-thread-144] (Suspended)
	waiting for: RunnableLock  (id=511)
	Object.wait(long) line: not available [native method]
	RunnableLock(Object).wait() line: 502 [local variables unavailable]
	Synchronizer.syncExec(Runnable) line: 246
	Display.syncExec(Runnable) line: 4813
	NatTable$3.getClientArea() line: 335
	GridLayer(CompositeLayer).getChildClientArea(int, int) line: 682
	CompositeLayer.access$3(CompositeLayer, int, int) line: 679
	CompositeLayer$1.getClientArea() line: 641
	ViewportLayer.getClientAreaWidth() line: 1502
	ViewportLayer.getColumnCount() line: 561
	CellVisualChangeEvent.convertToLocal(ILayer) line: 63
	ViewportLayer(AbstractLayer).handleLayerEvent(ILayerEvent) line: 260
	ViewportLayer.handleLayerEvent(ILayerEvent) line: 1332
	SelectionLayer(AbstractLayer).fireLayerEvent(ILayerEvent) line: 302
	SelectionLayer(AbstractLayer).handleLayerEvent(ILayerEvent) line: 261
	ColumnHideShowLayer(AbstractLayer).fireLayerEvent(ILayerEvent) line: 302
	ColumnHideShowLayer(AbstractLayer).handleLayerEvent(ILayerEvent) line: 261
	ColumnHideShowLayer(AbstractColumnHideShowLayer).handleLayerEvent(ILayerEvent) line: 50
	ColumnHideShowLayer.handleLayerEvent(ILayerEvent) line: 66
	ColumnReorderLayer(AbstractLayer).fireLayerEvent(ILayerEvent) line: 302
	ColumnReorderLayer(AbstractLayer).handleLayerEvent(ILayerEvent) line: 261
	ColumnReorderLayer.handleLayerEvent(ILayerEvent) line: 101
	DataLayer(AbstractLayer).fireLayerEvent(ILayerEvent) line: 302
	[b]CalculatedValueCache$1.run() line: 210[/b]
	ThreadPoolExecutor.runWorker(ThreadPoolExecutor$Worker) line: 1142
	ThreadPoolExecutor$Worker.run() line: 617 [local variables unavailable]
	Thread.run() line: 745 [local variables unavailable]
Main thread:
Thread [main] (Suspended)
	Unsafe.park(boolean, long) line: not available [native method]
	LockSupport.park(Object) line: 175
	ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronizer).parkAndCheckInterrupt() line: 836 [local variables unavailable]
	ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronizer).acquireQueued(AbstractQueuedSynchronizer$Node, int) line: 870
	ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronizer).acquire(int) line: 1199
	ReentrantReadWriteLock$WriteLock.lock() line: 943 [local variables unavailable]
	ViewportLayer(AbstractLayer).registerEventHandler(ILayerEventHandler<?>) line: 269
	ViewportLayer.moveRowPositionIntoViewport(int) line: 976
	ViewportLayer.moveCellPositionIntoViewport(int, int) line: 889
	ViewportLayer.processSelection(CellSelectionEvent) line: 1443
	ViewportLayer.handleLayerEvent(ILayerEvent) line: 1325
	SelectionLayer.fireCellSelectionEvent(int, int, boolean, boolean, boolean) line: 592
	SelectCellCommandHandler.doCommand(ILayer, SelectCellCommand) line: 42
	SelectCellCommandHandler.doCommand(ILayer, ILayerCommand) line: 1
	SelectionLayer(AbstractLayer).doCommand(ILayerCommand) line: 186
	SelectionLayer(AbstractIndexLayerTransform).doCommand(ILayerCommand) line: 105
	SelectionLayer.doCommand(ILayerCommand) line: 579
	ViewportLayer(AbstractLayerTransform).doCommand(ILayerCommand) line: 106
	ViewportLayer.doCommand(ILayerCommand) line: 1086
	BodyLayerStack(AbstractLayerTransform).doCommand(ILayerCommand) line: 106
	GridLayer.doCommandOnChildLayer(ILayerCommand, ILayer) line: 113
	GridLayer.doCommandOnChildLayers(ILayerCommand) line: 99
	GridLayer(CompositeLayer).doCommand(ILayerCommand) line: 136
	GridLayer.doCommand(ILayerCommand) line: 187
	NatTable.doCommand(ILayerCommand) line: 812
	SelectCellAction.run(NatTable, MouseEvent) line: 25
	ConfigurableModeEventHandler.mouseDown(MouseEvent) line: 45
	ModeSupport.mouseDown(MouseEvent) line: 108
	TypedListener.handleEvent(Event) line: 193
	EventTable.sendEvent(Event) line: 84
	Display.sendEvent(EventTable, Event) line: 4410
	NatTable(Widget).sendEvent(Event) line: 1079
	Display.runDeferredEvents() line: 4228
	Display.readAndDispatch() line: 3816
	PartRenderingEngine$4.run() line: 1121
	Realm.runWithDefault(Realm, Runnable) line: 336
	PartRenderingEngine.run(MApplicationElement, IEclipseContext) line: 1022
	E4Workbench.createAndRunUI(MApplicationElement) line: 150
	E4Application.start(IApplicationContext) line: 161
	EclipseAppHandle.run(Object) line: 196
	EclipseAppLauncher.runApplication(Object) line: 134
	EclipseAppLauncher.start(Object) line: 104
	EclipseStarter.run(Object) line: 388
	EclipseStarter.run(String[], Runnable) line: 243
	NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
	NativeMethodAccessorImpl.invoke(Object, Object[]) line: 62
	DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
	Method.invoke(Object, Object...) line: 498
	Main.invokeFramework(String[], URL[]) line: 673
	Main.basicRun(String[]) line: 610
	Main.run(String[]) line: 1519
	Main.main(String[]) line: 1492
[Updated on: Wed, 28 September 2016 09:24] by Moderator
Re: CalculatedValueCache Deadlock [message #1744576 is a reply to message #1744573] Wed, 28 September 2016 10:01 Go to previous messageGo to next message
You are using the CalculatedValueCache for thumbnails? I would have never come to that idea. Why? Is the calculation of the thumbnail values so expensive?
It doesn't look to me like an issue in the CalculatedValueCache. That class does not aquire a lock. It more looks like an issue related to internal event handling. Probably AbstractLayer#handleLayerEvent and AbstractLayer#registerEventHandler cause the deadlock.
Need to investigate on this. Please create a ticket.
Re: CalculatedValueCache Deadlock [message #1744587 is a reply to message #1744576] Wed, 28 September 2016 11:47 Go to previous messageGo to next message
Thanks for the quick reply.
Will do. I had a look through the source and it does aquire a readlock a few times as it propagates through but I couldn't see why it was claiming a write lock as well (that said some of the linked sources aren't working in my environment for some reason). The sync object did point at that thread though so it must have somewhere along the line.
I ended up using the calulcated value cache to allow faster painting. It seemed to give me lazy loading and caching "for free". I've got a table wtih 11k rows probably half of which have thumbnails. A full repaint without a cache or lazy loading (or for new items with just a cache) would need the loading, scaling and painting of 20odd thumbnails. The value cache just stores the ImageData so there is some overhead there but I'd run out of handles otherwise. I get a bit of flicker at the best of times.
Honestly I thought I'd got the idea from one of your posts but I can't find it anywhere. How would you have gone about it?
[Updated on: Wed, 28 September 2016 12:00] by Moderator
Re: CalculatedValueCache Deadlock [message #1744589 is a reply to message #1744587] Wed, 28 September 2016 11:59 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=502469
Thinking about it you are right that its not a CalculatedValueCache issue as such. Its threadpool does show it up though, if it was in the main thread the syncExec wouldn't lock.
Re: CalculatedValueCache Deadlock [message #1744611 is a reply to message #1744589] Wed, 28 September 2016 16:19 Go to previous messageGo to next message
I pushed a patch to Gerrit
https://git.eclipse.org/r/#/c/82117/
Is it possible for you to test this locally?
Re: CalculatedValueCache Deadlock [message #1744738 is a reply to message #1744611] Thu, 29 September 2016 14:47 Go to previous message
I merged my patch now so people are able to test easily with the latest SNAPSHOT build.
Regarding you question, when resources are involved I always use JFaceResources. We utilize it in the GUIHelper class.
Previous Topic:NatTable Drawing FPS / Performance vs SWT table
Next Topic:GroupBy - how to refresh groups after data changed?
Current Time: Fri Jul 25 11:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.06322 seconds
