Update bundle issue [message #1744497] |
Tue, 27 September 2016 08:55  |
If I use RestEasy libraries (or alternatively Jersey libraries), when I attempt to relaunch my bundle after a update, it raises many errors like :
osgi> !SESSION 2016-09-27 12:38:33.437 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_65
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_US
Command-line arguments: -configuration /tmp/.kura/configuration -console -consoleLog
!ENTRY kura.example 4 0 2016-09-27 12:40:20.131
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.io.IOException: Exception in opening zip file: /tmp/.kura/configuration/org.eclipse.osgi/bundles/73/1/bundlefile
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:291)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:87)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:100)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:73)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:245)
at org.eclipse.osgi.baseadaptor.bundlefile.BundleFile.internalGetResourceURL(BundleFile.java:150)
at org.eclipse.osgi.baseadaptor.bundlefile.BundleFile.getResourceURL(BundleFile.java:146)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findResourceImpl(ClasspathManager.java:361)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalResourceImpl(ClasspathManager.java:310)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalResource(ClasspathManager.java:297)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalResource(DefaultClassLoader.java:208)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalResource(BundleLoader.java:820)
at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:624)
at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:577)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.getResource(DefaultClassLoader.java:143)
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146)
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120)
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179)
at org.jboss.resteasy.spi.ResteasyProviderFactory.addClientMessageBodyReader(ResteasyProviderFactory.java:883)
at org.jboss.resteasy.spi.ResteasyProviderFactory.addMessageBodyReader(ResteasyProviderFactory.java:840)
at org.jboss.resteasy.spi.ResteasyProviderFactory.addMessageBodyReader(ResteasyProviderFactory.java:807)
at org.jboss.resteasy.spi.ResteasyProviderFactory.registerProvider(ResteasyProviderFactory.java:1432)
at org.jboss.resteasy.spi.ResteasyProviderFactory.registerProvider(ResteasyProviderFactory.java:1368)
at org.jboss.resteasy.plugins.providers.RegisterBuiltin.registerProviders(RegisterBuiltin.java:71)
at org.jboss.resteasy.plugins.providers.RegisterBuiltin.register(RegisterBuiltin.java:31)
at org.jboss.resteasy.client.jaxrs.ResteasyClientBuilder.getProviderFactory(ResteasyClientBuilder.java:340)
at org.jboss.resteasy.client.jaxrs.ResteasyClientBuilder.build(ResteasyClientBuilder.java:348)
at resteasy.example.RestActivator.restTest(RestActivator.java:33)
at resteasy.example.RestActivator.start(RestActivator.java:46)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.updateWorker(AbstractBundle.java:645)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.update(AbstractBundle.java:592)
at org.tigris.mtoolkit.iagent.internal.rpc.DefaultBundleManagerDelegate.updateBundle(DefaultBundleManagerDelegate.java:49)
at org.tigris.mtoolkit.iagent.internal.rpc.RemoteBundleAdminImpl.updateBundle(RemoteBundleAdminImpl.java:431)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.tigris.mtoolkit.iagent.internal.pmp.InvocationThread.run(InvocationThread.java:54)
at org.tigris.mtoolkit.iagent.internal.utils.ThreadPool$Worker.run(ThreadPool.java:179)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.FileNotFoundException: /tmp/.kura/configuration/org.eclipse.osgi/bundles/73/1/bundlefile (No such file or directory)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:219)
at java.util.zip.ZipFile.<init>(ZipFile.java:149)
at java.util.zip.ZipFile.<init>(ZipFile.java:163)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:274)
... 44 more
!ENTRY kura.example 4 0 2016-09-27 12:40:20.143
!STACK 0
java.io.IOException: Exception in opening zip file: /tmp/.kura/configuration/org.eclipse.osgi/bundles/73/1/.cp/resteasy-client-3.0.19.Final.jar
Caused by: java.io.FileNotFoundException: /tmp/.kura/configuration/org.eclipse.osgi/bundles/73/1/.cp/resteasy-client-3.0.19.Final.jar (No such file or directory)
... 44 more
I attach to this post a simple example (pom-first) with this issue.
Did anyone have explanations ?
Erwan
Re: Update bundle issue [message #1746267 is a reply to message #1746247] |
Wed, 26 October 2016 05:30  |
The issue doesn't appear when stop et restart the bundle but when uninstall, reinstall and start.
So, in a nutshell :
* Install the bundle and start, everything works
* Stop the bundle, then start the bundle, everything works
* Uninstall, reinstall and start, then see the error
* Shutting down Kura and restarting, everything works
Erwan
FUDForum. Page generated in 0.07543 seconds
