Home » Archived » BIRT » BIRT Dynamically hide option(BIRT 4.3.1 Hide option)
BIRT Dynamically hide option [message #1744477] Tue, 27 September 2016 07:23
Hi all,
I am trying to create a report in BIRT 4.3.1 and i am using with Maximo. My requirementt is to dynamically hide terms and conditions based on the type of value that i am getting in my dataset. I am creating a po print report and depeding upon service type that can be service or goods or both. Requirement is when line type is service that it should display text(a) and when line type is goods then it should display text(b) or in thrid case if both line type is both service and goods then it should display text(c). Problem is column name is LINETYPE and it value can be SERVICE, GOODS or both because there can be multiple lines. What is best and eaiset way to display and hide on BIRT report. Thanks
Previous Topic:Missing parameter exception
Next Topic:BIRT Dynamically hide option
Current Time: Mon Jul 21 06:11:30 EDT 2025
Powered by FUDForum. Page generated in 0.07470 seconds
