Unable to use a declaration in assignments and if conditions [message #1744158] |
Thu, 22 September 2016 18:02  |
I have the following grammar (snippets of):
Condition:
'condition' name=ID '(' conditionFormalParameters=FormalParameters ')' '=' conditionExpression=ConditionExpression;
ConditionExpression:
ref=ConditionRefInvocation | block=ConditionBlock;
ConditionBlock:
simple=SimpleCondition | complex=ComplexCondition;
SimpleCondition returns xbase::XBlockExpression:
{SimpleCondition}
(expressions+=ConditionBlockStatement ';'?)*
ComplexCondition returns xbase::XBlockExpression:
{ComplexCondition}
ConditionBlockStatement returns xbase::XExpression:
ConditionRefInvocation | XExpressionOrVarDeclaration;
ConditionRefInvocation:
{ConditionRefInvocation} ref=ConditionRef '(' params=ActualParameters ')';
In other words, I can define conditions and conditions are reusable. For example, the following is a snippet from my DSL that works.
condition isEmpty(String s) = {
s.empty
condition isAbcEmpty() = {
#isEmpty("abc")
However, when I try to us a Condition reference in an assignment (see below) I get a "no viable alternative at input '#'" error.
var b = #isEmpty("abc")
return b
And when I try to use a Condition reference in an if condition (see below) I get a list of errors:
- mismatched input ')' expecting '}'
- missing EOF at 'else'
- no viable alternative at input '#'
- The method isEmpty(String) is undefined
if (#isEmpty("abc")){
return true;
else{
return false;
My TypeComputer and relevant compiler methods are show below together with my compiler
//type computer
def dispatch computeTypes(ConditionRefInvocation literal, ITypeComputationState state) {
for (XExpression ap : literal.params.getParameters()) {
state.withNonVoidExpectation().computeTypes(ap);
val booleanLightWeightRef = getTypeForName(Boolean.TYPE, state)
state.withExpectation(booleanLightWeightRef)
state.acceptActualType(booleanLightWeightRef)
//compiler
override void _toJavaExpression(XExpression obj, ITreeAppendable appendable) {
switch (obj) {
ConditionRefInvocation: _toJavaExpression(obj as ConditionRefInvocation, appendable)
default: super._toJavaExpression(obj, appendable)
def _toJavaExpression(ConditionRefInvocation obj, ITreeAppendable appendable) {
appendable.trace(obj)
appendable.newLine
val condition = obj.ref.ref
val conditionParameters = obj.params
val conditionClass = condition.jvmElements.filter(JvmGenericType).filter[t|!t.isInterface].head
appendable.append('''new «conditionClass.fullyQualifiedName»().apply(''')
appendable.newLine
appendArguments(conditionParameters.parameters, appendable)
appendable.newLine
appendable.append(")")
appendable.newLine
appendable.newLine
Could you please help?
Edward
Re: Unable to use a declaration in assignments and if conditions [message #1744318 is a reply to message #1744313] |
Sun, 25 September 2016 01:24  |
from the Xbase grammar
XIfExpression returns XExpression:
{XIfExpression}
'if' '(' if=XExpression ')'
then=XExpression
(=>'else' else=XExpression)?;
=> if you want to use The ConditionRef you have to call it somewhere inside XExpression
likely at a place where it makes sense likely
XPrimaryExpression:
YourExpression | super or something likw that
FUDForum. Page generated in 0.03586 seconds
