License token is never released on DOORS 9.6.1.4 [message #1744182] |
Fri, 23 September 2016 04:27  |
Hello everybody,
I'm using Lyo to implement an OSLC consumer for DOORS 9.6.1.4. I have a problem concerning the license token taken by DWA; once an OSLC query is executed, the token is never released (I have waited for 5 days). I have to restart DWA in order to release the token.
To test it, I'm using 'DoorsOauthSample.java' and once 'SCENARIO A' is executed, DWA takes the token and it's never released.
I already set:
- OauthAccessTokenTimeout=15 on festival.xml,
- session-timeout=15 on web.xml
and this configuration does not work.
Searching by Internet and forums (thanks for the community responses), I found I have to log out from DWA once the OSLC query is executed.
How can I implement a logout on 'DoorsOauthSample.java'?
Do I have to add more configuration parameters to DWA?
Thanks for your help,
Carlos
FUDForum. Page generated in 0.09176 seconds
