Home » Eclipse Projects » Eclipse 4 » Neon: Restore editor state on startup
Neon: Restore editor state on startup [message #1744137] Thu, 22 September 2016 11:23 Go to next message
since I have changed from 4.5 (Mars) to 4.6 (Neon) the editors in my RCP does not get opened after restart even they where open before closing the application.
I had a look into workbench.xmi and it seams the relevant information are persisted.
  <persistedState key="memento" value="&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot;?>&#xD;&#xA;&lt;workbench>&#xD;&#xA;&lt;mruList>&#xD;&#xA;&lt;file factoryID=&quot;org.eclipse.ui.part.FileEditorInputFactory&quot; id=&quot;org.eclipse.ui.DefaultTextEditor&quot; name=&quot;x.txt&quot; tooltip=&quot;x/x.txt&quot;>&#xD;&#xA;&lt;persistable path=&quot;/x/x.txt&quot;/>&#xD;&#xA;&lt;/file>&#xD;&#xA;&lt;/mruList>&#xD;&#xA;&lt;/workbench>"/>
Does have any one an idea where to look for the trouble making code? Does any one have same experience after switching to Neon and a solution?
My RCP is using the compatibility layer as there are quite some e3 based plugins from IDE used in the RCP.
Any hints are appreciated, Martin
Re: Neon: Restore editor state on startup [message #1744167 is a reply to message #1744137] Fri, 23 September 2016 02:22 Go to previous messageGo to next message
Have you checked if the -clearPersistedState parameter is set?
Re: Neon: Restore editor state on startup [message #1744170 is a reply to message #1744167] Fri, 23 September 2016 02:50 Go to previous messageGo to next message
Thanks Dirk,
the -clearPersistedState is not set.
the config.ini is:
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Fri Sep 16 11:10:54 CEST 2016
org.eclipse.update.reconcile=false
eclipse.p2.profile=profile
osgi.nl=en
osgi.framework=file\:plugins/org.eclipse.osgi_3.11.0.v20160603-1336.jar
equinox.use.ds=true
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.1.200.v20160504-1450.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=de.bahntechnik.dd.opn.rcp.product
osgi.splashPath=platform\:/base/plugins/de.bahntechnik.dd.opn.rcp
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.compatibility.state_1.0.200.v20160504-1419.jar,reference\:file\:org.eclipse.osgi.nl_pt_4.5.0.v20151128060001.jar,reference\:file\:org.eclipse.osgi.nl_zh_4.5.0.v20151128060001.jar,reference\:file\:org.eclipse.osgi.nl_zh_TW_4.5.0.v20151128060001.jar
osgi.bundles.defaultStartLevel=4
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.p2.data.area=@config.dir/../p2
The layout of views /perspective is restored only the files does not get opened after restart of the RCP.
Any idea where to debug?
Martin
Re: Neon: Restore editor state on startup [message #1744171 is a reply to message #1744170] Fri, 23 September 2016 03:05 Go to previous messageGo to next message
Unfortunately not. Sorry. Maybe in org.eclipse.ui.part.FileEditorInputFactory but I'm honestly not very familiar with that part of the platform.
Re: Neon: Restore editor state on startup [message #1744849 is a reply to message #1744171] Fri, 30 September 2016 13:58 Go to previous messageGo to next message
We are hit by the same issue. All last opened editors are not restored on workbench restart.
I found the culprit to be within our fragment.e4xmi. As soon as I disable it, everything works as expected. Thus, I believe it has something to do how the editors are restored in e4 when a fragment is involved.
Do you have a custom e4 application model?
[Updated on: Fri, 30 September 2016 16:18] by Moderator
Re: Neon: Restore editor state on startup [message #1745006 is a reply to message #1744849] Tue, 04 October 2016 03:27 Go to previous messageGo to next message
Yes, I am using multiple fragment.e4xmi to define a perspectives, commands and so on.
I do not have a custom e4 application model as I am defining a product with application ID "org.eclipse.ui.ide.workbench".
I thought it might be connected to my own defined persepctives. But this is not the case as I used the "Resource" perspective provided by the application and the issue still persists.
Unfortunately I did not have time to debug into org.eclipse.ui.part.FileEditorInputFactory.
Do you think its because of the use of fragment.e4xmi or a specific setting?
Re: Neon: Restore editor state on startup [message #1745021 is a reply to message #1745006] Tue, 04 October 2016 05:32 Go to previous messageGo to next message
Maybe the issue is related to the fact that perspectives need to be contributed as snippets in mixed mode (usage of the compatibility layer and E4 contributions)
Re: Neon: Restore editor state on startup [message #1745024 is a reply to message #1745021] Tue, 04 October 2016 05:37 Go to previous messageGo to next message
Or some sort of startup issue. Have you tried to auto start the plugin via product configuration?
Re: Neon: Restore editor state on startup [message #1745027 is a reply to message #1745006] Tue, 04 October 2016 06:16 Go to previous message
Martin,
I can confirm that this is related to defining/contributing a perspective via fragments to the IDE. There is something fishy with the compatibility layer and the shared editor area. I suspect (but I did not debug) that because of that the code to restore the editors is not triggered or is confused where to restore them.
As a workaround, I reverted back to defining/contributing the perspective using plugin.xml. Works like a charm.
I've opened https://bugs.eclipse.org/502963 to clarify whether extending the IDE by fragments is supported/recommended or not. A reply on Twitter indicates it's not designed for this.
-Gunnar
[Updated on: Tue, 04 October 2016 06:19] by Moderator
Previous Topic:Spies will not install on Mars 4.5.2
Next Topic:Update NEON to NEON.1 and get error
Current Time: Sat Jul 26 12:11:15 EDT 2025
Powered by FUDForum. Page generated in 0.06140 seconds
