Home » Eclipse Projects » Oomph » Why oomph plugins versions from 1.5 become 1.4?
Why oomph plugins versions from 1.5 become 1.4? [message #1743468] Thu, 15 September 2016 13:04 Go to next message
Eclipse-Installer updated to 1.5 Build 2601
Reinstall Eclipse(Neon)
Found in the Bundle Pool Analysis, Oomph version is not 1.5 but 1.4
Re: Why oomph plugins versions from 1.5 become 1.4? [message #1743472 is a reply to message #1743468] Thu, 15 September 2016 14:03 Go to previous messageGo to next message
Bing Kun Yang wrote on Thu, 15 September 2016 19:04
To what "Oomph version" exactly are you referring? Can you show a screenshot?
Note that the versions of the plugins and features in a release can be lower than the version of that release. If there's no change in a plugin there's no need to increase its version.
Re: Why oomph plugins versions from 1.5 become 1.4? [message #1743481 is a reply to message #1743472] Thu, 15 September 2016 15:21 Go to previous messageGo to next message
index.php/fa/27091/0/
Marked "new" is my new install of Eclipse, "old" is a previous install of Eclipse
Two versions of the Eclipse is 4.6
Before install Eclipse is used by default is 1.5, new install of Eclipse is used by default is 1.4
Why not continue to use 1.5?
Re: Why oomph plugins versions from 1.5 become 1.4? [message #1743503 is a reply to message #1743481] Fri, 16 September 2016 01:56 Go to previous messageGo to next message
We found the problem in our promotion system and we've fixed it. You should now see the 1.5 build as expected. Can you please try to update?
Re: Why oomph plugins versions from 1.5 become 1.4? [message #1743525 is a reply to message #1743503] Fri, 16 September 2016 04:13 Go to previous message
Issue has been solved
Thank you
Previous Topic:How to override/disable P2Task for user
Next Topic:Oomph installs aren't working with Eclipse 4.7 I-builds
Current Time: Mon Nov 10 06:40:18 EST 2025
Powered by FUDForum. Page generated in 0.03364 seconds
