appendArguments(..) generating comments instead of content [message #1742541] |
Sat, 03 September 2016 20:13  |
I have the following grammar (snippets of):
Action:
'action' name=ID '(' actionFormalParameters=FormalParameters ')' '=' action=ActionBlock;
ActionBlock returns xbase::XBlockExpression:
{ActionBlock}
(expressions+=ActionBlockStatement ';'?)*
ActionBlockStatement returns xbase::XExpression:
ActionRefInvocation | XExpressionOrVarDeclaration;
ActionRefInvocation:
actionRef=ActionRef '(' actionActualParameters=ActualParameters ')';
ActionRef hidden():
'#' actionRefId=[Action];
In other words, I want to be able to do something like this:
action a(String s) = {
println(s)
action b(String s) = {
#a(s)
In my compiler that extends XbaseCompiler, I have the following function to handle ActionRefInvocation:
override protected doInternalToJavaStatement(XExpression obj, ITreeAppendable appendable, boolean isReferenced) {
if (obj instanceof ActionRefInvocation) {
appendable.trace(obj)
appendable.newLine
val action = obj.actionRef.actionRefId
val actionParameters = obj.actionActualParameters
val actionClass = action.jvmElements.filter(JvmGenericType).filter[t|!t.isInterface].head
val objectName = "action" + uuidName
appendable.append('''«actionClass.fullyQualifiedName» «objectName» = new «actionClass.fullyQualifiedName»();''')
appendable.newLine
appendable.append('''«objectName».accept(''')
appendable.newLine
appendArguments(actionParameters.parameters, appendable)
appendable.append(");")
appendable.newLine
appendable.newLine
return
super.doInternalToJavaStatement(obj, appendable, isReferenced)
But the output I get from the compilation is the following, which of course does not compile because the function implementation of a expects a String argument.
public void accept(final int i) {
valour.documentation.actions.Action6 action07f90ee2b6004c4fb226bbe61c58c88f = new valour.documentation.actions.Action6();
action07f90ee2b6004c4fb226bbe61c58c88f.accept(
/* name is null */);
Also, I've noticed that if I change the example supplied above to:
println(s)
action b() = {
#a("foo")
I get the following null pointer exception on the invocation of appendArguments(..)
!STACK 0
at org.eclipse.xtext.xbase.compiler.LiteralsCompiler.toJavaExpression(LiteralsCompiler.java:81)
at org.eclipse.xtext.xbase.compiler.LiteralsCompiler._toJavaExpression(LiteralsCompiler.java:73)
at org.eclipse.xtext.xbase.compiler.LiteralsCompiler.internalToConvertedExpression(LiteralsCompiler.java:41)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.internalToConvertedExpression(FeatureCallCompiler.java:102)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.internalToConvertedExpression(XbaseCompiler.java:317)
at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToConvertedExpression(TypeConvertingCompiler.java:104)
at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToJavaExpression(TypeConvertingCompiler.java:47)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArgument(FeatureCallCompiler.java:1033)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArguments(FeatureCallCompiler.java:995)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArguments(FeatureCallCompiler.java:989)
at mt.edu.um.cs.rv.ValourCompiler.doInternalToJavaStatement(ValourCompiler.java:70)
I'm not sure what I'm doing wrong here. I would appreciate your help.
Re: appendArguments(..) generating comments instead of content [message #1743471 is a reply to message #1742702] |
Thu, 15 September 2016 13:59   |
Thanks for you reply Christian, and sorry for getting back late but was on vacation since.
In my inferrer, I am first creating an FunctionalInterface for the action
val consumableFunctionalInterface = action.toClass(
functionalInterfaceName,
annotations += annotationRef(FunctionalInterface)
interface = true
members += action.toMethod("accept", typeRef(void), [
static = false
^default = false
abstract = true
visibility = JvmVisibility.PUBLIC
action.actionFormalParameters.parameters.forEach [ p |
parameters += action.toParameter(p.name, p.parameterType)
and then creating an implementation of the FunctioanlInterface and plugging in the body of the action
val actionClass = action.toClass(
className,
superTypes += typeRef(functionalInterfaceName)
static = false
annotations += annotationRef(Override)
body = action.action
I have not implemented anything in terms of the type computer. Is this something that I should be extending ?
My definition of ActualParameter is the following:
ActualParameters:
{ActualParameters}(parameters+=XExpression (',' parameters+=XExpression)*)?;
Any guidance to help me get this set up in the proper way would be greatly appreciated.
FUDForum. Page generated in 0.28459 seconds
