Home » Modeling » TMF (Xtext) » How to use @Flaky annotation(How to use @Flaky annotation for running failing tests more than once.)
How to use @Flaky annotation [message #1743424] Thu, 15 September 2016 06:23 Go to next message
Team,
I have some tests which fail sometimes unexpectedly and run fine when executed next time. So, to handle these tests I am trying to use @Flaky annotation (org.eclipse.xtext.junit4.Flaky). Here is my usage:
@Rule
public Flaky.Rule testRule = new Flaky.Rule();
@Flaky
@Test
public void testMethod() {
Assert.assertTrue(false);
As per documentation, the failing tests should get executed 3 time by default. But, I do not see the test running 3 times. It runs once and fails. Thats all. Nothing happens after that.
Am I missing any other configuration for using @Flaky annotation. I would like to know if any of you have used this annotation or have knowledge on how to use it for failing tests. Appreciate your time.
Thanks.
Vivek Veera
Re: How to use @Flaky annotation [message #1743427 is a reply to message #1743424] Thu, 15 September 2016 07:44 Go to previous messageGo to next message
id have expected something like
@Rule
Re: How to use @Flaky annotation [message #1743432 is a reply to message #1743427] Thu, 15 September 2016 08:23 Go to previous messageGo to next message
Hi Christian,
I could not understand your point. Could you please elaborate.
Are you suggesting to include a rule. I have actually added that if you see my code snippet below.
@Rule
@Flaky
@Test
Thanks for replying.
Vivek Veera
Re: How to use @Flaky annotation [message #1743433 is a reply to message #1743432] Thu, 15 September 2016 08:30 Go to previous message
the following works nice for me
import org.eclipse.xtext.junit4.Flaky;
import org.eclipse.xtext.xbase.lib.InputOutput;
import org.junit.Assert;
import org.junit.Rule;
import org.junit.Test;
@SuppressWarnings("all")
public class DemoTest {
@Rule
@Flaky
@Test
InputOutput.<String>println("mimi");
Previous Topic:xtext keyword problem
Next Topic:Integrating Xbase in my DSL. How to activate scoping and validation?
Current Time: Mon Jul 21 08:21:59 EDT 2025
Powered by FUDForum. Page generated in 1.08202 seconds
