Xtext parser programmatically for XMI generation [message #1743247] |
Tue, 13 September 2016 10:17  |
Hi all,
I am using Xtext as a parser to transform an input file with the extension .mydsl to a .xmi file.
I implemented my grammar and I can use it by opening an Eclipse Application and creating a file with the extension .mydsl. The extension is recognized and I can paste my input file into this file.
Then, I open this file with Sample Reflective Ecore Model Editor and finally I realise a "save as" to transform it in .xmi file.
It is quite laborious then I would like to automate this transformation. I created a java application (IHM) and I tried this code from https://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
new org.eclipse.emf.mwe.utils.StandaloneSetup().setPlatformUri("../");
Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource resource = resourceSet.createResource(URI.createURI("dummy:/example.mydsl"));
InputStream in = new ByteArrayInputStream("type foo type bar".getBytes());
resource.load(in, resourceSet.getLoadOptions());
Model model = (Model) resource.getContents().get(0);
It is not working.
Do I have to save the resource as xmi?
Could you help me please?
Jean
Re: Xtext parser programmatically for XMI generation [message #1743380 is a reply to message #1743367] |
Wed, 14 September 2016 13:57   |
Hi Christian,
Thank you for your answers.
Firstly, I am going to give you more information about my project.
My objective is to convert a file written according to mydsl to a HTML file or Matlab file.
For the moment, I am doing it in two time:
- I already have the transformation from XMI file to HTML or Matlab. It is implemented with acceleo. I insert it on my HMI (java application), it is working.
- Then I have to implement a transformation from my DSL file to XMI. As I said previously, I did it with Xtext, it works manually but I have some difficulties to insert it in my HMI.
Please find below my HMI:
In the future, I will hide the step of the XMI generation.
Now about my issue:
I tried your code, I can't make it working.
Please find below the error log
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Contenu non autorisé dans le prologue.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at fr.estaca.dbc.convertor.ui.View$3.run(View.java:225)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.xml.sax.SAXParseExceptionpublicId: dummy:/example.mydsl; systemId: dummy:/example.mydsl; lineNumber: 1; columnNumber: 1; Contenu non autorisé dans le prologue.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 4 more
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:398)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481)
at fr.estaca.dbc.convertor.ui.View.transform(View.java:272)
at fr.estaca.dbc.convertor.ui.View.widgetSelected(View.java:168)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4410)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4228)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3816)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at fr.estaca.dbc.convertor.ui.Application.start(Application.java:20)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346)
at fr.estaca.dbc.convertor.ui.View$3.run(View.java:230)
Thanks for your help.
Jean
FUDForum. Page generated in 0.03945 seconds
