Home » Archived » Jubula » Jubula 8.3 - Database connection failed because of invalid or missing database detail
Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743334] Wed, 14 September 2016 09:13 Go to next message
Hello People
After migrating to the new Jubula 8.3 installation. I get the error below. Please what am I missing. My database is an Oracle 11g db. What does it mean major version invalid.
2016-09-14 15:13:16.331 [Worker-0] ERROR o.e.j.c.core.persistence.Persistor - DBVersion: major version invalid
2016-09-14 15:13:16.339 [Worker-0] ERROR o.e.j.c.core.persistence.Persistor - ITE version problem - database schema version: "60.0" <--> ITE expected version: "50.0"
2016-09-14 15:13:16.343 [main] ERROR o.e.j.a.testexec.core.TestexecClient - Database connection failed because of invalid or missing database detail
java.lang.IllegalArgumentException: Database connection failed because of invalid or missing database detail
	at org.eclipse.jubula.app.testexec.core.ExecutionController.prepareDBConnection(ExecutionController.java:538) ~[na:na]
	at org.eclipse.jubula.app.testexec.core.ExecutionController.executeJob(ExecutionController.java:322) ~[na:na]
	at org.eclipse.jubula.app.testexec.core.TestexecClient.doRun(TestexecClient.java:78) ~[na:na]
	at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:444) [org.eclipse.jubula.client.cmd_4.0.0.201603111021.jar:na]
	at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:27) [org.eclipse.jubula.client.cmd_4.0.0.201603111021.jar:na]
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [org.eclipse.equinox.app_1.3.200.v20130910-1609.jar:na]
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_66]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_66]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_66]
	at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_66]
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
	at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62) [i4jruntime.jar:na]
	at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:101) [i4jruntime.jar:na]
	at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:16) [i4jruntime.jar:na]
2016-09-14 15:13:16.344 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Database connection failed because of invalid or missing database detail
<configuration>
    <project>XXXXX</project>
    <version>XXXXXXX</version>
    <autconfig>XXXXXX</autconfig>
    <dburl>jdbc:oracle:thin:@XXXXX:XXXX:XXXXXX</dburl>
    <dbuser>JTA_NEW</dbuser>
    <dbpw>jta_new_sssss</dbpw>
	 <testjob>XXXXXX</testjob>
	 <server>qa-test-automation-pc1</server>
	 <port>60000</port>
	</configuration>
I created a new schema. Imported old projects to the new installation. Trying to test if everything works well I get the error. I have tried via testexec and directly from the ITE itself i get the same error. I attached the full client log to the post and also screen shot showing successful connection to the db.
Thanks in advance.
Kind regards,
Dave
[Updated on: Wed, 14 September 2016 09:17] by Moderator
Re: Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743345 is a reply to message #1743334] Wed, 14 September 2016 09:53 Go to previous messageGo to next message
When does the error above come? Does it come when you try to open a project via Test->Open? Do you see an error in the ITE, or just in the log files?
Alex
Re: Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743354 is a reply to message #1743345] Wed, 14 September 2016 10:15 Go to previous messageGo to next message
After speaking to a developer, it looks like the version of the ITE or testexec that you are using to connect to the new database is the *old* version (database version 50.0). So the database is correctly created, but the client you are using to connect is outdated. Can you check whether you're starting testexec / the ITE from the right installation? Bear in mind, if you have multiple machines, that the installation needs to be updated on all of them. The version of the ITE can be checked via Help / About.
Alex
icon14.gif  Re: Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743365 is a reply to message #1743354] Wed, 14 September 2016 10:36 Go to previous messageGo to next message
Worked like a charm. I had to update my environment variable it was pointing to the old version.
Thank you Alex.
Dave.
Re: Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743403 is a reply to message #1743365] Thu, 15 September 2016 02:12 Go to previous message
Excellent news, great that it's working now! Smile
Previous Topic:please delete
Next Topic:how to handle Project Language in Jubula 8.2.2
Current Time: Sun Jul 27 16:26:15 EDT 2025
Powered by FUDForum. Page generated in 0.05603 seconds
