Home » Language IDEs » ServerTools (WTP) » J2EE Module Dependencies - Project Migration WTP 1.0 to WTP 1.5 (Calisto)
J2EE Module Dependencies - Project Migration WTP 1.0 to WTP 1.5 (Calisto) [message #173628] Sat, 08 July 2006 14:52 Go to next message
Originally posted by: Martin.Ahrer.gmx.at
--------------020108040103070502000505
I have been using the J2EE Module Dependencies with eclipse 3.1.2 + WTP
1.0.1.
Now I'm trying to migrate some projects to eclipse 3.2 + WTP 1.5
(Calisto release). When trying to add a Project dependendy in a Web
Project (using the J2EE Module Dependencies Panel) I'm getting a
"IWAE0010E An internal error occurred:"
Unfortunately no error log entry in the errors view to help diagnosing
the problem.
It works when creating a new Java Project within the new environment
(WTP 1.5), such a project can be added with no problems.
I have also tried to copy the metadata file (.setting, .project,
..classpath, .etc) from this new project to the one I'm trying to migrate
- with no success!
I diagnosed that WTP 1.0.1 was using a .settings/.component file for
maintaining Module dependencies. WTP 1.5 seems to be using
org.eclipse.wst.common.component. After loading the old project
..component was gone at all but no org.eclipse.wst.common.component
exists either.
Maybe somebody was able to do a migration, would be interested how this
migration is possible. I just can't afford re-creating all projects!
Martin
ps/ I would be willing to provide a candidate web and utility project to
test this behaviour!
name="configuration-details.txt"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline;
filename="configuration-details.txt"
*** Date: Sat Jul 08 20:48:41 CEST 2006
*** Platform Details:
*** System properties:
awt.toolkit=3Dsun.awt.windows.WToolkit
eclipse.buildId=3DM20060629-1905
eclipse.commands=3D-os
win32
-ws
win32
-arch
x86
-launcher
D:\Java\eclipse-SDK-3.2\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
d1c_8c
-vm
C:\Programme\Java\jdk1.4.2_11\bin\javaw.exe
eclipse.ee.install.verify=3Dfalse
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1152379351947
eclipse.vm=3DC:\Programme\Java\jdk1.4.2_11\bin\javaw.exe
eclipse.vmargs=3D-Xms40m
-Xmx256m
-jar
D:\Java\eclipse-SDK-3.2\startup.jar
eof=3Deof
file.encoding=3DCp1252
file.encoding.pkg=3Dsun.io
file.separator=3D\
java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
java.class.path=3DD:\Java\eclipse-SDK-3.2\startup.jar
java.class.version=3D48.0
java.endorsed.dirs=3DC:\Programme\Java\jdk1.4.2_11\jre\lib\e ndorsed
java.ext.dirs=3DC:\Programme\Java\jdk1.4.2_11\jre\lib\ext
java.home=3DC:\Programme\Java\jdk1.4.2_11\jre
java.io.tmpdir=3DC:\DOKUME~1\martin\LOKALE~1\Temp\
java.library.path=3DC:\Programme\Java\jdk1.4.2_11\bin;.;C:\W INDOWS\system=
32;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\Syst em32\Wbem;C:\=
Programme\svn-win32-1.3.1\bin;C:\Programme\CVSNT\;D:\Java\3r dparty\maven-=
2.0.4\bin;D:\Java\3rdparty\maven-1.1-beta-2\bin;D:\Java\3rdp arty\apache-a=
nt-1.6.5\bin;D:\Java\3rdparty\apache-forrest-0.7\bin;D:\Tool s\unxupdat;D:=
\Tools\unxutils\bin;D:\Tools\unxutils\usr\local\wbin
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.4.2_11-b06
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.4
java.util.prefs.PreferencesFactory=3Djava.util.prefs.Windows PreferencesFa=
ctory
java.vendor=3DSun Microsystems Inc.
java.vendor.url=3Dhttp://java.sun.com/
java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
java.version=3D1.4.2_11
java.vm.info=3Dmixed mode
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DSun Microsystems Inc.
java.vm.version=3D1.4.2_11-b06
line.separator=3D
org.osgi.framework.bootdelegation=3D*
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-1=
=2E1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=3Dde
org.osgi.framework.os.name=3DWindowsXP
org.osgi.framework.os.version=3D5.1
org.osgi.framework.processor=3Dx86
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.crypto,jav=
ax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.i mageio.event,=
javax.imageio.metadata,javax.imageio.plugins.jpeg,javax.imag eio.spi,javax=
=2Eimageio.stream,javax.naming,javax.naming.directory,javax. naming.event,=
javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,j avax.print,ja=
vax.print.attribute,javax.print.attribute.standard,javax.pri nt.event,java=
x.rmi,javax.rmi.CORBA,javax.security.auth,javax.security.aut h.callback,ja=
vax.security.auth.kerberos,javax.security.auth.login,javax.s ecurity.auth.=
spi,javax.security.auth.x500,javax.security.cert,javax.sound .midi,javax.s=
ound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,ja vax.sql,javax=
=2Eswing,javax.swing.border,javax.swing.colorchooser,javax.s wing.event,ja=
vax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basi c,javax.swing=
=2Eplaf.metal,javax.swing.plaf.multi,javax.swing.table,javax .swing.text,j=
avax.swing.text.html,javax.swing.text.html.parser,javax.swin g.text.rtf,ja=
vax.swing.tree,javax.swing.undo,javax.transaction,javax.tran saction.xa,ja=
vax.xml.parsers,javax.xml.transform,javax.xml.transform.dom, javax.xml.tra=
nsform.sax,javax.xml.transform.stream,org.ietf.jgss,org.omg. CORBA,org.omg=
=2ECORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAny Package,org.o=
mg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.Typ eCodePackage,=
org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage, org.omg.CosNa=
ming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny ,org.omg.Dyna=
micAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage ,org.omg.IOP,=
org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org .omg.Messagin=
g,org.omg.PortableInterceptor,org.omg.PortableInterceptor.OR BInitInfoPack=
age,org.omg.PortableServer,org.omg.PortableServer.CurrentPac kage,org.omg.=
PortableServer.POAManagerPackage,org.omg.PortableServer.POAP ackage,org.om=
g.PortableServer.portable,org.omg.PortableServer.ServantLoca torPackage,or=
g.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.x ml.sax,org.xm=
l.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.3.0
org.osgi.supports.framework.extension=3Dtrue
org.xml.sax.driver=3Dorg.apache.crimson.parser.XMLReaderImpl
os.arch=3Dx86
os.name=3DWindows XP
os.version=3D5.1
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.equinox.common@2:start, org.eclipse.update.con=
figurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=3DD:\Java\eclipse-SDK-3.2\configuration\org .eclipse.osgi=
\bundles
osgi.configuration.area=3Dfile:/D:/Java/eclipse-SDK-3.2/conf iguration/
osgi.framework=3Dfile:/d:/Java/eclipse-SDK-3.2/plugins/org.e clipse.osgi_3=
=2E2.0.v20060601.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.2.0.v20060601
osgi.install.area=3Dfile:/D:/Java/eclipse-SDK-3.2/
osgi.instance.area=3Dfile:/D:/Projects/eclipse-workspace-ehi -eclipse-3.2/=
osgi.instance.area.default=3Dfile:/C:/Dokumente und Einstellungen/martin/=
workspace/
osgi.logfile=3DD:\Projects\eclipse-workspace-ehi-eclipse-3.2 \.metadata\.l=
og
osgi.manifest.cache=3DD:\Java\eclipse-SDK-3.2\configuration\ org.eclipse.o=
sgi\manifests
osgi.nl=3Dde_DE
osgi.os=3Dwin32
osgi.splashLocation=3Dd:\Java\eclipse-SDK-3.2\plugins\org.ec lipse.platfor=
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3Dd:\Java\eclipse-SDK-3.2\plugins
osgi.ws=3Dwin32
path.separator=3D;
sun.arch.data.model=3D32
sun.boot.class.path=3DC:\Programme\Java\jdk1.4.2_11\jre\lib\ rt.jar;C:\Pro=
gramme\Java\jdk1.4.2_11\jre\lib\i18n.jar;C:\Programme\Java\j dk1.4.2_11\jr=
e\lib\sunrsasign.jar;C:\Programme\Java\jdk1.4.2_11\jre\lib\j sse.jar;C:\Pr=
ogramme\Java\jdk1.4.2_11\jre\lib\jce.jar;C:\Programme\Java\j dk1.4.2_11\jr=
e\lib\charsets.jar;C:\Programme\Java\jdk1.4.2_11\jre\classes
sun.boot.library.path=3DC:\Programme\Java\jdk1.4.2_11\jre\bi n
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3Dpentium i486 i386
sun.io.unicode.encoding=3DUnicodeLittle
sun.java2d.fontpath=3D
sun.os.patch.level=3DService Pack 2
user.country=3DDE
user.dir=3DD:\Java\eclipse-SDK-3.2
user.home=3DC:\Dokumente und Einstellungen\martin
user.language=3Dde
user.name=3Dmartin
user.timezone=3DEurope/Berlin
user.variant=3D
vendor=3DApache Software Foundation
vendor-url=3Dhttp://xml.apache.org/xalan-j
version=3D2.4.1
workspace.projectclasspath=3DD:\Projects\eclipse-workspace-e hi-eclipse-3.=
2\TemplateGenerator\bin;D:\Projects\eclipse-workspace-ehi-ec lipse-3.2\Tra=
velExpenseService\build\classes;D:\Projects\eclipse-workspac e-ehi-eclipse=
-3.2\TravelExpenseWeb\build\classes;D:\Projects\eclipse-work space-ehi-ecl=
ipse-3.2\utl\build\classes;D:\Projects\eclipse-workspace-ehi -eclipse-3.2\=
utl1
*** Features:
com.lowagie.itext (1.3.0.N20060628-1351) "Lowagie Itext"
com.nilswinkler.eclipse.accessmodifier (1.2.6) "Access Modifier Plug-in"
org.apache.batik (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik=
Pdf"
org.apache.commons.codec (1.3.0.N20060628-1351) "Apache Commons Codec"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.eclipse.birt (2.1.0.N20060628-1351) "Business Intelligence and Report=
ing Tools"
org.eclipse.birt.chart (2.1.0.N20060628-1351) "BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.1.0.N20060628-1351) "BIRT Chart Context-=
sensitive Help"
org.eclipse.birt.chart.runtime (2.1.0.N20060628-1351) "BIRT Chart Runtime=
org.eclipse.birt.cshelp (2.1.0.N20060628-1351) "BIRT Context-sensitive He=
lp"
org.eclipse.birt.example (2.1.0.N20060628-1351) "BIRT Example"
org.eclipse.birt.report.designer (2.1.0.N20060628-1351) "BIRT Report Desi=
gner"
org.eclipse.birt.report.runtime (2.1.0.N20060628-1351) "BIRT Report Runti=
me"
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools"
org.eclipse.datatools.connectivity.feature (0.9.0.200606161) "Eclipse Dat=
a Tools Platform Connectivity"
org.eclipse.datatools.connectivity.oda.designer.feature (0.9.0.200606161)=
"Eclipse Data Tools Platform Connectivity Open Data Access (ODA) Designe=
r"
org.eclipse.datatools.connectivity.oda.feature (0.9.0.200606161) "Eclipse=
Data Tools Platform Connectivity Open Data Access (ODA)"
org.eclipse.datatools.enablement.feature (0.9.0.200606161) "Eclipse Data =
Tools Platform Enablement"
org.eclipse.datatools.modelbase.feature (0.9.0.200606161) "Eclipse Data T=
ools Platform Model Base"
org.eclipse.datatools.sqldevtools.feature (0.9.0.200606161) "Eclipse Data=
Tools Platform SQL Development Tools"
org.eclipse.emf (2.2.0.v200606271057) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.0.v200606271057) "EMF Service Data Objects=
(SDO)"
org.eclipse.emf.ocl (1.0.0.v200606261119) "Eclipse Modeling Framework Tec=
hnology OCL Interpreter"
org.eclipse.emf.query (1.0.0.v200606261130) "Eclipse Modeling Framework T=
echnology Query Framework"
org.eclipse.emf.query.ocl (1.0.0.v200606261130) "Eclipse Modeling Framewo=
rk Technology Query OCL"
org.eclipse.emf.transaction (1.0.0.v200606261303) "Eclipse Modeling Frame=
work Technology Transaction Core"
org.eclipse.emf.validation (1.0.0.v200606261144) "Eclipse Modeling Framew=
ork Technology Model Validation Core"
org.eclipse.emf.validation.ocl (1.0.0.v200606261144) "Eclipse Modeling Fr=
amework Technology Validation Support for OCL"
org.eclipse.emf.workspace (1.0.0.v200606261303) "Eclipse Modeling Framewo=
rk Technology Workbench Core"
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework"
org.eclipse.gmf (1.0.0.v20060627-1200) "Graphical Modeling Framework"
org.eclipse.jdt (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java Developm=
ent Tools"
org.eclipse.jdt.source (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java D=
evelopment Tools SDK"
org.eclipse.jem (1.2.0.v20060530_RC2--ZasJzJJez) "Java EMF Model"
org.eclipse.jst (1.5.0.v200606092300-kW-O_ysCRLJsxJt) "J2EE Standard Tool=
s (JST)"
org.eclipse.pde (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-in Devel=
opment Environment"
org.eclipse.pde.source (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-i=
n Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse Platform=
org.eclipse.platform.source (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse P=
latform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP Pl=
org.eclipse.sdk (3.2.0.v20060609m-GNq6oQq-7es-Y81) "Eclipse Project SDK"
org.eclipse.tptp.monitoring (4.2.0.v200606131519--_OmSTOTOd6a3aR) "TPTP M=
onitoring"
org.eclipse.tptp.monitoring.doc.user (4.2.0.v200606121835--0842282835373A=
) "TPTP Monitoring Project Documentation"
org.eclipse.tptp.monitoring.examples (4.2.0.v200606121835--0842282835373A=
) "User examples for the TPTP Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.profile.server (4.1.100.v200606131519--084228=
2835373A) "TPTP Profile On Server Logging Utility"
org.eclipse.tptp.monitoring.report.birt (4.2.0.v200606131519--2PD88P8PAGA=
MAY) "BIRT Monitor Reports for TPTP Branding Plugin"
org.eclipse.tptp.platform.analysis (4.2.0.v200606131519--3YIAAYAYEMEUEk) =
"TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java (4.2.0.v200606131519--=
1G955G5G7A7E7M) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine (4.2.0.v200606131519--1G955G5G7=
A7E7M) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.2.0.v200606150100--Cq0bcpcppNmQn0) "TPT=
P Platform"
org.eclipse.tptp.platform.core.doc.user (4.2.0.v200606121835--1G955G5G7A7=
E7M) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.2.0.v200606121835-8AcKKEiFfIYIiEo) =
org.eclipse.tptp.platform.examples (4.2.0.v200606121835--0842282835373A) =
"TPTP Platform Examples"
org.eclipse.tptp.platform.lta (4.2.0.v200606131519--1G955G5G7A7E7M) "TPTP=
Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.2.0.v200606131519--3YIAAYAYEMEUEk) =
"TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user (4.2.0.v200606121835--0842282=
835373A) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server (4.1.100.v200606180100--2PD88P8P=
AGAMAY) "TPTP Profile on Server"
org.eclipse.tptp.platform.report (4.1.100.v200606150100--2PD88P8PAGAMAY) =
"TPTP Charting Service"
org.eclipse.tptp.platform.report.birt (4.2.0.v200606131519--1G955G5G7A7E7=
M) "BIRT Reporting for TPTP Branding plugin"
org.eclipse.tptp.platform.samples (4.2.0.v200606131519--2PD88P8PAGAMAY) "=
TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui (4.1.100.v200606131519--1G955G5G=
7A7E7M) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.2.0.v200606131519--2PD88P8PAGAMAY) "TP=
TP Platform Trace"
org.eclipse.tptp.test (4.2.0.v200606131519--4hNDDhDhISIcIw) "TPTP Test"
org.eclipse.tptp.test.doc.user (4.2.0.v200606121835--0842282835373A) "Tes=
t Tools User Documentation"
org.eclipse.tptp.test.report.birt (4.2.0.v200606131519--2PD88P8PAGAMAY) "=
BIRT Test Reports for TPTP Branding Plugin"
org.eclipse.tptp.test.samples (4.1.100.v200606131519--0842282835373A) "TP=
TP Test Samples"
org.eclipse.tptp.test.tools (4.2.0.v200606131519--2PD88P8PAGAMAY) "TPTP T=
est Tools"
org.eclipse.tptp.trace (4.1.100.v200606131519--1G955G5G7A7E7M) "TPTP Trac=
e"
org.eclipse.tptp.trace.report.birt (4.2.0.v200606131519--2PD88P8PAGAMAY) =
"BIRT Trace Reports for TPTP Branding Plugin"
org.eclipse.ve (1.2.0.v20060530_RC2-0-a2N7MMl7) "Visual Editor"
org.eclipse.wst (1.5.0.v200606092300-U4T922yjOWsGK5Y) "Web Standard Tools=
(WST)"
org.eclipse.xsd (2.2.0.v200606271057) "XML Schema Infoset Model (XSD)"
org.mozilla.rhino (1.6.0.N20060628-1351) "Mozilla Rhino"
org.springframework.ide.eclipse (1.3.2) "Spring IDE"
org.w3c.sac (1.3.0.N20060628-1351) "W3C Sac"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060518_RC1) "Event Model" [Resolved]
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU=
4J)" [Active]
com.ibm.icu.source (3.4.4.1) "International Components for Unicode for Ja=
va (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.lowagie.itext (1.3.0.N20060628-1351) "Lowagie Itext" [Resolved]
com.nilswinkler.eclipse.accessmodifier (1.2.6) "Access Modifier Plug-in" =
[Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.3.0.v200606181221) "Apache Axis 1.3.0" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]=
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Resolv=
ed]
org.apache.commons_logging (1.0.4.v200606131651) "Apache commons logging =
Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.N20060628-1351) "Apache Commons Codec" [R=
esolved]
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse" =
[Resolved]
org.apache.jakarta_log4j (1.2.8.v200606131651) "Apache Jakarta log4j Plug=
-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200606181221) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]=
org.eclipse.ant.ui (3.2.0.v20060531) "Ant UI" [Resolved]
ing Tools" [Resolved]
org.eclipse.birt.chart (2.1.0.N20060628-1351) "BIRT Chart Framework" [Res=
olved]
sensitive Help" [Resolved]
org.eclipse.birt.chart.device.extension (2.1.0.N20060628-1351) "BIRT Char=
t Device Extension(s)" [Resolved]
org.eclipse.birt.chart.device.pdf (2.1.0.N20060628-1351) "BIRT Chart Devi=
ce PDF Extension" [Resolved]
org.eclipse.birt.chart.device.svg (2.1.0.N20060628-1351) "BIRT Chart Devi=
ce SVG Extension" [Resolved]
org.eclipse.birt.chart.device.swt (2.1.0.N20060628-1351) "BIRT Chart Devi=
ce SWT Extension" [Resolved]
org.eclipse.birt.chart.engine (2.1.0.N20060628-1351) "BIRT Chart Engine" =
[Resolved]
org.eclipse.birt.chart.engine.extension (2.1.0.N20060628-1351) "BIRT Char=
t Engine Extension" [Resolved]
org.eclipse.birt.chart.examples (2.1.0.N20060628-1351) "BIRT Chart Exampl=
es Plug-in" [Resolved]
org.eclipse.birt.chart.reportitem (2.1.0.N20060628-1351) "BIRT Chart-Repo=
rt Integration" [Resolved]
org.eclipse.birt.chart.reportitem.ui (2.1.0.N20060628-1351) "BIRT Chart-R=
eport UI Integration Plug-in" [Resolved]
" [Resolved]
org.eclipse.birt.chart.ui (2.1.0.N20060628-1351) "BIRT Chart Library UI P=
lug-in" [Resolved]
org.eclipse.birt.chart.ui.extension (2.1.0.N20060628-1351) "BIRT Chart UI=
org.eclipse.birt.core (2.1.0.N20060628-1351) "BIRT Core Package" [Resolve=
d]
org.eclipse.birt.core.ui (2.1.0.N20060628-1351) "BIRT Core UI" [Resolved]=
lp" [Resolved]
org.eclipse.birt.data (2.1.0.N20060628-1351) "BIRT Data Engine" [Resolved=
org.eclipse.birt.data.oda (2.0.2.N20060628-1351) "BIRT Open Data Access" =
[Resolved]
org.eclipse.birt.data.oda.adapter.dtp (2.0.0.N20060628-1351) "BIRT-DTP OD=
A Adapter Plug-in" [Resolved]
org.eclipse.birt.example (2.1.0.N20060628-1351) "BIRT Example" [Resolved]=
org.eclipse.birt.report.data.adapter (2.1.0.N20060628-1351) "BIRT Data Ad=
apter" [Resolved]
org.eclipse.birt.report.data.oda.jdbc (2.1.0.N20060628-1351) "BIRT ODA-JD=
BC Bridge Driver" [Resolved]
org.eclipse.birt.report.data.oda.jdbc.ui (2.1.0.N20060628-1351) "BIRT JDB=
C UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.sampledb (2.1.0.N20060628-1351) "BIRT Sa=
mple Database" [Resolved]
org.eclipse.birt.report.data.oda.sampledb.ui (2.1.0.N20060628-1351) "BIRT=
Sample Database UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.xml (2.1.0.N20060628-1351) "BIRT ODA-XML=
Driver" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.1.0.N20060628-1351) "BIRT XML =
org.eclipse.birt.report.debug.ui (2.1.0.N20060628-1351) "BIRT debug Plug-=
in" [Active]
gner" [Resolved]
org.eclipse.birt.report.designer.core (2.1.0.N20060628-1351) "BIRT Design=
er Core" [Resolved]
org.eclipse.birt.report.designer.example.samplereport (2.1.0.N20060628-13=
51) "BIRT Samplereport Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui (2.1.0.N20060628-1351) "BIRT Designer=
UI" [Resolved]
org.eclipse.birt.report.designer.ui.editors (2.1.0.N20060628-1351) "Rdt P=
lug-in" [Resolved]
org.eclipse.birt.report.designer.ui.editors.schematic (2.1.0.N20060628-13=
51) "BIRT Editors Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.ide (2.1.0.N20060628-1351) "BIRT Desi=
gner UI for IDE" [Resolved]
org.eclipse.birt.report.designer.ui.lib (2.1.0.N20060628-1351) "BIRT Desi=
gner UI for Library" [Resolved]
org.eclipse.birt.report.designer.ui.lib.explorer (2.1.0.N20060628-1351) "=
BIRT Library Explorer Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.preview (2.1.0.N20060628-1351) "BIRT =
Preview Plug-in" [Resolved]
org.eclipse.birt.report.engine (2.1.0.N20060628-1351) "BIRT Engine" [Reso=
lved]
org.eclipse.birt.report.engine.emitter.html (2.1.0.N20060628-1351) "BIRT =
HTML Emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.pdf (2.1.0.N20060628-1351) "BIRT P=
DF emitter" [Resolved]
org.eclipse.birt.report.engine.fonts (2.1.0.N20060628-1351) "BIRT Engine =
fonts" [Resolved]
org.eclipse.birt.report.model (2.1.0.N20060628-1351) "BIRT Model" [Resolv=
ed]
org.eclipse.birt.report.model.adapter.oda (2.1.0.N20060628-1351) "BIRT Mo=
del ODA Adapter" [Resolved]
me" [Resolved]
org.eclipse.birt.report.viewer (2.1.0.N20060628-1351) "BIRT Web Viewer" [=
Active]
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools" [R=
esolved]
org.eclipse.cdt.core (3.1.0.200606261600) "C/C++ Development Tools Core" =
[Resolved]
org.eclipse.cdt.core.win32 (3.1.0.200606261600) "C/C++ Development Tools =
Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.0.200606261600) "C/C++ Development Tools =
Debug Model" [Resolved]
org.eclipse.cdt.debug.mi.core (3.1.0.200606261600) "C/C++ Development Too=
ls GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.0.200606261600) "C/C++ Development Tools=
GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.0.200606261600) "C/C++ Development Tools De=
org.eclipse.cdt.doc.user (3.1.0.200606261600) "C/C++ Development User Gui=
de" [Resolved]
org.eclipse.cdt.launch (3.1.0.200606261600) "C/C++ Development Tools Laun=
ching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.0.200606261600) "C/C++ Standard make Build=
Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.0.200606261600) "C/C++ Standard make Build U=
I" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.0.200606261600) "C/C++ Managed B=
uilder Core" [Resolved]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.200606261600) "GNU Managed B=
uild Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.0.200606261600) "C/C++ Managed Bui=
lder UI" [Active]
org.eclipse.cdt.refactoring (3.1.0.200606261600) "C/C++ Refactoring" [Res=
olved]
org.eclipse.cdt.ui (3.1.0.200606261600) "C/C++ Development Tools UI" [Res=
olved]
org.eclipse.compare (3.2.0.v20060605) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism=
" [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language"=
[Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Activ=
e]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolv=
ed]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System=
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]=
org.eclipse.core.resources (3.2.0.v20060603) "Core Resource Management" [=
Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource=
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Managem=
ent Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime =
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorizat=
ion Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclips=
e Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved=
org.eclipse.datatools.connectivity (0.9.0.200606131) "Data Tools Platform=
Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.derby (0.9.0.200606131) "Eclipse Da=
ta Tools Platform Apache Derby Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.generic (0.9.0.200605231) "Eclipse =
Data Tools Platform Generic DB Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.generic.ui (0.9.0.200605101) "Eclip=
se Data Tools Platform Generic DB UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.derby (0.9.0.200605101) "=
Eclipse Data Tools Platform Apache Derby Database Definition" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (0.9.0.200605=
101) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Res=
olved]
org.eclipse.datatools.connectivity.derby (0.9.0.200606071) "Eclipse Data =
Tools Platform Derby Plug-in" [Resolved]
org.eclipse.datatools.connectivity.derby.ui (0.9.0.200606021) "Eclipse Da=
ta Tools Platform Apache Derby UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.finfo (0.9.0.200606161) "Eclipse Data =
Tools Platform Connectivity" [Resolved]
org.eclipse.datatools.connectivity.oda (3.0.1.200606081) "DTP Open Data A=
ccess" [Resolved]
org.eclipse.datatools.connectivity.oda.consumer (3.0.1.200606071) "DTP OD=
A Consumer Helper Component Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.design (3.0.0.200605231) "DTP ODA =
Design Session Model" [Resolved]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.1.200606021) "DTP O=
DA Designer UI Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.designer.finfo (0.9.0.200606161) "=
Eclipse Data Tools Platform Connectivity Open Data Access (ODA) Designer"=
[Resolved]
org.eclipse.datatools.connectivity.oda.finfo (0.9.0.200606161) "Eclipse D=
ata Tools Platform Connectivity Open Data Access (ODA)" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.0.200606081) "DTP OD=
A Flat File Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.0.200606081) "DTP=
ODA Flat File Designer" [Resolved]
org.eclipse.datatools.connectivity.oda.profile (3.0.0.200605101) "DTP ODA=
Connection Profile Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.core (0.9.0.200606071) "Eclipse Da=
ta Tools Platform SQM Core Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.core.ui (0.9.0.200606071) "Eclipse=
Data Tools Platform SQM UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.server.ui (0.9.0.200605101) "Eclip=
se Data Tools Platform Server UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui (0.9.0.200606131) "Data Tools Platf=
orm Connectivity UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui.dse (0.9.0.200606131) "Eclipse Data=
Tools Platform Data Source Explorer Plug-in" [Resolved]
org.eclipse.datatools.enablement.finfo (0.9.0.200606161) "Eclipse Data To=
ols Platform Enablement" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (0.9.0.2006=
05231) "DB2 UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (0.9.0.20060523=
1) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Res=
olved]
org.eclipse.datatools.enablement.ibm.db2.luw.profile (0.9.0.200606061) "E=
clipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (0.9.0.2006=
05231) "DB2 UDB Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (0.9.0.2006052=
31) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [R=
esolved]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (0.9.0.20060=
5231) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in=
" [Resolved]
org.eclipse.datatools.enablement.mysql (0.9.0.200605231) "Eclipse Data To=
ols Platform MySQL enablement plug-in" [Resolved]
org.eclipse.datatools.enablement.mysql.dbdefinition (0.9.0.200605231) "Ec=
lipse Data Tools Platform MySQL Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.mysql.profile (0.9.0.200606061) "Eclipse=
Data Tools Platform MySQL Plug-in" [Resolved]
org.eclipse.datatools.enablement.oracle.dbdefinition (0.9.0.200605231) "E=
clipse Data Tools Platform Oracle Database Definition Plug-in" [Resolved]=
org.eclipse.datatools.enablement.oracle.profile (0.9.0.200606061) "Eclips=
e Data Tools Platform Oracle Plug-in" [Resolved]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (0.9.0.200605231=
) "Eclipse Data Tools Platform Sybase Database Definition Plug-in" [Resol=
ved]
org.eclipse.datatools.enablement.sybase.ase.profile (0.9.0.200606061) "Ec=
lipse Data Tools Platform Sybase ASE Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (0.9.0.200605101) "Eclipse D=
ata Tools Platform DBDefinition Model" [Resolved]
org.eclipse.datatools.modelbase.derby (0.9.0.200605101) "Derby Plug-in" [=
Resolved]
org.eclipse.datatools.modelbase.edit (0.9.0.200605101) "Eclipse Data Tool=
s Platform SQLModel Edit Plug-in" [Resolved]
org.eclipse.datatools.modelbase.finfo (0.9.0.200606161) "Eclipse Data Too=
ls Platform Model Base" [Resolved]
org.eclipse.datatools.modelbase.sql (0.9.0.200605101) "Eclipse Data Tools=
Platform SQLModel Plug-in" [Resolved]
org.eclipse.datatools.modelbase.sql.query (0.9.0.200605101) "Eclipse Data=
Tools Platform SQL Query Model Plugin" [Resolved]
org.eclipse.datatools.modelbase.sql.xml.query (0.9.0.200605101) "Eclipse =
Data Tools Platform SQL XML Query Model Plugin" [Resolved]
org.eclipse.datatools.sqltools.common.ui (0.9.0.200605101) "Eclipse Data =
Tools Platform SQL Tools Common UI Plug-in" [Resolved]
org.eclipse.datatools.sqltools.db.derby (0.9.0.200605101) "Eclipse Data T=
ools Platform Derby SQL Tools Plug-in" [Resolved]
org.eclipse.datatools.sqltools.db.generic (0.9.0.200605101) "Eclipse Data=
Tools Platform SQL Tools Generic Database Plug-in" [Resolved]
org.eclipse.datatools.sqltools.debugger.core (0.9.0.200605101) "Eclipse D=
ata Tools Platform SQL Debugger Framework" [Resolved]
org.eclipse.datatools.sqltools.editor.core (0.9.0.200605101) "Eclipse Dat=
a Tools Platform SQL Editor Core Plug-in" [Resolved]
org.eclipse.datatools.sqltools.finfo (0.9.0.200606161) "Eclipse Data Tool=
s Platform SQL Development Tools" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql (0.9.0.200605101) "Eclipse Dat=
a Tools Platform SQL Parser Plugin" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.lexer (0.9.0.200605101) "Eclip=
se Data Tools Platform Lexer Plug-in" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.query (0.9.0.200605101) "Eclip=
se Data Tools Platform SQL Query Parser Plugin" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (0.9.0.200605101) "E=
clipse Data Tools Platform SQL XML Query Parser Plug-in" [Resolved]
org.eclipse.datatools.sqltools.plan (0.9.0.200605101) "Eclipse Data Tools=
Platform SQL Execution Plan View Plug-in" [Resolved]
org.eclipse.datatools.sqltools.result (0.9.0.200605101) "Eclipse Data Too=
ls Platform SQL Results View Plug-in" [Resolved]
org.eclipse.datatools.sqltools.routineeditor (0.9.0.200605121) "Eclipse D=
ata Tools Platform SQL Tools Routine Editor Plug-in" [Resolved]
org.eclipse.datatools.sqltools.sql (0.9.0.200605101) "Eclipse Data Tools =
Platform SQL Core Plug-in" [Resolved]
org.eclipse.datatools.sqltools.sqleditor (0.9.0.200605121) "Eclipse Data =
Tools Platform SQL Editor" [Resolved]
org.eclipse.datatools.sqltools.sqlscrapbook (0.9.0.200605101) "Eclipse Da=
ta Tools Platform Sqlscrapbook Plug-in" [Resolved]
org.eclipse.debug.core (3.2.0.v20060605) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20060605) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.emf (2.2.0.v200606271057) "Eclipse Modeling Framework (EMF)" =
[Resolved]
org.eclipse.emf.ant (2.2.0.v200606271057) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.0.v200606271057) "EMF Template Code Generato=
r" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.0.v200606271057) "EMF Ecore Code Gener=
ation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0.v200606271057) "EMF Ecore Code Ge=
neration UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200606271057) "EMF Template Code Gener=
ator UI" [Resolved]
org.eclipse.emf.common (2.2.0.v200606271057) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.0.v200606271057) "EMF Common UI" [Resolved=
org.eclipse.emf.commonj.sdo (2.1.0.v200606271057) "CommonJ SDO" [Resolved=
org.eclipse.emf.converter (2.2.0.v200606271057) "EMF Model Convert Suppor=
t" [Resolved]
org.eclipse.emf.ecore (2.2.0.v200606271057) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200606271057) "EMF Ecore Change Mode=
l" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0.v200606271057) "EMF Ecore Change=
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200606271057) "EMF Ecore Edit Support"=
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200606271057) "Sample Ecore Editor" =
[Resolved]
(SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0.v200606271057) "EMF Service Data Ob=
jects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0.v200606271057) "EMF Service Data =
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0.v200606271057) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.0.v200606271057) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200606271057) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200606271057) "EMF Model Export Support"=
[Resolved]
org.eclipse.emf.importer (2.2.0.v200606271057) "EMF Model Import Support"=
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200606271057) "EMF Ecore Importer"=
[Resolved]
org.eclipse.emf.importer.java (2.2.0.v200606271057) "EMF Annotated Java I=
mporter" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200606271057) "EMF Rose Importer" [=
Resolved]
org.eclipse.emf.mapping (2.2.0.v200606271057) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200606271057) "Ecore to Ecore=
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200606271057) "Ecore t=
o Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200606271057) "Ecore to XML Map=
ping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200606271057) "Ecore to XML =
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.0.v200606271057) "EMF Mapping UI" [Resolv=
ed]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200606271057) "XSD to Ecore Map=
ping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200606271057) "XSD to Ec=
hnology OCL Interpreter" [Resolved]
echnology Query Framework" [Resolved]
rk Technology Query OCL" [Resolved]
work Technology Transaction Core" [Resolved]
org.eclipse.emf.transaction.ui (1.0.0.v200606261303) "Eclipse Modeling Fr=
amework Technology Transaction UI" [Resolved]
ork Technology Model Validation Core" [Resolved]
amework Technology Validation Support for OCL" [Resolved]
org.eclipse.emf.validation.ui (1.0.0.v200606261144) "Eclipse Modeling Fra=
mework Technology Validation UI" [Resolved]
org.eclipse.emf.validation.ui.ide (1.0.0.v200606261144) "Eclipse Modeling=
Framework Technology Validation UI IDE" [Resolved]
rk Technology Workbench Core" [Resolved]
org.eclipse.emf.workspace.ui (1.0.0.v200606261303) "Eclipse Modeling Fram=
ework Technology Workbench UI" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime" [Ac=
tive]
org.eclipse.equinox.device (1.0.0.v20060601a) "Device Access Service" [Re=
solved]
org.eclipse.equinox.event (1.0.0.v20060601a) "Event Admin" [Resolved]
org.eclipse.equinox.http (1.0.0.v20060601a) "HTTP Service" [Resolved]
org.eclipse.equinox.log (1.0.0.v20060601a) "Log Service" [Resolved]
org.eclipse.equinox.metatype (1.0.0.v20060601a) "Meta Type" [Resolved]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences Me=
chanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Suppor=
t" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved=
org.eclipse.equinox.useradmin (1.0.0.v20060601a) "User Admin Service" [Re=
solved]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved=
org.eclipse.gmf (1.0.0.v20060627-1200) "Graphical Modeling Framework" [Re=
solved]
org.eclipse.gmf.bridge (1.0.0.v20060627-1200) "GMF Models Bridging Plug-i=
n" [Resolved]
org.eclipse.gmf.bridge.ui (1.0.0.v20060627-1200) "GMF Tooling UI" [Resolv=
ed]
org.eclipse.gmf.bridge.ui.dashboard (1.0.0.v20060627-1200) "GMF Dashboard=
" [Resolved]
org.eclipse.gmf.codegen (1.0.0.v20060627-1200) "GMF GenModel and Code Gen=
eration" [Resolved]
org.eclipse.gmf.codegen.edit (1.0.0.v20060627-1200) "GMF GenModel Edit Su=
pport" [Resolved]
org.eclipse.gmf.codegen.ui (1.0.0.v20060627-1200) "GMF Code Generation UI=
" [Resolved]
org.eclipse.gmf.common (1.0.0.v20060627-1200) "GMF Tooling Commons Plug-i=
n" [Resolved]
org.eclipse.gmf.doc.ui (1.0.0.v20060627-1200) "GMF Documentation Cheatshe=
ets" [Resolved]
org.eclipse.gmf.ecore.editor (1.0.0.v20060627-1200) "ECore Sample Diagram=
Plugin" [Resolved]
org.eclipse.gmf.graphdef (1.0.0.v20060627-1200) "GMF Graphical Definition=
" [Resolved]
org.eclipse.gmf.graphdef.codegen (1.0.0.v20060627-1200) "Graphical Defini=
tion Code Generator" [Resolved]
org.eclipse.gmf.graphdef.codegen.ui (1.0.0.v20060627-1200) "Graphical Def=
inition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (1.0.0.v20060627-1200) "GMFGraph Edit Suppo=
rt" [Resolved]
org.eclipse.gmf.map (1.0.0.v20060627-1200) "GMF Mapping Model" [Resolved]=
org.eclipse.gmf.map.edit (1.0.0.v20060627-1200) "GMF Mapping Edit Support=
" [Resolved]
org.eclipse.gmf.runtime.common.core (1.0.0.v20060627-1200) "GMF Common Co=
re" [Resolved]
org.eclipse.gmf.runtime.common.ui (1.0.0.v20060627-1200) "GMF Common UI" =
[Resolved]
org.eclipse.gmf.runtime.common.ui.action (1.0.0.v20060627-1200) "GMF Comm=
on UI Action" [Resolved]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.0.v20060627-1200) "GMF =
Common UI Action IDE" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing (1.0.0.v20060627-1200) "GMF Pr=
inting" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.0.v20060627-1200) "=
GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.0.v20060627-1200) "GMF Co=
mmon UI Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.action (1.0.0.v20060627-1200) =
"GMF Common UI Action Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.0.v20060627-1200) "GM=
F Common UI DND Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.0.v20060627-1200)=
"GMF Common UI DND IDE Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.properties (1.0.0.v20060627-12=
00) "GMF Common UI Properties Service Framework" [Resolved]
org.eclipse.gmf.runtime.diagram.core (1.0.0.v20060627-1200) "GMF Diagram =
Core" [Resolved]
org.eclipse.gmf.runtime.diagram.ui (1.0.0.v20060627-1200) "GMF Diagram UI=
" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.0.v20060627-1200) "GMF Di=
agram Actions" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.0.v20060627-1200) "GMF Diagra=
m Browse" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.0.v20060627-1200) "GMF =
Geometric Shapes" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.0.v20060627-1200) "GMF D=
iagram Printing" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.0.v20060627-1200)=
"GMF Diagram UI Printing Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.0.v20060627-1200) "GMF=
Diagram UI Properties" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.0.v20060627-1200) "GMF =
Diagram Providers" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.0.v20060627-1200) "=
GMF Diagram Providers IDE" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.0.v20060627-1200) "GMF Dia=
gram UI Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.0.v20060627-1200=
) "GMF Diagram UI Resources Editor Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide (1.0.0.v20060627-=
1200) "GMF IDE Editor" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui (1.0.0.v20060627-1200) "GMF Draw2d Addi=
tions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.0.v20060627-1200) "GMF Draw=
2d Image Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.0.v20060627-1200) "GMF =
Draw2d Image AWT based Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.0.v20060627-1200) "GMF EM=
F Clipboard Support" [Resolved]
org.eclipse.gmf.runtime.emf.commands.core (1.0.0.v20060627-1200) "GMF Com=
mands" [Resolved]
org.eclipse.gmf.runtime.emf.core (1.0.0.v20060627-1200) "GMF Modeling Ser=
vice Layer" [Resolved]
org.eclipse.gmf.runtime.emf.type.core (1.0.0.v20060627-1200) "GMF EMF Typ=
e Core" [Resolved]
org.eclipse.gmf.runtime.emf.type.ui (1.0.0.v20060627-1200) "GMF EMF Type =
UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui (1.0.0.v20060627-1200) "GMF MSL UI" [Resol=
ved]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.0.v20060627-1200) "GMF EMF=
UI Properties Providers" [Resolved]
org.eclipse.gmf.runtime.gef.ui (1.0.0.v20060627-1200) "GMF GEF Additions"=
[Resolved]
org.eclipse.gmf.runtime.notation (1.0.0.v20060627-1200) "GMF Notation Mod=
el Support" [Resolved]
org.eclipse.gmf.runtime.notation.edit (1.0.0.v20060627-1200) "GMF Notatio=
n Edit Support" [Resolved]
org.eclipse.gmf.runtime.notation.providers (1.0.0.v20060627-1200) "GMF No=
tation Metamodel" [Resolved]
org.eclipse.gmf.sdk (1.0.0.v20060627-1200) "Graphical Modeling Framework =
SDK" [Resolved]
org.eclipse.gmf.tooldef (1.0.0.v20060627-1200) "GMF Tooling Model" [Resol=
ved]
org.eclipse.gmf.tooldef.edit (1.0.0.v20060627-1200) "GMF Tooling Edit Sup=
port" [Resolved]
org.eclipse.gmf.validate (1.0.0.v20060627-1200) "GMF Validation" [Resolve=
d]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" =
[Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]=
org.eclipse.hyades.analysis.engine (4.2.0.v200606131519) "Symptom Model" =
[Resolved]
org.eclipse.hyades.execution (4.2.0.v200606131519) "TPTP Platform Executi=
on Plug-In" [Active]
org.eclipse.hyades.execution.correlation (4.1.100.v200606131519) "Hyades =
Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.100.v200606131519) "Hyades Execut=
ion Trace" [Resolved]
org.eclipse.hyades.execution.win32.x86 (4.2.0.v200606131519) "TPTP Platfo=
rm Execution Plug-In" [Resolved]
org.eclipse.hyades.logging.adapter (4.2.0.v200606170100) "TPTP Monitoring=
Project Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.2.0.v200606131519) "Generic Adap=
ter UI" [Resolved]
org.eclipse.hyades.logging.core (4.2.0.v200606131519) "Hyades Logging Age=
nt, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) "Sample fo=
r Hyades Logging Agent, Common Base Events and Logging Facility Support" =
[Resolved]
org.eclipse.hyades.logging.parsers (4.2.0.v200606190100) "TPTP Monitoring=
Project Log File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.2.0.v200606131519) "Perfmon StatCon Module"=
[Resolved]
org.eclipse.hyades.probekit (4.2.0.v200606131519) "Hyades Probekit" [Reso=
lved]
org.eclipse.hyades.probekit.doc.user (4.1.100.v200606131519) "Probekit Us=
er Documentation" [Resolved]
org.eclipse.hyades.probekit.ui (4.1.100.v200606131519) "Probe Editor" [Re=
solved]
org.eclipse.hyades.resources.database (4.1.100.v200606190100) "Hyades Cor=
e Resource Extensions" [Resolved]
org.eclipse.hyades.sdb (4.1.100.v200606140100) "Symptom Database tool" [R=
esolved]
org.eclipse.hyades.statistical.ui (4.2.0.v200606131519) "Statistical UI" =
[Active]
org.eclipse.hyades.test.core (4.2.0.v200606131519) "TPTP Test Core Plug-I=
n" [Resolved]
org.eclipse.hyades.test.doc.user (4.1.100.v200606131519) "Test Tools User=
org.eclipse.hyades.test.tools.core (4.2.0.v200606131519) "TPTP Test Tools=
Core Plug-In" [Resolved]
org.eclipse.hyades.test.tools.ui (4.2.0.v200606131519) "TPTP Test Tools U=
I Plug-In" [Resolved]
org.eclipse.hyades.test.ui (4.2.0.v200606131519) "TPTP Test UI Plug-In" [=
Resolved]
org.eclipse.hyades.test.ui.extensions (4.2.0.v200606131519) "TPTP Test UI=
Extension Plug-In" [Resolved]
org.eclipse.hyades.trace.sample (4.1.100.v200606131519) "Samples for the =
TPTP Monitoring Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.2.0.v200606131519) "Hyades Trace Core UI" =
[Active]
org.eclipse.hyades.trace.views (4.1.100.v200606131519) "Hyades Trace View=
s Plugin" [Resolved]
org.eclipse.hyades.ui (4.1.100.v200606131519) "Hyades UI" [Active]
org.eclipse.jdt (3.2.0.v20060605-1400) "Eclipse Java Development Tools" [=
Resolved]
org.eclipse.jdt.apt.core (3.2.0.v20060602-1740) "Java Annotation Processi=
ng Core" [Installed]
org.eclipse.jdt.apt.ui (3.2.0.v20060602-1740) "Java Annotation Processing=
UI" [Installed]
org.eclipse.jdt.core (3.2.0.v_671) "Java Development Tools Core" [Active]=
org.eclipse.jdt.core.manipulation (1.0.0.v20060605-1400) "Java Code Manip=
ulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060605) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.0.v20060605) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.0.v20060605-1400) "Eclipse JDT Plug-in Devel=
oper Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development=
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060605-1400) "Java Development Tools JUni=
t support" [Active]
org.eclipse.jdt.junit.runtime (3.2.0.v20060605-1400) "Java Development To=
ols JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.0.v20060605-1400) "Java Development T=
ools JUnit4 runtime support" [Installed]
org.eclipse.jdt.launching (3.2.0.v20060605) "Java Development Tools Launc=
hing Support" [Active]
evelopment Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060605-1400) "Java Development Tools UI" [Ac=
tive]
org.eclipse.jem (1.2.0.v20060530_RC2) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.0.v20060530_RC2) "Java EMF Model BeanInfo (=
Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060530_RC2) "Java EMF Model Proxy Support=
" [Resolved]
org.eclipse.jem.ui (1.2.0.v20060518_RC1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.0.v20060530_RC2) "Java EMF Model Utilities" [Ac=
tive]
org.eclipse.jem.workbench (1.2.0.v20060530_RC2) "Java EMF Model Workbench=
Support" [Active]
org.eclipse.jface (3.2.0.I20060605-1400) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"=
[Resolved]
org.eclipse.jface.text (3.2.0.v20060605-1400) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)" [Resolv=
ed]
org.eclipse.jst.common.annotations.controller (1.1.0.v200606130315) "Anno=
tation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.0.v200606130315) "Annotation=
org.eclipse.jst.common.annotations.ui (1.1.0.v200606130315) "Annotations =
org.eclipse.jst.common.frameworks (1.1.0.v200606130315) "Integration Plug=
-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200606130315) "Project =
Facet Core (Java Support)" [Active]
org.eclipse.jst.ejb.doc.user (1.0.201.v200605291441) "EJB docs" [Resolved=
org.eclipse.jst.ejb.ui (1.1.0.v200606130315) "WTP EJB UI Plug-in" [Resolv=
ed]
org.eclipse.jst.j2ee (1.1.0.v200606222043) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.0.v200606130315) "J2EE Core Component" [Ac=
tive]
org.eclipse.jst.j2ee.doc.user (1.0.201.v200605152316) "J2EE tools documen=
tation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.0.v200606152049) "EJB component Plug-in" [R=
esolved]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.0.v200606212143) "EJB Anno=
tation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.0.v200606130315) "EJB E=
mitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.0.v200606212143) "EJB Annota=
tions Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.0.v200606130315) "Xdocl=
et Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.201.v200605040115) "J2EE tools infopops=
" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.0.v200606152049) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.0.v200606130315) "WTP JCA UI Plug-in" [R=
esolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.0.v200606130315) "J2EE Extensions =
to Common Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (1.1.0.v200606130315) "WTP J2EE UI Plug-in" [Acti=
ve]
org.eclipse.jst.j2ee.web (1.1.0.v200606152049) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (1.1.0.v200606130315) "Web Service Plug-i=
n" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.0.v200606130315) "WTP Webservice =
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.0.v200606130315) "XDocletRuntim=
org.eclipse.jst.jsp.core (1.1.0.v200606191945) "Structured Source JSP Mod=
el" [Active]
org.eclipse.jst.jsp.ui (1.1.0.v200606191945) "SSE JSP Source Editor" [Res=
olved]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools infopops"=
[Resolved]
org.eclipse.jst.server.core (1.0.102.v200606130315) "Java Server Support"=
[Active]
org.eclipse.jst.server.generic.core (1.0.100.v200606130315) "Generic Serv=
org.eclipse.jst.server.generic.jboss (1.5.0.v200606130315) "JBoss Generic=
server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS Generic=
Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J v1=
0.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200606130315) "Generic Server=
Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.0.v200606130315) "Weblogic g=
eneric server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.0.v200606130315) "Installable ser=
vers" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.102.v200606130315) "Apache Tomcat=
Support" [Active]
org.eclipse.jst.server.tomcat.ui (1.0.102.v200606130315) "Apache Tomcat U=
org.eclipse.jst.server.ui (1.0.102.v200606130315) "Java Server UI Support=
&qu
Re: J2EE Module Dependencies - Project Migration WTP 1.0 to WTP 1.5 (Calisto) [message #174313 is a reply to message #173628] Thu, 13 July 2006 05:47 Go to previous message
Sadly enough the whole deployment infrastructure is a trainwreck. The
bug you mention is indeed caused by a problem in the project's metadata
wrt the WTP.
I have had the same problem and fixed it as follows:
- I edited all .project files by hand and removed all references to WTP
functionality; I only left the standard builders and features.
- I removed in all projects all of the files in .settings that had to do
with wtp
[zip your work!]
- I created a new, temporary empty Dynamic Web Project so that I can see
what Eclipse needs to make a project a Web project.
- In the main web project (which according to eclipse is now no longer a
Dynamic Web Project) I copy files and parts of the files from the
empty project and edit them to represent the original.
After this Eclipse should see the thing as a normal Web project and you
can add dependencies. Pure horror.
I would not hold my breath though: the whole publishing and deployment
framework is one big bug and hardly works at all.
Frits
> 1.0.1.
> the problem.
> - with no success!
> exists either.
> Thanks
> Martin
Previous Topic:IWAB0398E - ClassNotFound during Webservices generation
Next Topic:whats is wrong with thejsp editor???
Current Time: Sun Jul 27 11:14:24 EDT 2025
Powered by FUDForum. Page generated in 0.03355 seconds
