Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » Problem with SOAP Web Services
Problem with SOAP Web Services [message #1743086] Sun, 11 September 2016 20:06
Hi all!
That's my first post and i write here beacuase i have a problem with Eclipse.
I am new to develope Web Service with Java and i occured to an issues with Eclipse.
I have the following WSDL file of a web service "www.webservicex.net/globalweather.asmx?wsdl"
I have read a lot about creating Web Services from WSDL, so i followed a guide on Internet for Eclipse to create a Web Service Client from WSDL. i got a lot of error and i dont know why, beacause with NetBeans it works.
Here's the code:
import java.io.IOException;
import java.io.PrintWriter;
import java.io.*;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import NET.webserviceX.*;
import NET.webserviceX.www.*;
 * Servlet implementation class CitiesServletClient
public class CitiesServletClient extends HttpServlet {
	private static final long serialVersionUID = 1L;
	private GlobalWeather service;
	private String parametro = "Italy";
     * @see HttpServlet#HttpServlet()
    public CitiesServletClient() {
        super();
        // TODO Auto-generated constructor stub
    protected void processRequest(HttpServletRequest request, HttpServletResponse response)
            throws ServletException, IOException {
        response.setContentType("text/html;charset=UTF-8");
        try (PrintWriter out = response.getWriter()) {
            /* TODO output your page here. You may use following sample code. */
            //Process result
            String listaCittà = getCitiesByCountry(request.getParameter("TextArea1"));
            out.println("<p>" + listaCittà + " Prova</p>");
    private String getCitiesByCountry(java.lang.String countryName) {
        // Note that the injected javax.xml.ws.Service reference as well as port objects are not thread safe.
        // If the calling of port operations may lead to race condition some synchronization is required.
        NET.webserviceX.www.GlobalWeatherSoap port = service.getGlobalWeatherSoap();
        return port.getCitiesByCountry(parametro);
	 * @see HttpServlet#doGet(HttpServletRequest request, HttpServletResponse response)
	protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
		processRequest(request, response);
		response.getWriter().append("Served at: ").append(request.getContextPath());
	 * @see HttpServlet#doPost(HttpServletRequest request, HttpServletResponse response)
	protected void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
		// TODO Auto-generated method stub
		doGet(request, response);
Thank you all anticipately for helps!
Previous Topic:[Eclipse Neon] Javascript syntax coloring problem with parameter variables
Next Topic:Concurrency in Eclipse with Slings plugg-in
Current Time: Sat Jul 19 20:52:51 EDT 2025
Powered by FUDForum. Page generated in 0.23579 seconds
