Home » Eclipse Projects » Eclipse Platform » Eclipse Crashing very Frequently -With oomph exception in stack trace(Problem in Mars)
icon4.gif  Eclipse Crashing very Frequently -With oomph exception in stack trace [message #1743060] Sat, 10 September 2016 01:45 Go to next message
Eclipse fails very frquently, the stack trace shows this..
org.eclipse.oomph.util.IOExceptionWithCause: Forbidden
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:266)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.handleArchiveRedirection(SetupCoreUtil.java:356)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.configureResourceSet(SetupCoreUtil.java:342)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.createResourceSet(SetupCoreUtil.java:124)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:369)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.access$3(SetupUIPlugin.java:310)
at org.eclipse.oomph.setup.ui.SetupUIPlugin$1$1.run(SetupUIPlugin.java:210)
Caused by: org.eclipse.ecf.filetransfer.IncomingFileTransferException: Forbidden
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:655)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:885)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:201)
... 8 more
at org.eclipse.oomph.setup.internal.core.SetupContext.associate(SetupContext.java:354)
at org.eclipse.oomph.setup.internal.core.SetupContext.createSelf(SetupContext.java:235)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:416)
... 10 more
[Updated on: Sat, 10 September 2016 02:14] by Moderator
Re: Eclipse Crashing very Frequently -With oomph exception in stack trace [message #1743075 is a reply to message #1743060] Sun, 11 September 2016 06:22 Go to previous message
That logic should be accessing http://www.eclipse.org/setups/setups.zip which in your case appears to be forbidden. I'm not sure why. Can you access that file from a browser? Are you behind firewall proxy?
This problem is logged as a warning, not an error, given that networks and websites can occasionally go down or fail. But you say Eclipse crashes. You literally mean Eclipse just terminates and you have to restart?
Previous Topic:debugging xhtml
Next Topic:Custom icons in help system
Current Time: Mon Jul 21 08:22:20 EDT 2025
Powered by FUDForum. Page generated in 0.04106 seconds
