Home » Eclipse Projects » OM2M » What is ASN-CSE and ADN-CSE?
What is ASN-CSE and ADN-CSE? [message #1742851] Thu, 08 September 2016 04:45 Go to next message
Hi all,
When I read some documentation of oneM2M standard, I found that beside IN-CSE and MN-CSE, there are other CSE called ASN-CSE and ADN-CSE.
The ADN-CSE I found in the Technical Report TR-0025 V1.0.0 : Application Developer Guide of oneM2M. Figure below:
index.php/fa/26995/0/
index.php/fa/26996/0/
And the ASN-CSE I found inside of the OM2M implementation.
Can anyone explain me what are they? and what are they used for?
Thank you in advanced!
Son
Re: What is ASN-CSE and ADN-CSE? [message #1742989 is a reply to message #1742851] Fri, 09 September 2016 03:21 Go to previous messageGo to next message
Typically the difference between ASN/ADN and MN nodes consists in the possibility to register another node to the node. MN are intermediary nodes and nodes such as ASN and ADN can register to this kind of nodes. Moreover, you cannot register a node to an ASN or an ADN, they are final nodes.
The difference between ASN and ADN is that ASN hosts a CSE and ADN does not. ADN is mainly composed of an AE registered to another CSE on another node.
You have complete information available in the TS-0001 with details for each type of node, how they are connected, etc. (section 6.1 for the different kind of nodes). http://onem2m.org/technical/published-documents
Guillaume
[Updated on: Fri, 09 September 2016 03:21] by Moderator
Re: What is ASN-CSE and ADN-CSE? [message #1743002 is a reply to message #1742989] Fri, 09 September 2016 06:10 Go to previous message
thank you Guillaume!
Son
Previous Topic:where is the OM2M-libs.rar
Next Topic:Does end-user applications can interact directly with MN-CSE ?
Current Time: Tue Jul 22 09:24:51 EDT 2025
Powered by FUDForum. Page generated in 0.07588 seconds
