Home » Eclipse Projects » Kura » Need Help: Error when deploy Greenhouse sample on RPi3b
Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742613] Tue, 06 September 2016 03:34 Go to next message
I follow http://iot.eclipse.org/java/tutorial/ to deploy greenhouse sample on my RaspberryPi 3 model B, with Kura2.0.0 and jdk8.
After the package installed, I cannot see 'greenhouse publisher' under 'services' , I examined kura log and see below output:
[code]
java.io.IOException: Error writing to /dev/i2c-1 at address 0x40 to address 0x3. Got -20001.
it seems like some wrong with i2c write. I had setup i2c according to this instruction learn.adafruit.com/adafruits-raspberry-pi-lesson-4-gpio-setup/configuring-i2c, and command ' i2cdetect -y 1' output:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
so any hint about what'a wrong? thanks a lot in advance.
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742687 is a reply to message #1742613] Tue, 06 September 2016 11:54 Go to previous messageGo to next message
In the past I've found this resource to be helpful: https://www.raspberrypi.org/forums/viewtopic.php?p=675658#p675658
(you can jump directly to "Fixing the problem" Smile)
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742729 is a reply to message #1742687] Tue, 06 September 2016 20:40 Go to previous messageGo to next message
thanks for your reply, however the greenhouse publisher just NOT appear under 'services' menu, though the mqtt message publish ok, I can read the temprature from iot.eclipse.org sandbox
I read the kura log which gives a warning:
2016-09-07 09:29:10,449 [Component Resolve Thread (Bundle 6)] WARN o.e.k.c.c.ConfigurationServiceImpl - Either kura.service.pid null or service.pid org.eclipse.iot.greenhouse.publisher.GreenhousePublisher are null
I don't know what's wrong. I attached kura.log and kura-console.log (chopped)
  • Attachment: kura.log
    (Size: 53.00KB, Downloaded 202 times)
  • Attachment: kura-console.log
    (Size: 1.08KB, Downloaded 383 times)
[Updated on: Tue, 06 September 2016 21:58] by Moderator
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742820 is a reply to message #1742729] Wed, 07 September 2016 17:48 Go to previous messageGo to next message
I can confirm there is a bug somewhere, I am checking into it. In the short term, you can get the Greenhouse service to show in the UI by logging into the OSGi console, stopping the bundle (org.eclipse.iot.greenhouse.publisher_0.1.0.SNAPSHOT), then starting it again. If you refresh your browser, the service should now show. Unfortunately, this will not persist a reboot. I will post back when I find the root issue.
--Dave
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742821 is a reply to message #1742820] Wed, 07 September 2016 17:58 Go to previous messageGo to next message
It also appears to work if you uninstall the DP and re-install it. This persists across reboots. Again, when we root cause the issue I will post back here.
--Dave
[Updated on: Wed, 07 September 2016 18:12] by Moderator
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742916 is a reply to message #1742821] Thu, 08 September 2016 10:57 Go to previous messageGo to next message
Hello David,
indeed after I stop and re-start bundle it appears under 'services' menu.
Another issue, the toggle on light doesn't take effect at all, so I download greenhouse source code and found missing read light code in place below (I added the missing code) in 'Pi4JGreenhouseSensorService.java'
			_handle = _scheduledThreadPoolExecutor.scheduleAtFixedRate(
					new Runnable() {
						public void run() {
							try {
								float newTemperature = readTemperature();
								if (Math.abs(_temperatureRef - newTemperature) > .1f) {
									notifyListeners("temperature",
											newTemperature);
									_temperatureRef = newTemperature;
								[b]boolean newLightState = readLightState();
								if(newLightState != _lightState) {
									notifyListeners("light", newLightState);
									_lightState = newLightState;
								}[/b]
							} catch (IOException e) {
								e.printStackTrace();
					}, 0, 5000, TimeUnit.MILLISECONDS);
after deploy to RPi, the same issue there, read light state is always returning true, however the LED is off, and I checked the pin state with 'gpio readall', the pin state if off indeed.
I don't know what's wrong there.
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1742968 is a reply to message #1742916] Thu, 08 September 2016 19:58 Go to previous messageGo to next message
well, I see, on periodically greenhouse just sense temperature but not light state.
however act on light state just taking no effect, with 'gpio readall' the pin state is always 0, Pi4JGreenhouseSensorService.readLightState always return true.
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1743015 is a reply to message #1742968] Fri, 09 September 2016 09:22 Go to previous messageGo to next message
Finally I've found the reason, the pi4j libs embedded in bundle 'org.eclipse.iot.greenhouse.sensors.raspberrypi' is not compatible with RPi3b.
So, I replaced the pi4j with the most recent version(1.1), the LED light is working properly at last!
Re: Need Help: Error when deploy Greenhouse sample on RPi3b [message #1780853 is a reply to message #1743015] Mon, 29 January 2018 04:03 Go to previous message
Thank you very much , I have solved my problem!
Previous Topic:I2c bus
Next Topic:Permanent deployment of plugins to kura
Current Time: Sun Jul 20 22:02:02 EDT 2025
Powered by FUDForum. Page generated in 0.29397 seconds
