Home » Modeling » TMF (Xtext) » Confusion about terminals(In what case do terminals become unreachable)
icon5.gif  Confusion about terminals [message #1742730] Tue, 06 September 2016 20:46 Go to next message
Have a look at the grammar below:
SysDefTree:
	(roots+=RootNode)+
RootNode:
		(properties+=Property)+
Property:
	name=ID '=' values+=PropertyValue ';'
PropertyValue:
	NumberValue | ByteValue | StringValue
NumberValue:
	'<' value=Number '>'
ByteValue hidden():
	'[' WS* ((bytes+=HexDigit) (bytes+=HexDigit) WS*)+ ']'
StringValue:
	value=STRING
HexDigit:
	('0'|'1'|'2'|'3'|'4'|'5'|'6'|'7'|'8'|'9'|'a'|'A'|'b'|'B'|'c'|'C'|'d'|'D'|'e'|'E'|'f'|'F')
Number:
	SINGLE_DIGIT | INT | HEX | HEX_INT_PREFIX | HEX_NO_PREFIX
// ======================== Terminals =========================================
terminal SINGLE_DIGIT:
	('0'..'9')
terminal HEX_INT_PREFIX:
	SINGLE_DIGIT+ ('a'..'f' | 'A'..'F') (SINGLE_DIGIT | 'a'..'f' | 'A'..'F' | '_')*
terminal HEX_NO_PREFIX:
terminal HEX:
	('0x' | '0X') (SINGLE_DIGIT | 'a'..'f' | 'A'..'F' | '_')+
terminal INT returns ecore::EInt:
	SINGLE_DIGIT+
terminal ID:
	 (SINGLE_DIGIT | 'a'..'z' | 'A'..'Z' | '_' | '#') ('a'..'z' | 'A'..'Z' | '_' | '-' | SINGLE_DIGIT | '#' | ',')*
terminal STRING	:
			'"' ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|'"') )* '"' |
			"'" ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|"'") )* "'"
terminal ML_COMMENT	: '/*' -> '*/';
terminal WS			: (' '|'\t'|'\r'|'\n')+;
When I run the Xtext generator I get the following error:
The following token definitions can never be matched because prior tokens match the same input: RULE_SINGLE_DIGIT
If I remove the rule ByteValue, the error goes away. Why is that?
I understand that I can play around with terminals and Number rule as well to get rid of the error but that results in an undesirable grammar. Moreover, the terminals are somewhat complex but they serve the intended purpose (won't mind suggestions for improvements there).
Re: Confusion about terminals [message #1742738 is a reply to message #1742730] Wed, 07 September 2016 02:07 Go to previous messageGo to next message
Keywords become terminal rules as well. Thus '1' will be matched as keyword in the hex digit terminal rule which is called by the byte value rule only.
You may tell the workflow to create a pure antlr debug grammar
ParserGenerator = {debuggrammar=true} or something like that
To analyze this.
Since terminal rules are context free they are not allowed to overlap each other
So you might have problems with the ID as well.
Maybe you should loosen your grammar (fewer terminal rules, maybe use of datatype rules which are parser rules) and use value converters to do the range checking
Re: Confusion about terminals [message #1742813 is a reply to message #1742738] Wed, 07 September 2016 15:40 Go to previous message
Ok that makes a lot of sense, thanks for the explanation. It means I still understand to some degree how this works.
By the way, I agree that the terminals are overly complicated, and overlapping. In fact, I know that HEX_NO_PREFIX and HEX_INT_PREFIX is actually shadowing ID in many places. I have a version of the grammar, where I removed all but comment, white-space and string terminals. Even though such parser rule based terminals allow context to be defined better and represent the specs more accurately but they break down terminals to be almost always as one character. This results in everything appearing in the editor as a keyword, and also double clicking any word always selects only one character, which is annoying.
Previous Topic:xtext add cross reference in expression
Next Topic:Grammar generation bug when adding cross-reference
Current Time: Wed Jul 23 23:01:47 EDT 2025
Powered by FUDForum. Page generated in 0.04215 seconds
