Home » Modeling » TMF (Xtext) » xtext add cross reference in expression(xtext add cross reference in expression)
xtext add cross reference in expression [message #1742484] Fri, 02 September 2016 07:11 Go to next message
How to use cross reference of a method implementation in an expression in xtext?
Re: xtext add cross reference in expression [message #1742490 is a reply to message #1742484] Fri, 02 September 2016 07:50 Go to previous messageGo to next message
What is your actual question. Please explain
Re: xtext add cross reference in expression [message #1742495 is a reply to message #1742490] Fri, 02 September 2016 08:02 Go to previous messageGo to next message
I have to cross reference the methods using in expressions.
I have my grammar like :
Call: 'call' procRef=[Proc] callExp=CompleteExpression?;
Proc: ('string'|'double')? 'proc' name=ID procExp=CompleteExpression?;
Which works fine for
call test();
proc test()
But I want to cross reference the proc when call used in expression like abc = test();
For this I am using grammar like
Assignment: name=('math')? (precision=Precision)? (assignExp+=Expression) (=>'=' procRef=[Proc] assignExp+=Expression);
But no luck. If I make procRef optional in the grammar, cross reference is not working at all.
Re: xtext add cross reference in expression [message #1742496 is a reply to message #1742495] Fri, 02 September 2016 08:07 Go to previous messageGo to next message
Please try this with a hello world grammar
Re: xtext add cross reference in expression [message #1742502 is a reply to message #1742496] Fri, 02 September 2016 09:03 Go to previous messageGo to next message
Yes I tried. The result is same.
Re: xtext add cross reference in expression [message #1742504 is a reply to message #1742502] Fri, 02 September 2016 09:19 Go to previous messageGo to next message
Please share that minimal example.
Re: xtext add cross reference in expression [message #1742506 is a reply to message #1742504] Fri, 02 September 2016 09:25 Go to previous messageGo to next message
OpenAssignment: args+=Assignment ','?;
Assignment: name=('math')? (precision=Precision)? (assignExp+=Expression) (=>'=' assignExp+=Expression);
Precision: (width=NUMBER)|((width=NUMBER)?'.'(decimal_places=NUMBER));
ArrayDecl : {ArrayDecl} ('[' ']') | ('[' size=CompleteExpression ']');
Parenthesis : {Parenthesis} ('(' ')') | ('(' size=CompleteExpression ')');
Initialize : {Initialize} ('{' '}')|('{' args=CompleteExpression '}');
Expression:
LogicalOr
LogicalOr returns Expression:
BitwiseOr ({LogicalOr.left=current} '||' right=BitwiseOr)*
BitwiseOr returns Expression:
LogicalAnd ({BitwiseOr.left=current} '|' right=LogicalAnd)*
LogicalAnd returns Expression:
BitwiseAnd ({LogicalAnd.left=current} '&&' right=BitwiseAnd)*
BitwiseAnd returns Expression:
Equivalency ({BitwiseAnd.left=current} '&' right=Equivalency)*
Equivalency returns Expression:
Relational ({Equivalency.left=current} ('=='|'!=') right=Relational)*
Relational returns Expression:
PlusMinus ({Relational.left=current} ('>='|'<='|'>'|'<') right=PlusMinus)*
PlusMinus returns Expression:
DivMult ({PlusMinus.left=current} ('+'|'-') right=DivMult)*
//DivMult | ({PlusMinus} ('+'|'-') expr=DivMult)
DivMult returns Expression:
LogicalNot ({DivMult.left=current} ('/'|'*') right=LogicalNot)*
LogicalNot returns Expression:
//OnesComplement ({LogicalNot.left=current} ('!') right=LogicalNot)*
OnesComplement | ({LogicalNot} ('!') expr=OnesComplement)
OnesComplement returns Expression:
Exponentiation ({OnesComplement.left=current} ('~') right=Exponentiation)*
Exponentiation returns Expression:
ColonOperator ({Exponentialtion.left=current} '^' right=ColonOperator)*
ColonOperator returns Expression:
PercentOperator | ({ColonOperator} (':'('+')?) expr=PercentOperator)
PercentOperator returns Expression:
ArrowExpression | ({PercentOperator} ('%'|'%t'|'%.'|'%:') expr=ArrowExpression)
ArrowExpression returns Expression:
Concatenation ({ArrowExpression.left=current} '->' right=Concatenation)*
Concatenation returns Expression:
Primary ({Concatenation.left=current} '##' right=Primary)*
Primary returns Expression: {Expression}
('+'|'-')? name=NUMBER | name=STRING | name=ID (ArrayDecl=ArrayDecl? & Parenthesis=Parenthesis?) |
ArrayDecl=ArrayDecl | Parenthesis=Parenthesis | Initialize=Initialize | LibraryFunc=LibraryFunc
GSD returns Expression: name=ID {GSD.left=current} ('[' occurence=(NUMBER|STRING) ']')?('(' m=NUMBER (',' (n=NUMBER))? ')')? '->' right=ID;
CompleteExpression:
CompleteExpression+=Expression (','? CompleteExpression+=Expression)*
terminal DBMS: ('DBMS'|'Dbms'|'dbms') (('\\'((' '|'\t')* '\r'? '\n')) | !('\n' | '\r'))*;
terminal ID : ((':'('+')?)?|('+'|'-')?)('a'..'z'|'A'..'Z'|'$'|'.'|'@'|'_')('a'..'z'|'A'..'Z'|'$'|'.'|'0'..'9'|'@'|'*'|'_'|'!')*;
terminal STRING : '"' ( '\\'('"'|('\r'? '\n')) | !('\n'|'"') )* '"' |
"'" ( '\\'("'"|('\r'? '\n')) | !('\n'|"'") )* "'";
terminal SL_COMMENT: '//' !('\n' | '\r')*;
terminal HASH_COMMENT : ('#'('\r'? '\n')?) | ('#' !('#'|'\n'|'\r')+ ('\r'? '\n')?) | (('#''#''#') !('\n'|'\r')* ('\r'? '\n')?);
terminal WS : (' '|'\t'| ('\\'((' '|'\t')* '\r'? '\n')))+;
terminal NL : ('\r'? '\n')+;
terminal NUMBER: (OCTAL|FLOAT|INT|BINARY|HEX);
terminal OCTAL returns ecore::EInt: ('0') ('0'..'7')+;
terminal FLOAT returns ecore::EFloat: ('0'..'9' ('0'..'9')*) '.' ('0'..'9')*;
terminal INT returns ecore::EInt: '0'..'9' ('0'..'9')*;
terminal RANGE: '0'..'9' '..' ('0'..'9')*;
terminal BINARY returns ecore::EInt: ('0b'|'0B') ('0'|'1')+;
terminal HEX returns ecore::EInt:('0x'|'0X')('0'..'9'|'a'..'f'|'A'..'F')+;
[Updated on: Fri, 02 September 2016 09:26] by Moderator
Re: xtext add cross reference in expression [message #1742507 is a reply to message #1742506] Fri, 02 September 2016 09:27 Go to previous messageGo to next message
Sry that grammar is too big to give any support
Re: xtext add cross reference in expression [message #1742701 is a reply to message #1742507] Tue, 06 September 2016 12:58 Go to previous messageGo to next message
This is the minimal grammar to reproduce the problem.
Re: xtext add cross reference in expression [message #1742703 is a reply to message #1742701] Tue, 06 September 2016 13:01 Go to previous messageGo to next message
it is not.
i e.g. do not understand why BitwiseAnd is in the "not minimal" grammar
Re: xtext add cross reference in expression [message #1742757 is a reply to message #1742703] Wed, 07 September 2016 09:29 Go to previous messageGo to next message
Oh Ok.
Is it fine?
Call: 'call' procRef=[Proc] callExp=Expression?;
Proc: ('string'|'double')? 'proc' name=ID procExp=Expression?;
OpenAssignment: args+=Assignment;
Assignment: name=('math')? (precision=Precision)? (assignExp+=Expression);
ArrayDecl : {ArrayDecl} ('[' ']');
Parenthesis : {Parenthesis} ('(' ')');
Expression:
Equivalency
Primary ({Equivalency.left=current} ('=='|'!='|'=') right=Primary)*
Re: xtext add cross reference in expression [message #1742760 is a reply to message #1742757] Wed, 07 September 2016 09:35 Go to previous messageGo to next message
My problem is I don't want to show warning if it not find cross reference in expression.
index.php/fa/26986/0/
  • Attachment: procref.png
    (Size: 5.98KB, Downloaded 328 times)
Re: xtext add cross reference in expression [message #1742762 is a reply to message #1742757] Wed, 07 September 2016 09:38 Go to previous messageGo to next message
yes although the definition of number is missing. and a rule that builds the model file.
if i improvise like
Model:
(elements+=Call | elements+=Proc | elements+=OpenAssignment)+
i get a lot of warning regarding ambiguity.
so thus i need
(a) a small grammar
(b) a complete grammar
(c) a test model
Re: xtext add cross reference in expression [message #1742763 is a reply to message #1742762] Wed, 07 September 2016 09:39 Go to previous messageGo to next message
and about the warning or whatever: i already told you what to do
Re: xtext add cross reference in expression [message #1742765 is a reply to message #1742763] Wed, 07 September 2016 09:44 Go to previous messageGo to next message
I extended LinkingDiagnosticMessageProvider for warningmessage but I don't understand how to get type of rule at that particular context.
Can I get the complete text of that context?
[Updated on: Wed, 07 September 2016 09:46] by Moderator
Re: xtext add cross reference in expression [message #1742769 is a reply to message #1742765] Wed, 07 September 2016 09:51 Go to previous message
see other question you asked
Previous Topic:Bidirectional imports
Next Topic:Confusion about terminals
Current Time: Sun Jul 27 14:38:36 EDT 2025
Powered by FUDForum. Page generated in 0.04803 seconds
