Home » Modeling » TMF (Xtext) » appendArguments(..) generating comments instead of content
appendArguments(..) generating comments instead of content [message #1742541] Sat, 03 September 2016 20:13 Go to next message
I have the following grammar (snippets of):
Action:
	'action' name=ID '(' actionFormalParameters=FormalParameters ')' '=' action=ActionBlock;
ActionBlock returns xbase::XBlockExpression:
	{ActionBlock}
	(expressions+=ActionBlockStatement ';'?)*
ActionBlockStatement returns xbase::XExpression:
	ActionRefInvocation | XExpressionOrVarDeclaration;
ActionRefInvocation:
	actionRef=ActionRef '(' actionActualParameters=ActualParameters ')';
ActionRef hidden():
	'#' actionRefId=[Action];
In other words, I want to be able to do something like this:
    action a(String s) = {
    		println(s)
    action b(String s) = {
    		#a(s)
In my compiler that extends XbaseCompiler, I have the following function to handle ActionRefInvocation:
override protected doInternalToJavaStatement(XExpression obj, ITreeAppendable appendable, boolean isReferenced) {
		if (obj instanceof ActionRefInvocation) {
			appendable.trace(obj)
			appendable.newLine
			val action = obj.actionRef.actionRefId
			val actionParameters = obj.actionActualParameters
			val actionClass = action.jvmElements.filter(JvmGenericType).filter[t|!t.isInterface].head
			val objectName = "action" + uuidName
			appendable.append('''«actionClass.fullyQualifiedName» «objectName» = new «actionClass.fullyQualifiedName»();''')
			appendable.newLine
			appendable.append('''«objectName».accept(''')
			appendable.newLine
			appendArguments(actionParameters.parameters, appendable)
			appendable.append(");")
			appendable.newLine
			appendable.newLine
			return
		super.doInternalToJavaStatement(obj, appendable, isReferenced)
But the output I get from the compilation is the following, which of course does not compile because the function implementation of a expects a String argument.
public void accept(final int i) {
    valour.documentation.actions.Action6 action07f90ee2b6004c4fb226bbe61c58c88f = new valour.documentation.actions.Action6();
    action07f90ee2b6004c4fb226bbe61c58c88f.accept(
    /* name is null */);
Also, I've noticed that if I change the example supplied above to:
    		println(s)
    action b() = {
    		#a("foo")
I get the following null pointer exception on the invocation of appendArguments(..)
!STACK 0
	at org.eclipse.xtext.xbase.compiler.LiteralsCompiler.toJavaExpression(LiteralsCompiler.java:81)
	at org.eclipse.xtext.xbase.compiler.LiteralsCompiler._toJavaExpression(LiteralsCompiler.java:73)
	at org.eclipse.xtext.xbase.compiler.LiteralsCompiler.internalToConvertedExpression(LiteralsCompiler.java:41)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.internalToConvertedExpression(FeatureCallCompiler.java:102)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.internalToConvertedExpression(XbaseCompiler.java:317)
	at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToConvertedExpression(TypeConvertingCompiler.java:104)
	at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToJavaExpression(TypeConvertingCompiler.java:47)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArgument(FeatureCallCompiler.java:1033)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArguments(FeatureCallCompiler.java:995)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendArguments(FeatureCallCompiler.java:989)
	at mt.edu.um.cs.rv.ValourCompiler.doInternalToJavaStatement(ValourCompiler.java:70)
I'm not sure what I'm doing wrong here. I would appreciate your help.
Re: appendArguments(..) generating comments instead of content [message #1742699 is a reply to message #1742541] Tue, 06 September 2016 12:55 Go to previous messageGo to next message
What are your adoptions to inferrer and type computer?
Re: appendArguments(..) generating comments instead of content [message #1742702 is a reply to message #1742699] Tue, 06 September 2016 12:59 Go to previous messageGo to next message
and how do the actual parameters look like.
and on what level do you use the actions? maybe a inferrer only solution would do the trick as well (with a silghtly different syntax)
Re: appendArguments(..) generating comments instead of content [message #1743471 is a reply to message #1742702] Thu, 15 September 2016 13:59 Go to previous messageGo to next message
Thanks for you reply Christian, and sorry for getting back late but was on vacation since.
In my inferrer, I am first creating an FunctionalInterface for the action
		val consumableFunctionalInterface = action.toClass(
			functionalInterfaceName,
				annotations += annotationRef(FunctionalInterface)
				interface = true
				members += action.toMethod("accept", typeRef(void), [
					static = false
					^default = false
					abstract = true
					visibility = JvmVisibility.PUBLIC
					action.actionFormalParameters.parameters.forEach [ p |
						parameters += action.toParameter(p.name, p.parameterType)
and then creating an implementation of the FunctioanlInterface and plugging in the body of the action
		val actionClass = action.toClass(
			className,
				superTypes += typeRef(functionalInterfaceName)
					static = false
					annotations += annotationRef(Override)
					body = action.action
I have not implemented anything in terms of the type computer. Is this something that I should be extending ?
My definition of ActualParameter is the following:
ActualParameters:
	{ActualParameters}(parameters+=XExpression (',' parameters+=XExpression)*)?;
Any guidance to help me get this set up in the proper way would be greatly appreciated.
Re: appendArguments(..) generating comments instead of content [message #1743474 is a reply to message #1743471] Thu, 15 September 2016 14:17 Go to previous messageGo to next message
i was thinking of
Model:
	actions+=Action+
Action:
	'action' name=ID '(' (actionFormalParameters+=JvmFormalParameter (',' actionFormalParameters+=JvmFormalParameter)*) ')' '=' action=XBlockExpression;
	def dispatch void infer(Model model, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(model.toClass("test.Demo")) [
			for (a : model.actions) {
				members += a.toMethod(a.name, Void.TYPE.typeRef) [
					body = a.action
					for (p : a.actionFormalParameters) {
						parameters+=p
Re: appendArguments(..) generating comments instead of content [message #1743484 is a reply to message #1743474] Thu, 15 September 2016 16:10 Go to previous messageGo to next message
Thanks for your quick reply.
My issue is not with defining an action but with having one action invoke another action, and my requirement is that action are referenced using a #.
In the example below, I don't have any issues with compiling action a. However, when compiling action b (which contains an ActionRefInvocation) I get the exception I mentioned in my first post.
    		println(s)
    action b() = {
    		#a("foo")
Re: appendArguments(..) generating comments instead of content [message #1743488 is a reply to message #1743484] Thu, 15 September 2016 16:43 Go to previous messageGo to next message
Well as I said that is not that easy. In that case you have to compute the types correctly in your type computer
Re: appendArguments(..) generating comments instead of content [message #1743489 is a reply to message #1743488] Thu, 15 September 2016 16:45 Go to previous messageGo to next message
Well how does your type computer for action ref and actual parameters look like?
Re: appendArguments(..) generating comments instead of content [message #1743491 is a reply to message #1743489] Thu, 15 September 2016 17:32 Go to previous messageGo to next message
This is what I have so far for ActionRefInvocation. I am computing a void type as the invocation of actions will always return void.
    def dispatch computeTypes(ActionRefInvocation literal, ITypeComputationState state) {
        state.withoutExpectation
        state.acceptActualType(getPrimitiveVoid(state))
I have not as yet written a type computer for ActualParameters as I'm not sure what to do here.
Re: appendArguments(..) generating comments instead of content [message #1743500 is a reply to message #1743491] Fri, 16 September 2016 01:13 Go to previous messageGo to next message
you are missing to walk down into the actual params
public class MyDslTypeComputer extends XbaseTypeComputer {
	public void computeTypes(XExpression expression, ITypeComputationState state) {
		if (expression instanceof ActionRefInvocation) {
			// TODO match formal and actual params in expectation (use expectation of formal param)
			for (XExpression ap : ((ActionRefInvocation) expression).getActionActualParameters().getParameters()) {
				state.withNonVoidExpectation().computeTypes(ap);
			state.acceptActualType(getPrimitiveVoid(state));
			return;
		super.computeTypes(expression, state);
Re: appendArguments(..) generating comments instead of content [message #1743661 is a reply to message #1743500] Sun, 18 September 2016 09:47 Go to previous message
That worked perfectly! Thanks for all your help!
Previous Topic:How does the until rule works ?
Next Topic:Multiple file support in IDEA plugin
Current Time: Tue Jul 29 00:09:53 EDT 2025
Powered by FUDForum. Page generated in 0.06106 seconds
