Home » Archived » Eclipse Communications Framework (ECF) » ECF + Karaf + Zookeeper
ECF + Karaf + Zookeeper [message #1742610] Tue, 06 September 2016 03:28 Go to next message
I have 3 OSGi runtimes on 3 different virtual machines in different subnets. There is no broadcasting between the subnets.
I would like to be able to use ECF inside Karaf and use Zookeeper to handle the remote/distributed bundles between the OSGi runtimes.
I have installed Karaf 4.0.6 and installed ECF SDK (latest). Here is a list of the bundles.
karaf@root()> list
START LEVEL 100 , List Threshold: 50
ID | State | Lvl | Version | Name
96 | Active | 80 | 3.7.0.v20150330-2103 | Eclipse Jobs Mechanism
97 | Active | 80 | 3.8.0.v20160823-2221 | ECF Core API
98 | Active | 80 | 5.0.200.v20160823-2221 | ECF Discovery API
99 | Active | 80 | 3.7.0.v20160823-2221 | ECF Identity Core API
100 | Active | 80 | 2.1.0.v20160823-2221 | ECF Remote Service Admin (RSA) Basic Topology Manager
101 | Active | 80 | 4.4.2.v20160823-2221 | ECF Remote Service Admin (RSA) Implementation
102 | Active | 80 | 1.0.0.v20160823-2221 | ECF Remote Service Admin (RSA) Proxy
103 | Active | 80 | 4.7.500.v20160823-2221 | ECF Generic Provider
105 | Active | 80 | 4.2.100.v20160823-2221 | ECF Generic Provider RemoteServices Support
106 | Active | 80 | 8.11.0.v20160823-2221 | ECF RemoteServices API
107 | Active | 80 | 2.0.100.v20150702-1411 | ECF RemoteServices AsyncProxy API Java8
108 | Active | 80 | 2.5.100.v20160823-2221 | ECF SharedObject API
109 | Active | 50 | 3.7.0.v20150402-1709 | Common Eclipse Runtime
110 | Active | 80 | 1.1.0.v20130327-1442 | Equinox Concurrent API
111 | Active | 80 | 1.6.0.v20141009-1504 | Supplemental Equinox Functionality
112 | Active | 80 | 1.6.100.v20160823-2221 | OSGi R6 RemoteServiceAdmin API
113 | Active | 80 | 3.3.3.v201105210832 | Apache ZooKeeper
115 | Active | 80 | 1.2.100.v20160823-2221 | ECF Discovery ZooKeeper Provider
There is a zookeeper server running in each VM together with the OSGi runtime, ports are 2222 and 2223.
I use Eclipse with bnd(tools) to write my code and I have the following
@Component(
immediate = true
, property = {
"service.exported.interfaces=com.example.ServiceConsumerAPI"
, "service.exported.configs=ecf.generic.server"
, "ecf.generic.server.id=ecftcp://myserver.mydomain:2230/service"
, service = ServiceConsumerAPI.class
I'm not sure what to use in "service.exported.configs" and "ecf.generic.server.id" to get the service from Karaf published in my zookeeper server. I used this code when my Karaf instances where running inside the same subnet and thus broadcasting was possible.
Many thanks in advance for your precious feedback.
Alex
Re: ECF + Karaf + Zookeeper [message #1742691 is a reply to message #1742610] Tue, 06 September 2016 12:23 Go to previous messageGo to next message
Hi Alex,
Alex Weirig wrote on Tue, 06 September 2016 03:28
<stuff deleted>
<stuff deleted>
I think you will need to refer to this page:
https://wiki.eclipse.org/Zoodiscovery
for information on configuring the Zookeeper instances.
See particularly the section: 'How to configure ZooDiscovery container'
If you need more assistance WRT Zookeeper Wim Jongman (ecf committer) is the maintainer of that component and its documentation. You can find him on the ecf-dev mailing list most easily
https://dev.eclipse.org/mailman/listinfo/ecf-dev
Re: ECF + Karaf + Zookeeper [message #1742737 is a reply to message #1742691] Wed, 07 September 2016 01:49 Go to previous message
Hi Scott,
thank you very much for you reply. I know the wiki page and found that it is really clear how to transpose the instructions to Karaf and DS.
I'll try to contact Wim and maybe we can add some documentation to the page.
Alex
Previous Topic:news.eclipse.org is shutting down.
Next Topic:Mutiple DistributionProviders for a the same component
Current Time: Fri Oct 31 12:43:59 EDT 2025
Powered by FUDForum. Page generated in 0.43994 seconds
