Saving to array not working [message #1741529] |
Thu, 25 August 2016 12:00  |
I'm using Eclipselink 2.6.3 with Postgres and I'm trying to save and List of strings to an `text[]` column in database
This is what've done so far:
@Array(databaseType="TEXT[]")
private List<String> members = new ArrayList<>();
annotated my model with
when I try save it, I get
... 92 common frames omitted
Caused by: org.postgresql.util.PSQLException: Unable to find server array type for provided name TEXT[].
at org.postgresql.jdbc.PgConnection.createArrayOf(PgConnection.java:1333) ~[postgresql-9.4.1209.jre7.jar:9.4.1209.jre7]
am I still missing something? my database column is `text[]` as well
Re: Saving to array not working [message #1804165 is a reply to message #1742461] |
Tue, 19 March 2019 11:30   |
I am testing with EclipseLink 2.7.4 and PostgreSQL JDBC driver 42.2.5 with Spring Boot 2.1.3.
This feature if worked would have been great to avoid lot of boilerplate converter code. However this is not working (atleast for me)
If I declare the entity with
@Array(databaseType = "text[]")
private List<String> plans;
The JDBC driver method createArrayOf in org.postgresql.jdbc.PgConnection complains.
public Array createArrayOf(String typeName, Object[] elements) throws SQLException {
checkClosed();
int oid = getTypeInfo().getPGArrayType(typeName);
if (oid == Oid.UNSPECIFIED) {
throw new PSQLException(
GT.tr("Unable to find server array type for provided name {0}.", typeName),
PSQLState.INVALID_NAME);
So I changed to
@Array(databaseType = "text")
However, beyond that when null/empty collection is being set to this, the code in EclipseLink seems to loose type info:
org.eclipse.persistence.mappings.foundation.AbstractCompositeDirectCollectionMapping.writeFromObjectIntoRow(...)
line 623:
Object fieldValue = null;
if (!elements.isEmpty()) {
fieldValue = this.getDescriptor().buildFieldValueFromDirectValues(elements, elementDataTypeName, session);
row.put(this.getField(), fieldValue);
on db side:
column "plans" is of type text[] but expression is of type text at character 211
If I force in debug session to compute fieldValue, the error isn't coming.
Anyways, these are observations spending couple of hours. Question is, is this working as documented?
Can this be addressed?
Re: Saving to array not working [message #1805193 is a reply to message #1804171] |
Tue, 09 April 2019 12:20  |
Have you tried using the @Array(databaseType="varchar") annotation mentioned above? You might still get the null issue as EclipseLink doesn't know NULL is a collection type, and only has the field type to go by ('text' or 'varchar') to pass to the driver for null typing.
What JDBC driver versions are you using, and how do they state to specify the type?
> edit, I didn't notice you posted the JDBC driver version. EclipseLink docs though haven't been updated in quite some time, so this might be due to behaviour changes from when the feature was first added/tested within the driver itself.
[Updated on: Tue, 09 April 2019 12:24] by Moderator
FUDForum. Page generated in 0.17546 seconds
