Home » Modeling » TMF (Xtext) » Add xtext nature programmatically(Add xtext nature programmatically)
Add xtext nature programmatically [message #1742281] Thu, 01 September 2016 08:32 Go to next message
I am using IXtextEditorCallback in my code. Then onwards when I am creating a project in editor it is not asking dialog to add xtext nature. Could you please tell me what to do?
class JPLEditorOnSave implements IXtextEditorCallback {
override afterCreatePartControl(XtextEditor editor) {}
override afterSave(XtextEditor editor) {
val IWorkspace workspace= ResourcesPlugin.getWorkspace();
val IPath location= Path.fromOSString(editor.resource.rawLocation.toFile.getAbsolutePath());
val IFile ifile= workspace.getRoot().getFileForLocation(location);
GenerationHandler.jpl2binExec(ifile)
override afterSetInput(XtextEditor xtextEditor) {}
override beforeDispose(XtextEditor editor) {}
override beforeSetInput(XtextEditor xtextEditor) {}
override onValidateEditorInputState(XtextEditor editor) {
return true
Re: Add xtext nature programmatically [message #1742282 is a reply to message #1742281] Thu, 01 September 2016 08:36 Go to previous messageGo to next message
what is your actual question.
Re: Add xtext nature programmatically [message #1742286 is a reply to message #1742282] Thu, 01 September 2016 08:44 Go to previous messageGo to next message
( i assuemd you customized org.eclipse.xtext.builder.nature.NatureAddingEditorCallback half a your ago, did you change this again)
Re: Add xtext nature programmatically [message #1742290 is a reply to message #1742286] Thu, 01 September 2016 08:51 Go to previous messageGo to next message
Yes right. I am using the below code for disable it in ui module before.
override bindIXtextEditorCallback() {
JPLEditorOnSave
But how can I add xtext nature now?
Re: Add xtext nature programmatically [message #1742292 is a reply to message #1742290] Thu, 01 September 2016 08:57 Go to previous messageGo to next message
Copy the code that does that from there?
Re: Add xtext nature programmatically [message #1742293 is a reply to message #1742292] Thu, 01 September 2016 09:01 Go to previous messageGo to next message
class JPLEditorUiModule extends AbstractJPLEditorUiModule {
override configure(Binder binder) {
super.configure(binder);
binder.bind(String).annotatedWith(Names.named((XtextContentAssistProcessor.COMPLETION_AUTO_ACTIVATION_CHARS))).toInstance('>_');
def Class<? extends AbstractAntlrTokenToAttributeIdMapper> bindAbstractAntlrTokenToAttributeIdMapper() {
JPLAntlrTokenToAttributeIdMapper
def Class<? extends IValueConverterService> bindIValueConverterService() {
return CustomTerminalConverters;
JPLEditorOnSave
def Class<? extends ILinkingDiagnosticMessageProvider.Extended> bindILinkingDiagnosticMessageProvider() {
return JPLHyperlinkHelper;
Re: Add xtext nature programmatically [message #1742294 is a reply to message #1742293] Thu, 01 September 2016 09:03 Go to previous messageGo to next message
No I mean : copy the logic from nature adding editor callback to your callback
Re: Add xtext nature programmatically [message #1742298 is a reply to message #1742294] Thu, 01 September 2016 09:33 Go to previous messageGo to next message
I dont understand. You mean like this:
return true
public static class NullImpl implements IXtextEditorCallback {
return true
Re: Add xtext nature programmatically [message #1742300 is a reply to message #1742298] Thu, 01 September 2016 09:37 Go to previous messageGo to next message
if you have a look at NatureAddingEditorCallback you will find these strange code :
public class NatureAddingEditorCallback extends IXtextEditorCallback.NullImpl {
	private static final String ADD_XTEXT_NATURE = "add_xtext_nature";
	@Inject
	private ToggleXtextNatureAction toggleNature;
	private @Inject DontAskAgainDialogs dialogs;
	public void afterCreatePartControl(XtextEditor editor) {
		IResource resource = editor.getResource();
		if (resource != null && !toggleNature.hasNature(resource.getProject()) && resource.getProject().isAccessible()
				&& !resource.getProject().isHidden()) {
			String title = Messages.NatureAddingEditorCallback_MessageDialog_Title;
			String message = Messages.NatureAddingEditorCallback_MessageDialog_Msg0 + resource.getProject().getName()
					+ Messages.NatureAddingEditorCallback_MessageDialog_Msg1;
			boolean addNature = false;
			if (MessageDialogWithToggle.PROMPT.equals(dialogs.getUserDecision(ADD_XTEXT_NATURE))) {
				int userAnswer = dialogs.askUser(message, title, ADD_XTEXT_NATURE, editor.getEditorSite().getShell());
				if (userAnswer == IDialogConstants.YES_ID) {
					addNature = true;
				} else if (userAnswer == IDialogConstants.CANCEL_ID) {
					return;
			} else if (MessageDialogWithToggle.ALWAYS.equals(dialogs.getUserDecision(ADD_XTEXT_NATURE))) {
				addNature = true;
			if (addNature) {
				toggleNature.toggleNature(resource.getProject());
this basically does 2 things
(1) ask the user
(2) add the nature
Re: Add xtext nature programmatically [message #1742301 is a reply to message #1742300] Thu, 01 September 2016 09:45 Go to previous messageGo to next message
Ok. But I am not at all doing with NatureAddingEditorCallback anywhere? So I need to added that code in class JPLEditorOnSave implements IXtextEditorCallback?
[Updated on: Thu, 01 September 2016 09:45] by Moderator
Re: Add xtext nature programmatically [message #1742302 is a reply to message #1742301] Thu, 01 September 2016 09:50 Go to previous messageGo to next message
Guess ....
Re: Add xtext nature programmatically [message #1742305 is a reply to message #1742302] Thu, 01 September 2016 10:26 Go to previous message
Ok
Previous Topic:[Solved] Xtext 2.10 - Cannot reference common JavaVMTypes in model
Next Topic:feature modeling plugin and oAW chain
Current Time: Tue Jul 22 04:12:51 EDT 2025
Powered by FUDForum. Page generated in 0.07947 seconds
