Home » Eclipse Projects » OM2M » How to add a string to the body of contentInstance?
How to add a string to the body of contentInstance? [message #1742283] Thu, 01 September 2016 08:36 Go to next message
Hello all,
assume that I have a string like:
String bodyContent =
"<con>
&lt;obj>
&lt;str name=&quot;appId&quot;val=&quot;APP&quot;/>
&lt;str name=&quot;category&quot; val=&quot;temperature &quot;/>
&lt;int name=&quot;data&quot; val=&quot;20&quot;/>
&lt;int name=&quot;unit&quot; val=&quot;celsius&quot;/>
&lt;/obj>
</con>"
And I would like to create inside of the DATA container an contentInstance whose body is the above string.
I tried the following:
String targetId = "/" + CSE_ID + "/" + CSE_NAME + "/" + actuatorId + "/" + DATA;
ContentInstance cin = new ContentInstance();
cin.setContent(bodyContent);
cin.setContentInfo(MimeMediaType.OBJ);
RequestSender.createContentInstance(targetId, cin);
And this is my result, the content body was not shown as a table like usual:
https://s14.postimg.org/kdukr3ye9/Unbenannt.png
Can anyone help me where did I do wrong here?
Thank you very much!
Son
Re: How to add a string to the body of contentInstance? [message #1742853 is a reply to message #1742283] Thu, 08 September 2016 04:52 Go to previous messageGo to next message
Did you try with the String :
"&lt;obj>
&lt;/obj>"
Because it seems, according to you picture that there is an extra <con> tag, which is not needed.
Dorian
Re: How to add a string to the body of contentInstance? [message #1742857 is a reply to message #1742853] Thu, 08 September 2016 05:03 Go to previous messageGo to next message
Hi Dorian,
I also tried without of the <con> tag but still no success Sad
Son
Re: How to add a string to the body of contentInstance? [message #1742860 is a reply to message #1742857] Thu, 08 September 2016 05:18 Go to previous message
And when you do a GET request with a REST client on this resource, do you retrieve the value you wanted ? Because, it may just be the display in the debug interface which does not work as you expect (maybe also try to put the value by replacing all the &lt; and &quot; by < and ").
[Updated on: Thu, 08 September 2016 05:19] by Moderator
Previous Topic:How to start the plugin automatically?
Next Topic:where is the OM2M-libs.rar
Current Time: Sun Aug 31 14:56:01 EDT 2025
Powered by FUDForum. Page generated in 0.03885 seconds
