Home » Modeling » TMF (Xtext) » [Solved] Xtext 2.10 - Cannot reference common JavaVMTypes in model
[Solved] Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742121] Wed, 31 August 2016 10:57 Go to next message
I'm trying to go through the tutorial at https://eclipse.org/Xtext/documentation/305_xbase.html .
Mapping a datatype to a Java element, does not seem to work.
Instead at the line:
datatype Date mapped-to java.util.Date
I get the following error message:
Couldn't resolve reference to JvmType 'java.util.Date'.
I've tried adding a reference to the common Java types in the language definition, like this:
language = StandardLanguage {
	name = "org.example.domainmodel.Domainmodel"
	fileExtensions = "dmodel"
	referencedResource=
		"platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel"
	serializer = {
		generateStub = false
	validator = {
		// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
However i still get the same error.
Am i or the tutorial missing something?
[Updated on: Thu, 01 September 2016 07:43] by Moderator
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742122 is a reply to message #1742121] Wed, 31 August 2016 11:03 Go to previous messageGo to next message
Does your grammar inherit from xbase?
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742123 is a reply to message #1742122] Wed, 31 August 2016 11:24 Go to previous messageGo to next message
e.g grammar org.xtext.example.mydsl1.MyDsl with org.eclipse.xtext.xbase.Xtype
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742124 is a reply to message #1742123] Wed, 31 August 2016 11:26 Go to previous messageGo to next message
if not you can
commonTypesSupport = {
onlyEnabledIfGrammarIsUsed = false
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742275 is a reply to message #1742124] Thu, 01 September 2016 07:42 Go to previous messageGo to next message
Thank you Christian, this works!
The grammar in the tutorial inherits from org.eclipse.xtext.common.Terminals.
Maybe the tutorial should be updated accordingly:
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742277 is a reply to message #1742275] Thu, 01 September 2016 08:08 Go to previous messageGo to next message
i will add a hint
Re: Xtext 2.10 - Cannot reference common JavaVMTypes in model [message #1742278 is a reply to message #1742277] Thu, 01 September 2016 08:14 Go to previous message
https://github.com/eclipse/xtext-eclipse/issues/69
Previous Topic:xtext class not found error
Next Topic:Add xtext nature programmatically
Current Time: Sun Jul 20 14:24:42 EDT 2025
Powered by FUDForum. Page generated in 0.17660 seconds
