Home » Newcomers » Newcomers » Helios not starting("Incompatible file format" error reported in log file)
Helios not starting [message #669360] Tue, 10 May 2011 01:30 Go to next message
My copy of Helios is reporting an error message in the log file when I attempt to start it (Windows 7 platform). The splash screen appears briefly but then promptly disappears and there's no exclipse.exe process to be found running.
Here's the error message in the log file at workspaces/.metadata/.log:
!ENTRY org.eclipse.osgi 4 0 2011-05-10 17:03:17.619
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:116)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (174).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:121)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger (BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:106)
... 22 more
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 1331426228.
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getR eader(WorkspaceTreeReader.java:58)
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getR eader(WorkspaceTreeReader.java:66)
at org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:978)
at org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:665)
at org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1503)
at org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:2134)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1883)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:406)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
... 28 more
Thanks for any assistance.
Re: Helios not starting [message #669484 is a reply to message #669360] Tue, 10 May 2011 09:53 Go to previous messageGo to next message
You don't say whether you've every successfully started it before or
not. It sure helps to provide context. Assuming this is the case, the
usual culprit is failure to specify a valid JRE or JDK in eclipse.ini.
Note that if you're going to develop in Java, you'll want an actual JDK
and not merely a JRE there. Please see
http://wiki.eclipse.org/Eclipse.ini
On 09-May-11 23:30, forums-noreply@eclipse.org wrote:
> Hello,
> Quote:
>> !STACK 1
>> tarter.java:369)
>> tarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
>> Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
>> Source)
>> at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
>> Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> 619)
>> at
>> at
>> leLoader.java:422)
>> leLoader.java:410)
>> at java.lang.ClassLoader.loadClass(Unknown Source)
>> ... 13 more
>> ion.java:417)
>> ... 22 more
>> Caused by:
>> Manager.java:665)
>> Manager.java:1503)
>> ace.java:2134)
>> .java:1883)
>> ugin.java:406)
>> at java.security.AccessController.doPrivileged(Native
>> Method)
>> ... 28 more
Re: Helios not starting [message #669578 is a reply to message #669484] Tue, 10 May 2011 15:44 Go to previous messageGo to next message
Thanks for the reply.
Yes, I have successfully started the application previously. This behaviour started when the PC crashed as the application was shutting down yesterday.
Re: Helios not starting [message #674449 is a reply to message #669360] Thu, 26 May 2011 20:26 Go to previous messageGo to next message
Can anyone help with this, please? I still cannot get Eclipse to start.
Thanks.
Re: Helios not starting [message #674463 is a reply to message #674449] Thu, 26 May 2011 22:53 Go to previous messageGo to next message
Maybe workspace/.metadata/.plugins/org.eclipse.core.resources/.root/*.tree has been corrupted. Maybe.
So, rename workspace to workspace_old, start eclipse(new workspace will be created automatically), then import "Existing projects" from old workspace.
(If I were you, I'll delete *.tree, start eclipse(at this time, all projects will be vanished in the workspace), and then import "Existing projects" from current workspace without copying. But I'm not sure this is reliable.)
Re: Helios not starting [message #674600 is a reply to message #674449] Fri, 27 May 2011 09:45 Go to previous messageGo to next message
> Thanks.
By now you could have reinstalled and tried again to see if it fixed the
problem. You can have as many copies of Eclipse as you like.
icon12.gif  Re: Helios not starting [message #1723464 is a reply to message #674600] Mon, 15 February 2016 14:39 Go to previous messageGo to next message
Look at the folders page in the eclipse instalation.
it could be in:
C:\Users\xxxx\.metadata\.plugins
I've removed some folders to test and I figured out the error was in the folder: org.eclipse.core.resources
I deleted it and problem solved!
It was due to an energy interruption who for sure must have corrupted a file.
Re: Helios not starting [message #1728709 is a reply to message #1723464] Wed, 06 April 2016 10:58 Go to previous messageGo to next message
I encountered very similar problem launching LiveCycle ES4 Workbench. When clicking on the icon to start Workbench, I got the banner for about 2 seconds and then it closed. I checked the log file and found the same message in the root cause of the stack dump. I removed org.eclipse.core.resources folder from my .plugins folder and restarted LiveCycle Workbench. Worked like a charm! Thanks. - Frank
Re: Helios not starting [message #1742065 is a reply to message #1728709] Wed, 31 August 2016 00:43 Go to previous message
The only thing I'd add to this is that in the above cases, C:\Users\xxxx\ actually refers to the workspace folder; it could be anywhere, not just under C:\Users.
Previous Topic:Cannot Find Eclipse Button Mac OSX
Next Topic:Request for information - UML
Current Time: Sat Jul 19 02:35:54 EDT 2025
Powered by FUDForum. Page generated in 0.09105 seconds
