Home » Modeling » TMF (Xtext) » Xtext grammar related query(Xtext grammar related query)
Xtext grammar related query [message #1741934] Tue, 30 August 2016 12:38 Go to next message
Can anyone please tell me how to use parser rule as part of expression?
Below grammar showing error at Primary Expression because I added Annotation inside Expression. But I need it because my language contains this type of coding.
@app()->test=123 ----------- this works fine
if @app()->test=123 -------------- causes error
My grammar is:
Model: {Model} statements+=Statement*;
Statement: (Annotation)
Annotation: '@app()->' exp+=Expression ;
ArrayDecl : {ArrayDecl} ('[' ']') | ('[' size=exp+=Expression']');
Parenthesis : {Parenthesis} ('(' ')') | ('(' size=exp+=Expression')');
Expression:
LogicalOr
LogicalOr returns Expression:
BitwiseOr ({LogicalOr.left=current} '||' right=BitwiseOr)*
BitwiseOr returns Expression:
LogicalAnd ({BitwiseOr.left=current} '|' right=LogicalAnd)*
LogicalAnd returns Expression:
BitwiseAnd ({LogicalAnd.left=current} '&&' right=BitwiseAnd)*
BitwiseAnd returns Expression:
Equivalency ({BitwiseAnd.left=current} '&' right=Equivalency)*
Equivalency returns Expression:
Relational ({Equivalency.left=current} ('=='|'!='|'=') right=Relational)*
Relational returns Expression:
PlusMinus ({Relational.left=current} ('>='|'<='|'>'|'<') right=PlusMinus)*
PlusMinus returns Expression:
DivMult ({PlusMinus.left=current} ('+'|'-') right=DivMult)*
DivMult returns Expression:
LogicalNot ({DivMult.left=current} ('/'|'*') right=LogicalNot)*
LogicalNot returns Expression:
OnesComplement | ({LogicalNot} '!' expr=OnesComplement)
OnesComplement returns Expression:
Exponentiation ({OnesComplement.left=current} ('~') right=Exponentiation)*
Exponentiation returns Expression:
Concatenation ({Exponentialtion.left=current} '^' right=Concatenation)*
Concatenation returns Expression:
ArrowExpression ({Concatenation.left=current} '##' right=ArrowExpression)*
ArrowExpression returns Expression:
ColonOperator ({ArrowExpression.left=current} '->' right=ColonOperator)*
ColonOperator returns Expression:
Primary | ({ColonOperator} (':'('+')?) expr=Primary)
Primary returns Expression: {Expression}
name=NUMBER | name=STRING | name=ID (ArrayDecl=ArrayDecl? & Parenthesis=Parenthesis?) | ArrayDecl=ArrayDecl | Parenthesis=Parenthesis|Annotation
Re: Xtext grammar related query [message #1741938 is a reply to message #1741934] Tue, 30 August 2016 12:52 Go to previous messageGo to next message
can you please post
(a) a mininal and complete grammar reproducing the problem
(b) if you have customizations to the parserGenerator in the workflow post these as well
Re: Xtext grammar related query [message #1741939 is a reply to message #1741938] Tue, 30 August 2016 13:01 Go to previous messageGo to next message
I have shared you the minimal grammar that reproduces the problem.
I didn't add any customizations to the parserGenerator
Re: Xtext grammar related query [message #1741941 is a reply to message #1741939] Tue, 30 August 2016 13:08 Go to previous messageGo to next message
The grammar is not complete
No definition of if number etc
It is not minimal since the expressions contains way too much stuff
Generating it give a lot of warnings so I assume you use backtracking which is a customization of the parser generator
Re: Xtext grammar related query [message #1741942 is a reply to message #1741941] Tue, 30 August 2016 13:11 Go to previous messageGo to next message
No I am not using any customizations even backtracking also.
Could you please look into the grammar I attached
[Updated on: Wed, 31 August 2016 04:22] by Moderator
Re: Xtext grammar related query [message #1741946 is a reply to message #1741942] Tue, 30 August 2016 13:44 Go to previous messageGo to next message
i do not want to have a look at such a big grammar to solve your problem
i am sure you use backtracking (have a look at your workflow)
the grammar gives me errors and
warning(200): ../org.xtext.example.mydsl1/src-gen/org/xtext/example/mydsl1/parser/antlr/internal/InternalMyDsl.g:719:3: Decision can match input such as "'->' RULE_NUMBER" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(200): ../org.xtext.example.mydsl1/src-gen/org/xtext/example/mydsl1/parser/antlr/internal/InternalMyDsl.g:719:3: Decision can match input such as "'->' RULE_ID" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.mydsl1/src-gen/org/xtext/example/mydsl1/parser/antlr/internal/InternalMyDsl.g:719:3: Decision can match input such as "'->' RULE_STRING" using multiple alternatives: 1, 2
and many others
Re: Xtext grammar related query [message #1741947 is a reply to message #1741946] Tue, 30 August 2016 13:45 Go to previous messageGo to next message
btw what is the error you get.
please use this grammar as starting point
grammar org.xtext.example.mydsl1.MyDsl with org.eclipse.xtext.common.Terminals hidden(WS, SL_COMMENT, ML_COMMENT)
generate myDsl "http://www.xtext.org/example/mydsl1/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model: {Model} NL* statements+=Statement*;
Statement: (NonRecursingStatement|ConditionalElseBlock) ';'? NL+ | HASH_COMMENT NL*;
NonRecursingStatement returns Statement:
	(	OpenAssignment
//Annotation: {Annotation} '@app' '(' (appExp+=Expression)* ')' ('->'appExp+=Expression);
Annotation: '@app' '(' (appExp+=Expression)* ')' ('->'appExp+=Expression);
Block : (statements+=StartBlock) statementlist+=Statement* (statements+=EndBlock);
StartBlock returns Statement : {StartBlock}'{' NL+;
EndBlock returns Statement : {EndBlock}'}';
IfStatement returns Statement: {Statement} 'if'  (ifExp+=Expression)*;
ElseStatement returns Statement: {Else} (HASH_COMMENT NL*)* 'else';
ElseIfStatement returns Statement: (HASH_COMMENT NL*)* ('else' NL* 'if') (exp+=Expression (','? exp+=Expression)*);
ConditionalIfBlock returns Statement:
	IfStatement {ConditionalIfBlock.left=current} NL+ (=>block+=Block|right+=(NonRecursingStatement)|conditionalIfBlock+=ConditionalIfBlock)
ConditionalElseIfBlock returns Statement:
	ConditionalIfBlock {ConditionalElseBlock.left=current} (NL+ elseif+=ElseIfStatement NL+ (=>block+=Block|right+=(NonRecursingStatement)))*
ConditionalElseBlock returns Statement:
	ConditionalElseIfBlock {ConditionalElseBlock.left=current} (NL+ else+=ElseStatement NL+ (=>block+=Block|right+=(NonRecursingStatement)))?
OpenAssignment: args+=Assignment (',' args+=Assignment)* ','?;
Assignment: name=('math')? (precision=Precision)? assignExp+=Expression;
Precision: (width=NUMBER)|((width=NUMBER)?'.'(decimal_places=NUMBER));
Expression:
	Equivalency
	Relational ({Equivalency.left=current} ('=') right=Relational)*
	PlusMinus ({Relational.left=current} ('>') right=PlusMinus)*
	ArrowExpression ({PlusMinus.left=current} ('-') right=ArrowExpression)*
	Primary ({ArrowExpression.left=current} '->' right=Primary)*
	name=NUMBER | Annotation=Annotation | name=ID
terminal ID : (':'('+')?)? ('a'..'z'|'A'..'Z'|'$'|'.'|'@'|'_')('a'..'z'|'A'..'Z'|'$'|'.'|'0'..'9'|'@'|'*'|'_'|'!')*;
terminal STRING : 	'"' ( '\\'('"'|('\r'? '\n')) | !('\n'|'"') )* '"' |
					"'" ( '\\'("'"|('\r'? '\n')) | !('\n'|"'") )* "'";
terminal SL_COMMENT: '//' !('\n' | '\r')*;
terminal HASH_COMMENT : ('#'('\r'? '\n')?) | ('#' !('#'|'\n'|'\r')+ ('\r'? '\n')?) | (('#''#''#') !('\n'|'\r')* ('\r'? '\n')?);
terminal WS  : (' '|'\t'| ('\\'((' '|'\t')* '\r'? '\n')))+;
terminal NL  : ('\r'? '\n')+;
terminal NUMBER: ('+'|'-')? (INT);
terminal INT returns ecore::EInt: '0'..'9' ('0'..'9')*;
Re: Xtext grammar related query [message #1742107 is a reply to message #1741947] Wed, 31 August 2016 09:48 Go to previous message
Thank you sir.
Previous Topic:What is the best JavaFX diagram builder for Xtext language?
Next Topic:Unexpected name generation of the Activator of the UI project in Xtext
Current Time: Fri Jul 18 18:42:23 EDT 2025
Powered by FUDForum. Page generated in 0.25736 seconds
