Home » Modeling » TMF (Xtext) » How to disable cross reference on predefined methods?(How to disable cross reference on predefined methods?)
How to disable cross reference on predefined methods? [message #1741912] Tue, 30 August 2016 10:41 Go to next message
Can anyone please tell me how to disable cross reference "Couldn't resolve reference"?
Re: How to disable cross reference on predefined methods? [message #1741928 is a reply to message #1741912] Tue, 30 August 2016 11:42 Go to previous messageGo to next message
can you explain why you want to do that? i most cases this is a bad idea
Re: How to disable cross reference on predefined methods? [message #1741931 is a reply to message #1741928] Tue, 30 August 2016 12:16 Go to previous messageGo to next message
I have few methods which are in built with my product. So I no need to implement them externally. Editor should check them from jar.
Re: How to disable cross reference on predefined methods? [message #1741937 is a reply to message #1741931] Tue, 30 August 2016 12:48 Go to previous messageGo to next message
Well this question has no easy solution
(a) asuming your libary can be expressed in your dsl itself. and the dsl file containing project is a java project the you can put a jar containing the libary dsl files to the classpath of that project and it will work out of the box
(b) you should have a look at the concept of scoping. you could e.g. provide EObjectDescriptions for our libary inside a customization of DefaultGlobalScopeProvider
(c) you could customize org.eclipse.xtext.linking.ILinkingDiagnosticMessageProvider.getUnresolvedProxyMessage(ILinkingDiagnosticContext) and return null in certain situations
Re: How to disable cross reference on predefined methods? [message #1742117 is a reply to message #1741937] Wed, 31 August 2016 10:34 Go to previous messageGo to next message
Could you please tell me which method creates red underline if it doesn't find cross reference in HyperlinkHelper class?
Or, Can I at least remove red error underline?
[Updated on: Wed, 31 August 2016 10:37] by Moderator
Re: How to disable cross reference on predefined methods? [message #1742119 is a reply to message #1742117] Wed, 31 August 2016 10:36 Go to previous messageGo to next message
(C) debug it
Re: How to disable cross reference on predefined methods? [message #1742127 is a reply to message #1742119] Wed, 31 August 2016 11:32 Go to previous messageGo to next message
Yes I did but any of the methods are not calling up in HyperlinkHelper class
Re: How to disable cross reference on predefined methods? [message #1742129 is a reply to message #1742127] Wed, 31 August 2016 11:48 Go to previous messageGo to next message
hyperlinkhelper uses resolved cross refs. it has ZERO todo with red underlining.
Re: How to disable cross reference on predefined methods? [message #1742131 is a reply to message #1742129] Wed, 31 August 2016 11:56 Go to previous messageGo to next message
Can you explain please bit more?
[Updated on: Wed, 31 August 2016 12:00] by Moderator
Re: How to disable cross reference on predefined methods? [message #1742133 is a reply to message #1742131] Wed, 31 August 2016 12:04 Go to previous messageGo to next message
xtext cross referenced a resolved by the linking infrastructure using the scope provided by scopeproviders.
these use the class i gave you to produce errors.
the hyperlink helper uses at cross reference places that resolved references to do the hyperlinking
(it uses eobjectatoffsethelper)
i still dont know what you actually want to slove?
hyperlinking?
scoping?
ged rid of the error messages?
Re: How to disable cross reference on predefined methods? [message #1742135 is a reply to message #1742133] Wed, 31 August 2016 12:20 Go to previous messageGo to next message
I want to get rid of error messages in case there is no cross reference available. Because I have some in built methods which are not visible to the code. So in such conditions I don't want to show error line. It is fine if they obey parser rule
Re: How to disable cross reference on predefined methods? [message #1742136 is a reply to message #1742135] Wed, 31 August 2016 12:19 Go to previous messageGo to next message
This is the Method i gave you. Set a breskpoint and See what happens
Re: How to disable cross reference on predefined methods? [message #1742137 is a reply to message #1742135] Wed, 31 August 2016 12:54 Go to previous messageGo to next message
I have extended HyperlinkHelper
@Inject
private EObjectAtOffsetHelper eObjectAtOffsetHelper;
but how can I override
public EObject resolveCrossReferencedElementAt(XtextResource resource, int offset) {
INode node = getCrossReferenceNode(resource, new TextRegion(offset, 0));
if (node != null)
return getCrossReferencedElement(node);
return null;
which is in EObjectAtOffsetHelper class.
[Updated on: Wed, 31 August 2016 12:55] by Moderator
Re: How to disable cross reference on predefined methods? [message #1742139 is a reply to message #1742137] Wed, 31 August 2016 13:19 Go to previous messageGo to next message
Yes but that has zero todo with the error message.
What is how to heal with unresolved references when hyper linking
Re: How to disable cross reference on predefined methods? [message #1742141 is a reply to message #1742139] Wed, 31 August 2016 13:23 Go to previous messageGo to next message
So what is the solution for situation?
Re: How to disable cross reference on predefined methods? [message #1742238 is a reply to message #1742141] Thu, 01 September 2016 01:14 Go to previous messageGo to next message
Try to adapt the linking diagnostics message provider. That is a thing of 2 minutes for a first try
Re: How to disable cross reference on predefined methods? [message #1742264 is a reply to message #1742238] Thu, 01 September 2016 05:12 Go to previous message
Yes it is working. Thank you sir.
Previous Topic:Indenting multiline values on serialization
Next Topic:xtext class not found error
Current Time: Wed Jul 23 23:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.05624 seconds
