xtext GenModelSupport error [message #1741740] |
Mon, 29 August 2016 04:48  |
Can anyone please tell me. why this error coming up?
java.lang.NoSuchMethodException: org.eclipse.emf.codegen.ecore.xtext.GenModelSupport.createInjectorAndDoEMFRegistration()
at java.lang.Class.getDeclaredMethod(Unknown Source)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.ensureResourceCanBeLoaded(XtextGeneratorResourceSetInitializer.java:74)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.loadResource(XtextGeneratorResourceSetInitializer.java:59)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.access$0(XtextGeneratorResourceSetInitializer.java:57)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer$1.apply(XtextGeneratorResourceSetInitializer.java:49)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer$1.apply(XtextGeneratorResourceSetInitializer.java:1)
at org.eclipse.xtext.xbase.lib.IteratorExtensions.forEach(IteratorExtensions.java:363)
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:333)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.initialize(XtextGeneratorResourceSetInitializer.java:52)
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:198)
at org.eclipse.xtext.xtext.generator.StandardLanguage.initialize(StandardLanguage.java:169)
at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:176)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:120)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:21)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:65)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:197)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:29)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:18)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
359 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
375 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
391 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
391 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
999 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
999 [main] ERROR textGeneratorResourceSetInitializer - Couldn't initialize GenModel support.
FUDForum. Page generated in 0.05139 seconds
