Use a Sonatype nexus p2 proxy to download with eclipse installer [message #1741105] |
Tue, 23 August 2016 03:14  |
I'm trying to figure out how I can use eclipse installer/oomph in conjunction with my nexus p2 proxy.
Actually, the setup with my nexus P2 proxy works completely with an running instance of eclipse when I want to "Install a new software" or "check for updates".
I'm trying to replace former Google Mechanic to Eclipse Installer to be sure my whole team uses the very same eclipse setup.
As my nexus proxy is actually mirroring internet P2 update site, I want to download my eclipse product through it, but i can't find a way to tell eclipse installer to download "products" through my proxy.
I tried to use -Doomph.redirection.foo but I didn't manage to.
Can someone help me please ?
Thank you.
dom
Re: Use a Sonatype nexus p2 proxy to download with eclipse installer [message #1741256 is a reply to message #1741255] |
Wed, 24 August 2016 04:27   |
When trying with such a configuration,I get this log output, where you can see that my redirection is not mentionned and so not used.
Thank you.
Executing bootstrap tasks
Java(TM) SE Runtime Environment 1.8.0_45-b14
Product org.eclipse.products.epp.package.jee.latest
Bundle org.eclipse.oomph.setup 1.4.0.v20160530-1355, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.core 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.installer 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.p2 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Performing P2 Director (Eclipse IDE for Java EE Developers (Neon))
Offline = false
Mirrors = true
Resolving 63 requirements from 3 repositories to C:\bin\eclipse-test\jee-latest3\eclipse
Requirement epp.package.jee [4.6.0,5.0.0)
Requirement org.eclipse.platform.feature.group [4.6.0,5.0.0)
Requirement org.eclipse.rcp.feature.group [4.6.0,5.0.0)
Requirement org.eclipse.cft.server.core.feature.feature.group
Requirement org.eclipse.cft.server.ui.feature.feature.group
Requirement org.eclipse.datatools.common.doc.user.feature.group
Requirement org.eclipse.datatools.connectivity.doc.user.feature.group
Requirement org.eclipse.datatools.connectivity.feature.feature.group
Requirement org.eclipse.datatools.doc.user.feature.group
Requirement org.eclipse.datatools.enablement.feature.feature.group
Requirement org.eclipse.datatools.intro.feature.group
Requirement org.eclipse.datatools.modelbase.feature.feature.group
Requirement org.eclipse.datatools.sqldevtools.feature.feature.group
Requirement org.eclipse.datatools.sqltools.doc.user.feature.group
Requirement org.eclipse.egit.feature.group
Requirement org.eclipse.egit.mylyn.feature.group
Requirement org.eclipse.jdt.feature.group
Requirement org.eclipse.jpt.common.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.common.feature.feature.group
Requirement org.eclipse.jpt.dbws.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jaxb.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jaxb.feature.feature.group
Requirement org.eclipse.jpt.jpa.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jpa.feature.feature.group
Requirement org.eclipse.jsf.feature.feature.group
Requirement org.eclipse.jst.common.fproj.enablement.jdt.feature.group
Requirement org.eclipse.jst.enterprise_ui.feature.feature.group
Requirement org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.group
Requirement org.eclipse.jst.server_adapters.ext.feature.feature.group
Requirement org.eclipse.jst.server_adapters.feature.feature.group
Requirement org.eclipse.jst.server_ui.feature.feature.group
Requirement org.eclipse.jst.web_ui.feature.feature.group
Requirement org.eclipse.jst.webpageeditor.feature.feature.group
Requirement org.eclipse.jst.ws.axis2tools.feature.feature.group
Requirement org.eclipse.jst.ws.cxf.feature.feature.group
Requirement org.eclipse.jst.ws.jaxws.dom.feature.feature.group
Requirement org.eclipse.jst.ws.jaxws.feature.feature.group
Requirement org.eclipse.m2e.feature.feature.group
Requirement org.eclipse.m2e.logback.feature.feature.group
Requirement org.eclipse.m2e.wtp.feature.feature.group
Requirement org.eclipse.m2e.wtp.jaxrs.feature.feature.group
Requirement org.eclipse.m2e.wtp.jpa.feature.feature.group
Requirement org.eclipse.m2e.wtp.jsf.feature.feature.group
Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
Requirement org.eclipse.mylyn.context_feature.feature.group
Requirement org.eclipse.mylyn.ide_feature.feature.group
Requirement org.eclipse.mylyn.java_feature.feature.group
Requirement org.eclipse.mylyn.wikitext_feature.feature.group
Requirement org.eclipse.mylyn_feature.feature.group
Requirement org.eclipse.pde.feature.group
Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
Requirement org.eclipse.recommenders.rcp.feature.feature.group
Requirement org.eclipse.rse.feature.group
Requirement org.eclipse.rse.useractions.feature.group
Requirement org.eclipse.tm.terminal.feature.feature.group
Requirement org.eclipse.wst.common.fproj.feature.group
Requirement org.eclipse.wst.jsdt.chromium.debug.feature.feature.group
Requirement org.eclipse.wst.jsdt.feature.feature.group
Requirement org.eclipse.wst.server_adapters.feature.feature.group
Requirement org.eclipse.wst.web_ui.feature.feature.group
Requirement org.eclipse.wst.xml_ui.feature.feature.group
Requirement org.eclipse.wst.xsl.feature.feature.group
Requirement org.eclipse.oomph.setup.feature.group
Repository http://download.eclipse.org/technology/epp/packages/neon
Repository http://download.eclipse.org/releases/neon/201606221000
Repository http://download.eclipse.org/oomph/updates/milestone/latest
Adding repository http://download.eclipse.org/technology/epp/packages/neon
Adding repository http://download.eclipse.org/releases/neon/201606221000
Adding repository http://download.eclipse.org/oomph/updates/milestone/latest
ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 HTTP Proxy Authentication Required: http://download.eclipse.org/releases/neon/201606221000/content.xml
ERROR: org.eclipse.ecf.identity code=0 Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:287)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
Re: Use a Sonatype nexus p2 proxy to download with eclipse installer [message #1741627 is a reply to message #1741597] |
Fri, 26 August 2016 08:12  |
Dominique,
I had a lot of trouble using the Nexus p2 proxy. In some cases metadata and artifacts would not match. artifacts.xml contained plugin versions newer than the ones found in the plugin folder. The installation would then fail. In other cases the proxy's update site was unreachable when the proxied update site was offline, which is pretty much the opposite of what I would've expected.
FUDForum. Page generated in 0.04428 seconds
