Home » Modeling » TMF (Xtext) » Parsing exception in xtext grammar(required (...)+ loop did not match anything at input )
Parsing exception in xtext grammar [message #1741156] Tue, 23 August 2016 07:46 Go to next message
I have create xtext grammar(see it bellow) but when I run eclipse I have following exception.
required (...)+ loop did not match anything at input 'IPADDR_eth0'
My parsed string is :IPADDR_eth0="10.170.53.101"
I know that problem is probably in the grammar, but don't know where.
So, where I'm wrong?
Vladimir
grammar com.iamsoft.net.Validate with org.eclipse.xtext.common.Terminals
generate validate "http://www.iamsoft.com/net/Validate"
Model:
	netDescription+=DescriptionPair+;
DescriptionPair:
	ipaddr | netmask | speed | mtu | tso | gateway |  router | subnet | no_vlans | vlan;
 vlan:
	'VLAN_' name=ID '='
	value=IntList;
IntList:
	valueList+=INT+ | '"' valueList+=INT+ '"';
IPAddrList:
	ipNum1=INT '.' ipNum2=INT '.' ipNum3=INT '.' ipNum4=INT;
//List of numbers with 3 digit
 no_vlans:
	'NO_VLANS_' name=ID '=' list+=IntList;
subnet:
	'SUBNET_' name=ID '=' list+=IPWithQuotes;
router:
	'ROUTER_' name=ID '=' list+=IPWithQuotes;
gateway:
	'GATEWAY_' name=ID '=' list+=IPWithQuotes;
mtu:
	'MTU_' name=ID '=' val=IntWithQuotes;
tso:
	'TSO_' name=ID '=' '"' value=ON_OFF '"';
terminal ON_OFF:
	'on' | 'off';
netmask:
	'NETMASK_' name=ID '=' list+=IPWithQuotes;
speed:
	'SPEED_' name=ID '=' value=IntWithQuotes;
ipaddr:
	'IPADDR_' name=ID '=' list+=IPWithQuotes;
IPWithQuotes:
	IPAddrList | '"' IPAddrList '"';
IntWithQuotes:
	value=INT | '"' value=INT '"';
[Updated on: Tue, 23 August 2016 07:54] by Moderator
Re: Parsing exception in xtext grammar [message #1741157 is a reply to message #1741156] Tue, 23 August 2016 07:52 Go to previous message
what is your testmodel? IPADDR_eth0 i an id. maybe you actually mean
terminal ID : '^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
as ID instead of the default impl
Previous Topic:Gets proposal for a position
Next Topic:New line space error
Current Time: Mon Jul 28 17:49:14 EDT 2025
Powered by FUDForum. Page generated in 0.27654 seconds
