Home » Eclipse Projects » Sirius » Properties tab refresh problem
Properties tab refresh problem [message #1741062] Mon, 22 August 2016 11:18 Go to next message
I created a direct edit label element for my nodes. The nodes also have a properties tab when selected in the model. For some reason, when I rename the node models, sometimes the properties tab will refresh with the updated name. For others, they will not refresh their properties and keep the old name, but when deselected and reselected again, the updated name appears on the properties.
Anyone have any solutions for this problem?
Re: Properties tab refresh problem [message #1741107 is a reply to message #1741062] Tue, 23 August 2016 03:17 Go to previous messageGo to next message
Hi Ryan,
Do you define your own new properties views from the VSM (new feature of Sirius 4.0) ? Or do you observe the issue in the standard properties ?
Maxime - Obeo
Re: Properties tab refresh problem [message #1741137 is a reply to message #1741107] Tue, 23 August 2016 06:16 Go to previous messageGo to next message
I am running Sirius 3.1 and I see the issue in the standard properties.
[Updated on: Tue, 23 August 2016 07:20] by Moderator
Re: Properties tab refresh problem [message #1741168 is a reply to message #1741137] Tue, 23 August 2016 08:54 Go to previous messageGo to next message
We are not aware of such an issue.
When you write "a property tab", do you mean a property section or a tab that you added to your modeler (would be displayed as the other tabs: semantic, style, appearance, ...)?
Do you have a scenario to reproduce on the problem on demand ?
In this case you might fill bug on https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Maxime - Obeo
Re: Properties tab refresh problem [message #1741202 is a reply to message #1741168] Tue, 23 August 2016 12:17 Go to previous messageGo to next message
It is a property tab in the modeler. Sorry for the confusion on that.
Re: Properties tab refresh problem [message #1741243 is a reply to message #1741202] Wed, 24 August 2016 02:55 Go to previous message
If you look at org.eclipse.gmf.runtime.diagram.ui.properties.sections.AbstractModelerPropertySection which is a superclass of several property sections, you will notice the getFilter() method and the eventListener field: the property section listens for changes on its EObject to trigger an update.
Regarding how you provide your tab, you might need to have the same logic.
Maxime - Obeo
Previous Topic:External Java Action to set a value
Next Topic:NPE when creating DRepresentation
Current Time: Sun Jul 20 21:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.11444 seconds
