Home » Modeling » EMF » check whether the model is loaded properly or not(check whether the model is loaded properly or not)
check whether the model is loaded properly or not [message #1740987] Mon, 22 August 2016 04:23 Go to next message
Hi ,
I have designed the ecore model with classes A,B,C,D.Now I have generated all the required packages and classes for this.Now I have the xml file which has the serialized objects in form of xml tags of the classes which is specified in the ecore model.Now the problem is if I try to load the xml file which contains the tag which is invalid serailized object then still my model loads only the valid serialized objects.But how can we check whether the xml file conatins the valid tags is as per Ecore model classes.
Re: check whether the model is loaded properly or not [message #1740990 is a reply to message #1740987] Mon, 22 August 2016 04:50 Go to previous message
Loading will throw an exception (while also loading all the valid parts, and you can look at Resource.getErrors()/getWarnings() for information about what problems were encountered during loading.
Previous Topic:[CDO] Load model under alternative EMF metamodel
Next Topic:Efficient check on EDataType
Current Time: Mon Jul 21 05:01:11 EDT 2025
Powered by FUDForum. Page generated in 0.07511 seconds
