Home » Newcomers » Newcomers » update properties in ant build file
update properties in ant build file [message #1740834] Thu, 18 August 2016 15:15 Go to next message
I've started to use ant build files for project builds. If I edit a property value the value substitution does not take affect immediately. Saving the file does not help. The ONLY way I have found to convince eclipse that a property value has changed, whether in the editor or when the ant file is executed, is to close the editor view and reopen it.
Is there some setting I haven't enabled, or is this an eclipse bug?
I'm using the latest version of the Eclipse Mars release.
Re: update properties in ant build file [message #1740927 is a reply to message #1740834] Fri, 19 August 2016 15:19 Go to previous message
It might be a problem of expectation or failure to describe exactly
what's happening. You make a change to build.xml (or other ant source),
then you expect some effect directly? It's only going to be seen when
you invoke ant to perform the build, right?
Previous Topic:Problem while running the python on eclipse
Next Topic:Opacity option for font color and back ground color for a field
Current Time: Sun Jul 27 11:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.08308 seconds
