Home » Modeling » TMF (Xtext) » Ambiguous cross reference
Ambiguous cross reference [message #1740812] Thu, 18 August 2016 12:47 Go to next message
My Xtext grammar has rules that resemble the following:
A:
    'A' name=ID;
B:
    'B' name=ID;
C:
    'C' name=ID;
D:
    A|B;
Relationship:
    ('A' source=[A] | 'B' source=[B]) '=>' target=[C];
I do not get any errors or warnings about ambiguity from Xtext.
I can express models like the following with no errors:
A a1
B b1
C c1
A a1 => c1 // expected
B b1 => c1 // expected
A b1 => c1 // not expected
B a1 => c1 // not expected
My question is why the last two statements do not give errors? How can I change the grammar (rather than the metamodel since it's given) to enforce that? Also, when I create a model, using the Ecore reflective model editor, that creates (a1, b1 and c1) and then a relationship from b1 to c1, and then I look at how it got serialized in the Xtext editor, I see it
A b1 => c 1 //not expected
Thanks for your help.
[Updated on: Thu, 18 August 2016 12:50] by Moderator
Re: Ambiguous cross reference [message #1740813 is a reply to message #1740812] Thu, 18 August 2016 12:52 Go to previous messageGo to next message
The cross referencing is done by the inferred metamodel and not the grammar
So what about naming the references sourcea and sourceb
Re: Ambiguous cross reference [message #1740814 is a reply to message #1740813] Thu, 18 August 2016 12:56 Go to previous messageGo to next message
That would involve changing the metamodel, right? As I said earlier, the metamodel is given not inferred, and source is of type D.
Re: Ambiguous cross reference [message #1740817 is a reply to message #1740814] Thu, 18 August 2016 13:13 Go to previous messageGo to next message
Is the syntax given as well?
Re: Ambiguous cross reference [message #1740819 is a reply to message #1740814] Thu, 18 August 2016 13:21 Go to previous messageGo to next message
Hi Maged
It seems like a bug to me, but without a working example I cannot
experiment.
You might try bring more explicit:
.... returns A:
.... source=[A|ID]
Ed Willink
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Re: Ambiguous cross reference [message #1740820 is a reply to message #1740819] Thu, 18 August 2016 13:27 Go to previous messageGo to next message
If you stick to the grammar you can adapt linking/scopeprovider content assist and maybe the serializer
Re: Ambiguous cross reference [message #1740821 is a reply to message #1740820] Thu, 18 August 2016 13:30 Go to previous messageGo to next message
The grammar (and syntax) is not given, I can change it. It's only the metamodel I cannot change.
[Updated on: Thu, 18 August 2016 13:31] by Moderator
Re: Ambiguous cross reference [message #1740826 is a reply to message #1740821] Thu, 18 August 2016 14:12 Go to previous message
what you can do is
Relationship:
    ({Relationship}'A' source=[A] | {Relationship} 'B' source=[B]) '=>' target=[C];
class MyDslScopeProvider extends AbstractMyDslScopeProvider {
	@Inject
	MyDslGrammarAccess ga
	override getScope(EObject context, EReference reference) {
		if (context instanceof Relationship) {
			if (reference == MyDslPackage.Literals.RELATIONSHIP__SOURCE) {
				val node = NodeModelUtils.findActualNodeFor(context)
				if (node != null) {
					for (cn : node.asTreeIterable) {
						if (cn.grammarElement === ga.relationshipAccess.AKeyword_0_0_0) {
							return delegateGetScope(context, EcoreFactory.eINSTANCE.createEReference=>[EType = MyDslPackage.Literals.A])
						} else if (cn.grammarElement === ga.relationshipAccess.BKeyword_0_1_0) {
							return delegateGetScope(context, EcoreFactory.eINSTANCE.createEReference=>[EType = MyDslPackage.Literals.B])
		super.getScope(context, reference)
class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	override completeRelationship_Source(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		val n = context.currentNode
		if(n instanceof HiddenLeafNode) {
			if ("A" == n.previousSibling?.text) {
				lookupCrossReference(context.getCurrentModel(), EcoreFactory.eINSTANCE.createEReference=>[EType = MyDslPackage.Literals.A], acceptor, Predicates.<IEObjectDescription> alwaysTrue(), getProposalFactory("ID", context));
				return
			} else if ("B" == n.previousSibling?.text) {
				lookupCrossReference(context.getCurrentModel(), EcoreFactory.eINSTANCE.createEReference=>[EType = MyDslPackage.Literals.B], acceptor, Predicates.<IEObjectDescription> alwaysTrue(), getProposalFactory("ID", context));
				return
		} else if (n instanceof LeafNode) {
			if ("A" == n.previousSibling?.previousSibling?.text) {
				return
			} else if ("B" == n.previousSibling?.previousSibling?.text) {
				return
		super.completeRelationship_Source(model, assignment, context, acceptor)
Previous Topic:xtext create open declaration
Next Topic:Import Resolution - XBase
Current Time: Sun Jul 27 15:52:19 EDT 2025
Powered by FUDForum. Page generated in 0.44577 seconds
