Home » Modeling » Epsilon » Validating a weaving model programmatically
Validating a weaving model programmatically [message #1740734] Wed, 17 August 2016 18:02 Go to next message
I want to validate a weaving model, which weaves two ecore metamodel. When I use the launch configuration there is no any problem. However, if I use java, the below error will be appeared.
Undefined variable, type or model: 'Source!EClass'
The minimal example is attached. Please run the validation.java file.
In the example:
GeneralTrace.ecore is the weaving metamodel.
TraceSMMtoTMM.model is the weaving model.
SourceMM.ecore is the source metamodel.
TargetMM.ecore is the target metamodel.
WeavingValidation.evl is the code written in evl for validating the weaving model.
The error is because of the sourceEndType constraint:
context GeneralTrace!TraceLinkEnd{
--TraceLinkEnd type must be set
constraint notEmptyLinkEndType{
check: self.type.isDefined
-- the type of SourceEnd must be related to one of Source meta-classes
constraint sourceEndType{
guard: self.satisfies('notEmptyLinkEndType') and self.sowner.isDefined()
check:Source!EClass.all.select(c|c.name = self.type.name).size() = 1
message: "The meta-class "+self.type.name+"SourceEnd refers to incorrect element"
I register three metamodels correctly but I don't know why the error occurs.
Bests,
Leila.
  • Attachment: TestEVL.zip
    (Size: 15.17KB, Downloaded 139 times)
[Updated on: Wed, 17 August 2016 18:03] by Moderator
Re: Validating a weaving model programmatically [message #1740976 is a reply to message #1740734] Mon, 22 August 2016 00:44 Go to previous messageGo to next message
Hi Leila,
Injecting the following line of code just before the return statement in your "createEmfMetaModel" method should fix this.
emfMetaModel.getResource().getResourceSet().getPackageRegistry().put(EcorePackage.eINSTANCE.getNsURI(), EcorePackage.eINSTANCE);
Dimitris
Re: Validating a weaving model programmatically [message #1740988 is a reply to message #1740976] Mon, 22 August 2016 04:28 Go to previous message
Hi Dimitris,
Thank you so much.
Bests,
Leila.
Previous Topic:How to Copy a Model File?
Next Topic:show validation view programmatically
Current Time: Wed Jul 23 11:49:59 EDT 2025
Powered by FUDForum. Page generated in 0.04431 seconds
