Home » Newcomers » Newcomers » Tomcat can not be started via Eclipse and XAMPP
Tomcat can not be started via Eclipse and XAMPP [message #1740507] |
Mon, 15 August 2016 05:32  |
I installed Eclipse Java Neon and XAMPP.
In Eclipse Java Neon I changed the Tomcat Ports from the standard value
Tomcat admin port 8005
HTTP/1.1 8080
AJP/1.3 8009
to the new values
Tomcat admin port 8044
HTTP/1.1 8088
AJP/1.3 8099
Those values I also changed in the server.xml-file.
I also installed XAMPP and in the control panel I could start Apache and MySQL.
But when i click the start-Button for Tomcat then in the message box is the message written that it is tried to start the tomcat windows service and nothing happens. The color for tomcat doesnt change to green.
Now when I look in Netstat via click on the Netstat-Button then I see there that still the old ports for Tomcat7 are used (8005, 8009, 8080).
My first question is why it has not changed to the new values?
Secondly when I try to start the Tomcat7-Server in the Tab Servers in Eclipse via the green start icon then I get the message:
""Starting Tomcat v7.0 Server at localhost" has encountered a problem. Server Tomcat v7.0 Server at localhost failed to start."
In the console output stands following:
Aug 15, 2016 11:30:44 AM org.apache.catalina.startup.VersionLoggerListener log
INFORMATION: Server version: Apache Tomcat/7.0.70
INFORMATION: Server built: Jun 15 2016 16:27:45 UTC
INFORMATION: Server number: 7.0.70.0
INFORMATION: OS Name: Windows 10
INFORMATION: OS Version: 10.0
INFORMATION: Architecture: x86
INFORMATION: Java Home: C:\Program Files\Java\jre1.8.0_101
INFORMATION: JVM Version: 1.8.0_101-b13
INFORMATION: JVM Vendor: Oracle Corporation
INFORMATION: CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 7.0
INFORMATION: CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 7.0
INFORMATION: Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 7.0
INFORMATION: Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 7.0
INFORMATION: Command line argument: -Dwtp.deploy=C:\Program Files\Apache Software Foundation\Tomcat 7.0\wtpwebapps
INFORMATION: Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 7.0\endorsed
INFORMATION: Command line argument: -Dfile.encoding=Cp1252
Aug 15, 2016 11:30:44 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFORMATION: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre1.8.0_101\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre1.8.0_101/bin/client;C:/Program Files/Java/jre1.8.0_101/bin;C:/Program Files/Java/jre1.8.0_101/lib/i386;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\C:\Program Files\Java\jdk1.8.0_102;C:\Program Files\Skype\Phone\;C:\Program Files\Common Files\Adobe\AGL;C:\Program Files\apache-ant-1.9.7-bin\apache-ant-1.9.7;C:\Users\Rebecca\Desktop;;.
Aug 15, 2016 11:30:45 AM org.apache.coyote.AbstractProtocol init
INFORMATION: Initializing ProtocolHandler ["http-bio-8080"]
SCHWERWIEGEND: Failed to initialize end point associated with ProtocolHandler ["http-bio-8080"]
java.net.BindException: Address already in use: JVM_Bind <null>:8080
at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:413)
at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:650)
at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:435)
at org.apache.coyote.http11.AbstractHttp11JsseProtocol.init(AbstractHttp11JsseProtocol.java:119)
at org.apache.catalina.connector.Connector.initInternal(Connector.java:978)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102)
at org.apache.catalina.core.StandardService.initInternal(StandardService.java:560)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:838)
at org.apache.catalina.startup.Catalina.load(Catalina.java:642)
at org.apache.catalina.startup.Catalina.load(Catalina.java:667)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:253)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:427)
Caused by: java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source)
at java.net.AbstractPlainSocketImpl.bind(Unknown Source)
at java.net.PlainSocketImpl.bind(Unknown Source)
at java.net.ServerSocket.bind(Unknown Source)
at java.net.ServerSocket.<init>(Unknown Source)
at org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:49)
at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:400)
... 17 more
Aug 15, 2016 11:30:45 AM org.apache.catalina.core.StandardService initInternal
SCHWERWIEGEND: Failed to initialize connector [Connector[HTTP/1.1-8080]]
org.apache.catalina.LifecycleException: Failed to initialize component [Connector[HTTP/1.1-8080]]
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:106)
Caused by: org.apache.catalina.LifecycleException: Protocol handler initialization failed
at org.apache.catalina.connector.Connector.initInternal(Connector.java:980)
... 12 more
Caused by: java.net.BindException: Address already in use: JVM_Bind <null>:8080
... 13 more
... 17 more
INFORMATION: Initializing ProtocolHandler ["ajp-bio-8009"]
SCHWERWIEGEND: Failed to initialize end point associated with ProtocolHandler ["ajp-bio-8009"]
java.net.BindException: Address already in use: JVM_Bind <null>:8009
... 16 more
SCHWERWIEGEND: Failed to initialize connector [Connector[AJP/1.3-8009]]
org.apache.catalina.LifecycleException: Failed to initialize component [Connector[AJP/1.3-8009]]
... 12 more
Caused by: java.net.BindException: Address already in use: JVM_Bind <null>:8009
... 13 more
... 16 more
Aug 15, 2016 11:30:45 AM org.apache.catalina.startup.Catalina load
INFORMATION: Initialization processed in 1915 ms
Aug 15, 2016 11:30:45 AM org.apache.catalina.core.StandardService startInternal
INFORMATION: Starting service Catalina
Aug 15, 2016 11:30:45 AM org.apache.catalina.core.StandardEngine startInternal
INFORMATION: Starting Servlet Engine: Apache Tomcat/7.0.70
Aug 15, 2016 11:30:45 AM org.apache.catalina.valves.AccessLogValve open
SCHWERWIEGEND: Failed to open access log file [C:\Program Files\Apache Software Foundation\Tomcat 7.0\logs\localhost_access_log.2016-08-15.txt]
java.io.FileNotFoundException: C:\Program Files\Apache Software Foundation\Tomcat 7.0\logs\localhost_access_log.2016-08-15.txt (Zugriff verweigert)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.apache.catalina.valves.AccessLogValve.open(AccessLogValve.java:1206)
at org.apache.catalina.valves.AccessLogValve.startInternal(AccessLogValve.java:1267)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.StandardPipeline.startInternal(StandardPipeline.java:185)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1133)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:819)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1571)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1561)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Aug 15, 2016 11:30:45 AM org.apache.catalina.startup.HostConfig deployDirectory
INFORMATION: Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\docs
Aug 15, 2016 11:30:46 AM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
INFORMATION: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [153] milliseconds.
Aug 15, 2016 11:30:46 AM org.apache.catalina.startup.HostConfig deployDirectory
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\docs has finished in 885 ms
INFORMATION: Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\examples
Aug 15, 2016 11:30:46 AM org.apache.catalina.core.ApplicationContext log
INFORMATION: ContextListener: contextInitialized()
INFORMATION: SessionListener: contextInitialized()
INFORMATION: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@bcfe68')
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\examples has finished in 743 ms
INFORMATION: Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\host-manager
Aug 15, 2016 11:30:47 AM org.apache.catalina.startup.HostConfig deployDirectory
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\host-manager has finished in 147 ms
INFORMATION: Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\manager
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\manager has finished in 122 ms
INFORMATION: Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\ROOT
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\ROOT has finished in 131 ms
Aug 15, 2016 11:30:47 AM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in 2191 ms
Aug 15, 2016 11:30:47 AM org.apache.catalina.core.StandardServer await
SCHWERWIEGEND: StandardServer.await: create[localhost:8005]:
at org.apache.catalina.core.StandardServer.await(StandardServer.java:444)
at org.apache.catalina.startup.Catalina.await(Catalina.java:781)
at org.apache.catalina.startup.Catalina.start(Catalina.java:727)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:428)
Aug 15, 2016 11:30:47 AM org.apache.coyote.AbstractProtocol pause
INFORMATION: Pausing ProtocolHandler ["http-bio-8080"]
INFORMATION: Pausing ProtocolHandler ["ajp-bio-8009"]
Aug 15, 2016 11:30:47 AM org.apache.catalina.core.StandardService stopInternal
INFORMATION: Stopping service Catalina
Aug 15, 2016 11:30:47 AM org.apache.catalina.core.ApplicationContext log
INFORMATION: SessionListener: contextDestroyed()
INFORMATION: ContextListener: contextDestroyed()
Aug 15, 2016 11:30:47 AM org.apache.coyote.AbstractProtocol stop
INFORMATION: Stopping ProtocolHandler ["http-bio-8080"]
Aug 15, 2016 11:30:47 AM org.apache.coyote.AbstractProtocol destroy
INFORMATION: Destroying ProtocolHandler ["http-bio-8080"]
INFORMATION: Stopping ProtocolHandler ["ajp-bio-8009"]
INFORMATION: Destroying ProtocolHandler ["ajp-bio-8009"]
What can I do so that I can start Tomcat in Eclipse?
Thank you.
Best regards
Rebecca
Re: Tomcat can not be started via Eclipse and XAMPP [message #1740657 is a reply to message #1740507] |
Tue, 16 August 2016 13:23   |
it seems to be that I set now all ports correctly.
But now when I start the tomcat server via the green button then I get following logs in the console:
Aug 16, 2016 7:22:16 PM org.apache.catalina.startup.VersionLoggerListener log
Aug 16, 2016 7:22:16 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Aug 16, 2016 7:22:18 PM org.apache.coyote.AbstractProtocol init
Aug 16, 2016 7:22:18 PM org.apache.catalina.startup.Catalina load
INFORMATION: Initialization processed in 4408 ms
Aug 16, 2016 7:22:18 PM org.apache.catalina.core.StandardService startInternal
Aug 16, 2016 7:22:18 PM org.apache.catalina.core.StandardEngine startInternal
Aug 16, 2016 7:22:18 PM org.apache.catalina.valves.AccessLogValve open
SCHWERWIEGEND: Failed to open access log file [C:\Program Files\Apache Software Foundation\Tomcat 7.0\logs\localhost_access_log.2016-08-16.txt]
java.io.FileNotFoundException: C:\Program Files\Apache Software Foundation\Tomcat 7.0\logs\localhost_access_log.2016-08-16.txt (Zugriff verweigert)
Aug 16, 2016 7:22:18 PM org.apache.catalina.startup.HostConfig deployDirectory
Aug 16, 2016 7:22:20 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
INFORMATION: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [274] milliseconds.
Aug 16, 2016 7:22:20 PM org.apache.catalina.startup.HostConfig deployDirectory
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\docs has finished in 1,849 ms
Aug 16, 2016 7:22:23 PM org.apache.catalina.core.ApplicationContext log
INFORMATION: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@295a03')
Aug 16, 2016 7:22:23 PM org.apache.catalina.startup.HostConfig deployDirectory
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\examples has finished in 2,421 ms
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\host-manager has finished in 330 ms
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\manager has finished in 228 ms
INFORMATION: Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\ROOT has finished in 229 ms
Aug 16, 2016 7:22:23 PM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler ["http-bio-8080"]
INFORMATION: Starting ProtocolHandler ["ajp-bio-8009"]
Aug 16, 2016 7:22:23 PM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in 5407 ms
Aug 16, 2016 7:22:24 PM org.apache.catalina.core.StandardWrapperValve invoke
SCHWERWIEGEND: Servlet.service() for servlet [jsp] in context with path [] threw exception [java.lang.IllegalStateException: No output folder] with root cause
at org.apache.jasper.JspCompilationContext.createOutputDir(JspCompilationContext.java:754)
at org.apache.jasper.JspCompilationContext.getOutputDir(JspCompilationContext.java:203)
at org.apache.jasper.JspCompilationContext.getClassFileName(JspCompilationContext.java:597)
at org.apache.jasper.compiler.Compiler.isOutDated(Compiler.java:459)
at org.apache.jasper.compiler.Compiler.isOutDated(Compiler.java:423)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:655)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:364)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:395)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:339)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:442)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1082)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:623)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Furthermore when I try to open http://localhost:8080/ then I get the 404-http-status.
What is still wrong?
Thank you.
Current Time: Thu Jul 24 23:39:44 EDT 2025
Powered by FUDForum. Page generated in 1.48028 seconds
