buckminster 4.5 can't materialize maven [message #1716917] |
Tue, 08 December 2015 21:53  |
Hi everyone.
does anyone can confirm to me, buckminster headless 4.5 (or buckminster 4.5 in mars) can success materialize maven?
i still run well with buckminster 4.4. but can't with 4.5. error at end.
i use mint 17.x
maven provide like that:
<rm:searchPath name="bundles.maven">
<rm:provider xsi:type="maven:MavenProvider" componentTypes="osgi.bundle" readerType="maven2">
<rm:property key="buckminster.source" value="false" />
<rm:property key="buckminster.mutable" value="false" />
<rm:uri format="xxxx:##central.maven.org/maven2" />
<maven:mappings>
<maven:entry groupId="org.mortbay.jasper" artifactId="apache-jsp" name="org.mortbay.jasper.apache-jsp" />
<maven:entry groupId="org.mortbay.jasper" artifactId="apache-el" name="org.mortbay.jasper.apache-el" />
<maven:entry groupId="org.eclipse.jetty" artifactId="apache-jsp" name="org.eclipse.jetty.apache-jsp" />
</maven:mappings>
</rm:provider>
</rm:searchPath>
error log like that
!ENTRY org.eclipse.buckminster.core 0 293 2015-12-09 09:31:30.912
!MESSAGE bcprov:osgi.bundle/1.53.0: No provider was found that could resolve the request
!ENTRY org.eclipse.buckminster.core 4 293 2015-12-09 09:31:30.913
!MESSAGE ERROR [0185] : No suitable provider for component bcprov:osgi.bundle/1.53.0 was found in resourceMap file:/mnt/data/dev/project/me/repository/idempiere-hsv-group-new/vn.hsv.idempiere.bundles/vn.hsv.feature.idempiere.sdk/adempiere.rmap
ERROR [0185] : No suitable provider for component bcprov:osgi.bundle/1.53.0 was found in searchPath bundles.maven
ERROR [0185] : Resolution attempt ended with exception: Provider maven2(xxxx:##central.maven.org/maven2): Missing CSpec source required by component type osgi.bundle
ERROR Provider maven2(xxxx://central.maven.org/maven2): Missing CSpec source required by component type osgi.bundleorg.eclipse.buckminster.core.ctype.MissingCSpecSourceException: Provider maven2(xxxx:##central.maven.org/maven2): Missing CSpec source required by component type osgi.bundle
at org.eclipse.buckminster.pde.cspecgen.bundle.BundleBuilder.parsePluginModelBase(BundleBuilder.java:243)
at org.eclipse.buckminster.pde.cspecgen.bundle.BundleBuilder.parseFile(BundleBuilder.java:270)
at org.eclipse.buckminster.pde.cspecgen.PDEBuilder.build(PDEBuilder.java:70)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.getResolution(AbstractComponentType.java:319)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.getResolution(AbstractComponentType.java:201)
at org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve(ResourceMap.java:340)
at org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve(ResourceMap.java:252)
at org.eclipse.buckminster.core.resolver.ResourceMapResolver.innerResolve(ResourceMapResolver.java:218)
at org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.resolve(ResolverNodeWithJob.java:217)
at org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.run(ResolverNodeWithJob.java:102)
at org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$NodeResolutionJob.run(ResolverNodeWithJob.java:47)
Re: buckminster 4.5 can't materialize maven [message #1740463 is a reply to message #1716917] |
Sat, 13 August 2016 14:03  |
by debug i catch bellow logic, it give issue to maven.
class org.eclipse.buckminster.pde.cspecgen.bundle.BundleBuilder
line 104 always return null
model.load(bld.getInputStream(), true);
return null;
this code is ok, it here for long time ago.
but new code add at commit 3ced2949599e81dc4ef9cbac4ca261d1f3fd9208
change class org.eclipse.buckminster.core.reader.ZipArchiveReader, function innerReadFile like bellow
while ((ze = zi.getNextEntry()) != null)
if (ze.getName().equals(fileName)) {
result = consumer.consumeStream(this, fileName, zi, new NullProgressMonitor());
break;
if (result == null)
throw new FileNotFoundException(fileName);
so FileNotFoundException always fire when use maven. let issue description at #1
FUDForum. Page generated in 0.03834 seconds
