Xtext templates [message #1008341] |
Mon, 11 February 2013 23:32  |
Hi All,
I wanted to create template for content assist.
The documentation says : you need to create a folder named templates and add templates.xml inside it.
I have created templates.xml by exporting it from the runtime preference page.
The same i added into templates folder of ui plugin.
But it is not working..
Please let me know, i have done anything wrong ??
As a matter of fact, I have also added template folder to exported in build.properties.
Girish
Re: Xtext templates [message #1740365 is a reply to message #1740363] |
Fri, 12 August 2016 05:53   |
I have this templates.xml it resides in the templates folder in the ui project of my plugin and it is enabled in the build section for binary builds.
if I run my plugin in a runtime eclipse the templates are not loaded.
I cannot see my mistake:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<templates>
<template autoinsert="true"
context="de.mdsd.xtext.formatter2.model.FormatterModel.FormatterDefinition"
deleted="false" description="keyword "." ":""
enabled="true" name="keyworddot" id="keyworddot">keyword "." ":" {
format dot {
nospace around
</template>
deleted="false" description="keyword "," " enabled="true"
name="keywordkomma" id="keywordkomma">keyword "," {
format komma {
nospace before
space " " after
</template>
deleted="false" description="keyword ";"" enabled="true"
name="keywordsemicolon" id="keywordsemicolon">keyword ";" {
format semicolon {
nospace before
linewrap(2,0,1) after
</template>
deleted="false" description="format linewrapAround(2,1,1)" enabled="true"
name="linewrapAround" id="linewrapAround">format linewrapAround linewrap (2, 1,1)
around</template>
deleted="false" description="pair "(" ")" "[" "]""
enabled="true" name="pair()"id="pairparenteses">pair "(" ")" "[" "]" {
format openParentesis {
nospace around
format closingParentesis {
nospace before
</template>
deleted="false" description="pair "{" "}" "
enabled="true" name="pair{}" id="pairbaces">pair "{" "}" {
format openBrace {
space " " before
linewrap(2, 0, 0) after
indent after
format closingBrace {
linewrap(2, 1, 1) before
deindent before
</template>
context="de.mdsd.xtext.formatter2.model.FormatterModel.FormatDefinition"
deleted="false" description="use closingBrace" enabled="true"
name="useclosingBrace" id="useclosingBrace">use closingBrace</template>
deleted="false" description="use closingParentesis" enabled="true"
name="useclosingParentesis"id="useclosingParentesis">use closingParentesis</template>
deleted="false" description="use dot" enabled="true" name="usedot" id="usedot">use dot
</template>
deleted="false" description="use komma" enabled="true" name="usekomma"id="usekomma">use komma
</template>
deleted="false" description="use semicolon" enabled="true" name="useksemicolon"id="useksemicolon">use
semicolon</template>
deleted="false" description="use linewrapAround" enabled="true"
name="uselinewrapAround"id="uselinewrapAround">use linewrapAround ${Max_Min_Default}</template>
deleted="false" description="use openBrace" enabled="true" name="useopenBrace"id="useopenBrace">use
openBrace</template>
deleted="false" description="use openParentesis" enabled="true"
name="useopenParentesis"id="useopenParentesis">use openParentesis</template>
</templates>
Re: Xtext templates [message #1760361 is a reply to message #1760358] |
Wed, 26 April 2017 06:44  |
my list missed one point: make sure the templates.xml is mentioned in build.properties
besides this the code for loading it is in org.eclipse.xtext.ui.editor.templates.XtextTemplateStore.loadContributedTemplates()
FUDForum. Page generated in 0.04496 seconds
