Home » Modeling » EMF » [CDO] Is it possible to store generated EMF model directly to CDO?
[CDO] Is it possible to store generated EMF model directly to CDO? [message #1739272] Fri, 29 July 2016 04:52 Go to next message
From the document that I have followed, I understood that every element in EMF model to extend CDOObject. Is this mandatory to extend CDOObject? If yes, then I have an EMF model which is actually developed from other team and don't have permission to extend model class CDOObject. Is there any alternative solution in such case?? otherwise I would request them to update this changes particularly for me.
I have tried to save model elements without extending them to CDOObject, I have been getting Stackoverflow error. I want to be sure this is because of the code modification is required.
[Updated on: Thu, 04 August 2016 01:04] by Moderator
Re: [CDO] Is it possible to store generated EMF model directly to CDO? [message #1739699 is a reply to message #1739272] Thu, 04 August 2016 01:12 Go to previous messageGo to next message
Since I am very new to CDO. It is becoming hard to predict the answer for this. I have tried googling alot, but no breakthrough yet. I think this may be a very dull question. But I am very eager to know the answer. Some one could please share the idea behind it.
Thank you.
Re: Is it possible to store generated EMF model directly to CDO? [message #1739746 is a reply to message #1739272] Fri, 29 July 2016 10:14 Go to previous messageGo to next message
Am 29.07.2016 um 16:27 schrieb Prashanth Parameshwara:
No, it's not strictly required. CDO also supports normally generated models (so called "legacy models").
Of course, it's better to regenerate the models particularly for CDO (so called "native models"). Only then you have the
scalability benefits and can scale your model instances to arbitrary sizes. Legacy models don't support lazy loading and
automatic unloading.
Maybe I can comment on the error if you show the stack trace...
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Is it possible to store generated EMF model directly to CDO? [message #1739752 is a reply to message #1739699] Thu, 04 August 2016 02:27 Go to previous messageGo to next message
Am 04.08.2016 um 08:12 schrieb Prashanth Parameshwara:
I've tried to answer the question in your previous post to this thread, but here I see no new question.
Cheers
/Eike
Re: Is it possible to store generated EMF model directly to CDO? [message #1739869 is a reply to message #1739746] Fri, 05 August 2016 03:42 Go to previous messageGo to next message
First of all, thank you very much for the support Smile
I will see the possibilities to go ahead now. Since Legacy models don't support lazy loading and automatic unloading. I would definitely think more about porting.
And regarding StackOverflowError : stack trace is here below
org.eclipse.emf.cdo.util.CommitException: java.lang.StackOverflowError
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1340)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1290)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1257)
at org.artop.aal.examples.standalone.test.TestCdoAutosarClient.a(TestCdoAutosarClient.java:165)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:27)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: java.lang.StackOverflowError
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEClassifier(CompletePackageClosure.java:97)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEGenericType(CompletePackageClosure.java:165)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEStructuralFeatures(CompletePackageClosure.java:118)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEClassifier(CompletePackageClosure.java:104)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEGenericTypes(CompletePackageClosure.java:156)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEClassifier(CompletePackageClosure.java:106)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEPackage(CompletePackageClosure.java:67)
at org.eclipse.emf.internal.cdo.util.CompletePackageClosure.handleEClassifier(CompletePackageClosure.java:99)
............. and further goes the same.
Re: Is it possible to store generated EMF model directly to CDO? [message #1740344 is a reply to message #1739869] Fri, 12 August 2016 02:18 Go to previous messageGo to next message
@Eike Stepper : You got any luck!! Anything you could figured out for the stack over flow error? Even when I try to add root element also, the error appears.
BTW, I have been continuously getting the error for whatever may be the code changes and also I would like to mention that the ecore contains lots of Packages and Class type. Could this be the problem??
[Updated on: Fri, 12 August 2016 03:29] by Moderator
Re: Is it possible to store generated EMF model directly to CDO? [message #1740461 is a reply to message #1740344] Sat, 13 August 2016 11:58 Go to previous message
I looked into "CompletePackageClosure". But from the mentioned stacktrace and no ecore-model given for reproducing it, it's difficult to say whats going wrong. (or it's perhaps obvious? Smile )
The 'visitedPackages.add' and 'visited.add' should prevent an endless recursion. Are 'equals' methods overridden somewhere in your generated code? You could debug and look which packages/objects cause the the infinite recursion.
Re: Is it possible to store generated EMF model directly to CDO? [message #1741985 is a reply to message #1739869] Fri, 12 August 2016 06:34 Go to previous message
Am 05.08.2016 um 09:42 schrieb Prashanth Parameshwara:
> First of all, thank you very much for the support :)
> [...]Caused by: java.lang.StackOverflowError
The CompletePackageClosure class is supposed to detect and ignore cycles automatically. So, either there's a bug in it
or your model is just very big and possibly deep. Is it possible to have a look at your model? Is it just one Ecore file
or are there multiple, cross-referenced files?
Cheers
/Eike
Previous Topic:[CDO] EMF Compare with CDOFileResources
Next Topic:[CDO] Load model under alternative EMF metamodel
Current Time: Tue Jul 29 02:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.04939 seconds
