Home » Eclipse Projects » Eclipse 4 » Get position or triggering mouse event of MPopupMenu
Get position or triggering mouse event of MPopupMenu [message #1740198] Wed, 10 August 2016 07:12 Go to next message
I have a popup menu defined for a part.
I register the menu for a particular control using
menuService.registerContextMenu(xrefPane, "uk.co.xbundle.assembly.xrefs.popupmenu");
The popup menu successfully opens on a right click on the control.
The handler defined for one of the menu items has signature:
@Execute
public abstract void execute(MPopupMenu menu) {
This works, because the triggering popup menu is injected from the context.
I now need to access the xy of the right mouse click which triggered the popup menu, but I can't find my way through to this.
Does anyone know how to get this, or another idiomatic way to get the riggering MouseEvent through to the handler?
Robert
[Updated on: Wed, 10 August 2016 07:13] by Moderator
Re: Get position or triggering mouse event of MPopupMenu [message #1740201 is a reply to message #1740198] Wed, 10 August 2016 07:46 Go to previous messageGo to next message
IIRC there's no coordinate available (even at the SWT level) because a
popup menu could also be triggered through keyboard shortcuts. The only
possible work around is to get the current cursor location.
Tom
> @Execute
> Thanks
> Robert
Re: Get position or triggering mouse event of MPopupMenu [message #1740226 is a reply to message #1740201] Wed, 10 August 2016 10:41 Go to previous messageGo to next message
Thanks Tom
In EclipseFX I worked around using:
ContextMenu cm = (ContextMenu) ((WPopupMenu<ContextMenu>) menu.getWidget()).getWidget();
double x = cm.getX();
Robert
Re: Get position or triggering mouse event of MPopupMenu [message #1740252 is a reply to message #1740226] Wed, 10 August 2016 14:35 Go to previous messageGo to next message
Oh you are talking about FX? It somehow feels wrong to rely on UI
information an naturally you rely on a implementation detail of the
renderer framework (although unlikely to change any time :-).
I guess if you describe your usecase a bit more we could find a better
solution. Why do you need the x/y information?
Tom
On 10.08.16 16:41, Robert Onslow wrote:
> Thanks Tom
> Robert
Re: Get position or triggering mouse event of MPopupMenu [message #1740376 is a reply to message #1740252] Fri, 12 August 2016 08:28 Go to previous message
Hi Tom
This attached screen shot shows a cross reference on a document on the right hand side. (This is the Text control showing "trial/1/2" in the left hand margin of the document)
A new cross reference is added by clicking "End XRef" on a popup menu, also shown.
The handler needs to know where on the document the popup was triggered in order to know where to place the new cross-refererence on the document.
That means getting some info about the triggering event, or the position of the popup, into the handler attached to the End XRef menu item.
MPopupMenu at the moment has no access to the triggering mouse event, or the position of the popup. Hence the clunky workaround by getting hold of the rendered component which I agree is less than ideal.
Could MPopupMenu eventually contain some triggering data do you think? It seems to me that popups will quite often need to pass positional data to handlers - e.g. adding components to a diagram via a popup etc.
Robert
Previous Topic:MessageConsole
Next Topic:Persisted object when closing MPart ?
Current Time: Sun Jul 20 22:37:15 EDT 2025
Powered by FUDForum. Page generated in 0.05090 seconds
