Home » Eclipse Projects » OM2M » om2m and Iot(om2m and Iot)
om2m and Iot [message #1739587] Wed, 03 August 2016 03:18 Go to next message
Hi all,
I am developing IoT solution and now i want that to be OM2M std.
Before that I want some clarification,
1) what is the difference between OM2M and ONEM2M.
2)If i have a Temperature Sensor and want to do OM2M implementation on board and gateway, how can i proceed.
3)Which industry/domain are using OM2M for their product.
Thank you Smile
Re: om2m and Iot [message #1739723 is a reply to message #1739587] Thu, 04 August 2016 06:10 Go to previous messageGo to next message
1) OM2M is not a standard, it is an implementation of the oneM2M standard.
2) You should run an IN (Infrastructure Node) as the "root" of your system. Then run an MN (Middle Node) which is going to register to the IN previously created. And after that, you will have to register your Temperature Sensor to this MN as a new AE (Application Entity). In order to communicate to between your sensor and OM2M you have to create an IPE (Interworking Proxy application Entity) such as described in this tutorial : https://wiki.eclipse.org/OM2M/one/Developer
3) I can't answer that, sorry
Dorian Smile
[Updated on: Fri, 05 August 2016 05:30] by Moderator
Re: om2m and Iot [message #1739851 is a reply to message #1739723] Fri, 05 August 2016 00:14 Go to previous messageGo to next message
Hi Dorian
Thanks a lot for the reply. I will follow the steps.
If i have some doubt i will get back to you.
Thanks and Regards
Soumya Smile
Re: om2m and Iot [message #1739877 is a reply to message #1739851] Fri, 05 August 2016 05:36 Go to previous messageGo to next message
Ok Smile
Oh, and maybe this page can answer your third question : https://wiki.eclipse.org/OM2M/Community. I don't know if it is exhaustive but it can give you an idea.
Dorian
Re: om2m and Iot [message #1765303 is a reply to message #1739877] Thu, 08 June 2017 05:32 Go to previous messageGo to next message
Dear soumya patra,
I am very new in OM2M, I am doing the same like you. I have connected Temperature sensor and current sensor with Arduino and sending the measurement data to local server as MQTT messages. could you tell me what you did after this how did you connected your sensor with OM2M ?
Thank you..!!
Re: om2m and Iot [message #1775124 is a reply to message #1765303] Tue, 24 October 2017 23:37 Go to previous message
Dear all,
I am also working on an om2m project and would like to know how can sensor nodes be connected to the IoT gateway (om2m). I know Dorian shared a useful link which uses plugins (thank you), but is there any other resource which can be helpful?
thanks
Previous Topic:Announced Resources handle in remote located IN-CSE
Next Topic:raspberry as gateway
Current Time: Sun Aug 31 09:32:35 EDT 2025
Powered by FUDForum. Page generated in 0.03377 seconds
