Home » Eclipse Projects » e(fx)clipse » Dependency Injection
Dependency Injection [message #1080106] Mon, 05 August 2013 09:28 Go to next message
i want to use my own DI objects but unfortunately it doesn't work.
I use eclipse 4.2.2.
I want to use the variable "table" from the ListView class in the CreateFeatureHandler class. I always get the following error message:
org.eclipse.e4.core.di.InjectionException: Unable to process "ListView.table": no actual value was f
ound for the argument "javafx.scene.control.TableView<Feature>".
@SuppressWarnings("restriction")
public class ListView {
    @Inject
    private TableView<Feature> table;
    @SuppressWarnings("unchecked")
    @Inject
    public ListView(BorderPane parent, final MApplication application, IEclipseContext context) {
    table = new TableView<Feature>();
        ... (content of the table)
    context.modify("table", table);
public class CreateFeatureHandler {
    private Stage stage;
    @Execute
    @Inject
    void execute(@Optional final Feature feature, @Named("table") final TableView<Feature> table) {
    GridPane grid = new GridPane();
    grid.setHgap(10);
    grid.setVgap(10);
    grid.setPadding(new Insets(0, 10, 0, 10));
    final TextField name = new TextField();
    name.setPromptText("name");
    final TextField number = new TextField();
    number.setPromptText("number");
    Button b = new Button("Create");
    b.setOnAction(new EventHandler<ActionEvent>() {
        public void handle(ActionEvent e) {
        Feature feat = TeamFactory.eINSTANCE.createFeature();
        feat.setName(name.getText());
        feat.setNumber(number.getText());
        LocalFileTest.addFeatureAndSaveIt(feat);
        System.out.println("TABLE:\t"+table);
        stage.close();
    grid.add(new Label("name:"), 0, 0);
    grid.add(name, 1, 0);
    grid.add(new Label("number:"), 0, 1);
    grid.add(number, 1, 1);
    grid.add(b, 1, 2);
    stage = new Stage(StageStyle.DECORATED);
    stage.initModality(Modality.WINDOW_MODAL);
    Scene s1 = new Scene(grid);
    stage.setScene(s1);
    stage.show();
Re: Dependency Injection [message #1080114 is a reply to message #1080106] Mon, 05 August 2013 09:35 Go to previous messageGo to next message
You need to call IEC.set("table",table) - modify only works if you have
declared this variable at first on the IEC (not needed in your case)
Tom
On 05.08.13 15:29, Patrick Sowada wrote:
> Quote:
> @Inject private TableView<Feature> table;
> @Inject
> @Execute
> @Inject
> grid.setHgap(10);
> grid.setVgap(10);
> stage.close();
> grid.add(b, 1, 2);
> stage.setScene(s1);
> stage.show();
Re: Dependency Injection [message #1080115 is a reply to message #1080114] Mon, 05 August 2013 09:38 Go to previous messageGo to next message
.... not unimportant - this naturally only works if the part with the
table is the current active part in your application because handlers
are executed always in the current active context.
Tom
> Tom
>> Hi,
>> Quote:
>> @Inject
>> @Execute
>> @Inject
>> grid.setHgap(10);
>> grid.setVgap(10);
>> stage.close();
>> grid.add(b, 1, 2);
>> stage.setScene(s1);
>> stage.show();
Re: Dependency Injection [message #1080846 is a reply to message #1080115] Tue, 06 August 2013 08:54 Go to previous message
great it works, thx for your help
Re: Dependency Injection [message #1739765 is a reply to message #1080115] Tue, 06 August 2013 08:54 Go to previous message
Previous Topic:e(fx)clipse 0.9.0 is feature complete
Next Topic:Re: application doesn't start anymore
Current Time: Wed Jul 23 12:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.04579 seconds
