Home » Eclipse Projects » Target Management » Need example code snippet to open remote terminal and execute shell commands programmatically(Need an example code to open remote terminal and execute shell commands programmatically)
Need example code snippet to open remote terminal and execute shell commands programmatically [message #1739730] Thu, 04 August 2016 08:00 Go to next message
I am using the below code to open a remote terminal and execute a shell command in it.
            TerminalsUI terminalsUI = TerminalsUI.getInstance();
            TerminalViewer viewer = terminalsUI.activateTerminalsView();
            CTabItem tab = viewer.getTabFolder().createTabItem(TerminalServiceHelper.getTerminalSubSystem(conn).getHost(), "");
            TerminalElement element = TerminalServiceHelper.createTerminalElement(tab,
                    TerminalServiceHelper.getTerminalSubSystem(conn));
            TerminalServiceHelper.getTerminalSubSystem(conn).addChild(element);
            ITerminalShell lol = element.getTerminalShell();
            TerminalShellService fdf = (TerminalShellService)RSEHelper.getConnectedRemoteShellService(conn, null);
            SshTerminalService shelll = (SshTerminalService)fdf.getAdapter(ITerminalService.class);
            element.setTerminalShell((ITerminalShell)shelll);
            shelll.launchTerminal(null, null, new String[] {}, "", "ls -l", null);
This is opening the remote terminal in "Terminals" view with the content:
Last login: Wed Aug 17 11:14:33 2016 from 10.X.X.X
root@moron:~#
Also command ls -l was not executed and shown in the newly opened terminal may be because of the exception:
java.lang.ClassCastException: org.eclipse.rse.internal.services.ssh.terminal.SshTerminalService cannot be cast to org.eclipse.rse.services.terminals.ITerminalShell
at the line: element.setTerminalShell((ITerminalShell)shelll);
Question:
The above code snippet gives warning as "Discouraged access" at many places.
Please can any one post the recommended code snippet that can be used to open a remote terminal programmatically and execute commands in it programmatically?
[Updated on: Thu, 04 August 2016 08:01] by Moderator
Re: Need example code snippet to open remote terminal and execute shell commands programmatically [message #1739736 is a reply to message #1739730] Thu, 04 August 2016 08:42 Go to previous messageGo to next message
are you sure you want to do this inside the RSE Framework (RSE Terminals View) ?
I would personally recommend using the newer Terminal 4.x view instead, which has direct SSH access with a lot less bulk around it. A code snippet for programmatically open a tab in that view is referenced here:
https://marketplace.eclipse.org/comment/3982#comment-3982
and here:
https://dev.eclipse.org/mhonarc/lists/tm-dev/msg01128.html
and here:
https://dev.eclipse.org/mhonarc/lists/tm-dev/msg01044.html
Martin
Re: Need example code snippet to open remote terminal and execute shell commands programmatically [message #1739872 is a reply to message #1739736] Fri, 05 August 2016 04:22 Go to previous message
Yes. Is it not possible to do it on older RSE/TM. I am using org.eclipse.rse.terminals.ui (1.3.0.201504210807).
I am able to execute commands in remote shell with the below code:
	IWorkbenchWindow window = HandlerUtil.getActiveWorkbenchWindowChecked(event);
            IStructuredSelection sel = (IStructuredSelection)window.getSelectionService().getSelection();
            RemoteProcessImpl ele = (RemoteProcessImpl)sel.getFirstElement();
            IHost conn = ele.getSystemConnection();
            IRemoteCmdSubSystem cmdSS = RemoteCommandHelpers.getCmdSubSystem(conn);
            Object[] obs = null;
            RemoteOutput fe = null;
            try {
                cmdSS.checkIsConnected(null);
            } catch (SystemMessageException e2) {
                e2.printStackTrace();
            try {
                cmdSS.initializeSubSystem(null);
            } catch (SystemMessageException e1) {
                e1.printStackTrace();
            RemoteCommandShell shell = null;
            try {
                shell = (RemoteCommandShell)cmdSS.getDefaultShell();
            } catch (Exception e) {
                e.printStackTrace();
            shell.removeOutput();
            cmdSS.sendCommandToShell("ls -l", shell, null);
            Thread.sleep(1000);
            obs = new Object[shell.getRoots().length];
            obs = shell.getRoots();
            for (int i = 0; i < obs.length; i++) {
                fe = (RemoteOutput)obs[i];
                String op1 = fe.getText();
                System.out.println(op1);
            command.setLength(0);
I want to do the same thing in remote terminal.
Previous Topic:using Remote Terminal in my plugin
Next Topic:Add connections from code
Current Time: Mon Nov 03 16:56:01 EST 2025
Powered by FUDForum. Page generated in 0.03757 seconds
